Drag n Drive build normally aspirated #3254182
08/27/24 08:33 PM
08/27/24 08:33 PM
Hawai’i
62Val Offline OP
62Val  Offline OP
Hawai’i
Looking for some advice as to which might be better to build a small block 450 cubes R5P7 head or a w9RP head engine. Or a big block 622 cubes wedge B1MC head or a Hemi millennium stage V head engine. Pros small block lighter pkg. less torque easier to hook. Big block pros less abuse, less maintenance lower rpm launch easier on drive train? 2600lb car cal trac leaf sprung car 6 speed 10.5x28 tire. Opinions?
Re: Drag n Drive build normally aspirated [Re: 62Val] #3254220
08/28/24 05:17 AM
08/28/24 05:17 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I believe small blocks bigger than 430 cubes have to compete in the big block class....After that, I guess it depends on budget and ET goals. Most NA combos will be in the 9's, with a nasty BB probably capable of upper 8's...
The other thing to keep in mind, is the tire size your using...A BB is going to hit the tire pretty hard to launch, so if your doing a small tire, I would just go SB....
Re: Drag n Drive build normally aspirated [Re: 62Val] #3254228
08/28/24 06:10 AM
08/28/24 06:10 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
At 2600lb 900hp will get you into the 8's. Our old 580 makes a little more than that and pushes our just over 4000lb E body into the 9's on 29.10.5 slicks. On our car for drag and drive I'd tame the valvetrain down some (currently .768") and upgrade the cooling system. Likely I'd swap rocker arm ratio's to 1.5 from 1.6 or go smaller on the cam with 1.7's for race and 1.5 for road. We have a drag and drive weekend which is around a 500 mile round trip (UK), I hear some guys are running bigger cams with no issues but boost seems to be the weapon of choice. There are lot's of options out there for power management but for N/A it's usually timing control.
Re: Drag n Drive build normally aspirated [Re: Tig] #3254239
08/28/24 08:19 AM
08/28/24 08:19 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
What valvetrain do you think will survive the street drive better? A 9000 rpm small block or 7000 RPM big inch Hemi? Survival is key.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Drag n Drive build normally aspirated [Re: Hemi_Joel] #3254246
08/28/24 08:52 AM
08/28/24 08:52 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Steve Morris did a thing on valve springs breaking. Seems that running at one rpm for extended periods of time breaks valve springs, and varying engine rpms doesn't. shruggy
Re: Drag n Drive build normally aspirated [Re: Hemi_Joel] #3254257
08/28/24 09:44 AM
08/28/24 09:44 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
The one with the best valvetrain geometry...
69 GTX 68 Road Runner
Re: Drag n Drive build normally aspirated [Re: John Brown] #3254265
08/28/24 09:57 AM
08/28/24 09:57 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I thought that was interesting, but I don't know if it is possible to drive for an extended period of time at the exact same engine RPM. Especially with an automatic with a loose converter. I have done 9 drag and drives with my Barracuda. I have run cheap K-motion springs that I changed every year. I have run expensive comp endurance springs that I have used up to 6 years. I have never broken a spring even with a fairly healthy spec'd solid roller. I have broken a rocker arm, and killed a few pushrod tips. I think the rocker arm broke because the shaft was torn up under the bearing on the bottom half and it bound up. The pushrod tip thing was a hardening problem with the adjusters or the pushrods. I ran years with the same pushrods and adjusters, then all the sudden it ate 1, then it ate 4 or 5 more on that one drag week. They didn't turn blue or anything they just wore the cup out. It was like my original wore out, then my spares were crap.
The big block NA class is usually a little slower than the small block class at drag week. But either class can have a ringer that kills the rest of the field. Small Block NA record is like 8.60 at 3200 or 3300lbs I think. But you never know what shows up. I ran the small block super street class one year just because I wanted to run earlier in the day and didn't care how I placed. I ended up 3rd with a 10.57 average. 2nd was 10.40s and 1st was like 9.0ish.
68 Barracuda Formula S 340
Re: Drag n Drive build normally aspirated [Re: Bad340fish] #3254268
08/28/24 10:10 AM
08/28/24 10:10 AM
an8sec70cuda Offline
Didn't Doc w/ the red camaro run like 7.90s or 8.0s in the BB NA class?
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: Drag n Drive build normally aspirated [Re: an8sec70cuda] #3254283
08/28/24 11:03 AM
08/28/24 11:03 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Green Mustang has been WELL into the 7's NA...Dont know the owners name. I know they change rockers during the drive
Re: Drag n Drive build normally aspirated [Re: Al_Alguire] #3254292
08/28/24 11:49 AM
08/28/24 11:49 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Green Mustang AKA "Snot Rocket" has been sold. As for Doc he runs the Pro Street BB NA class with big tires. Doc has something in the works for Sick Week 2025 that is much lighter.Love to see his co pilot get out of that car. LOL Jasons Camaro has been 8.60s as posted. Right at one inch of lift. He and his wife have it figured out. Probly that Mopar intake. LOL. Buddy of mine has a big inch small block R3 W9RP. with a man pedal thats been bottom 9s. Chinese crank shaft is now in two pieces, Have to be a glutton for punishment to be NA powered.
Re: Drag n Drive build normally aspirated [Re: ksj] #3254298
08/28/24 12:18 PM
08/28/24 12:18 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I am referring to the blue colored fox body with a BBC owned by Ed Ensor. Been in the 7.40's
https://www.youtube.com/watch?v=p-C-RJpV8wA
Re: Drag n Drive build normally aspirated [Re: Al_Alguire] #3254301
08/28/24 12:25 PM
08/28/24 12:25 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
That car is a beast.
Re: Drag n Drive build normally aspirated [Re: an8sec70cuda] #3254303
08/28/24 12:31 PM
08/28/24 12:31 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Yeah but he has a Billet Goodwin motor, kicks him to the Pro-Street class.
Ensor's cars are always top notch performers and could win a car show. I think his current car has to run unlimited since it is a super light tube chassis deal.
I wish I had the budget and the time some of these guys have lol.
Re: Drag n Drive build normally aspirated [Re: Bad340fish] #3254379
08/28/24 06:53 PM
08/28/24 06:53 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I think it was 2019 when Brett Miller and Brad Bowers ran Drag Week. I think it was Brad's Dart and Brett's old Engine Masters Motor which I think was R3W8. They won their class.
That same year someone was running an R5p7 motor in another class, it was a stick shift with some engine setback.
I don't remember the times but I think on most if not days the W8 motor was faster.
If anyone else has more details please chime in.
Re: Drag n Drive build normally aspirated [Re: 340Cuda] #3254395
08/28/24 07:51 PM
08/28/24 07:51 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
R5P7 was a 69 Dart from Sweden wasnt it? Old school paint. Red and white I think. I remember it being a three pedal car.
Re: Drag n Drive build normally aspirated [Re: ksj] #3254440
08/28/24 11:17 PM
08/28/24 11:17 PM
Hawai’i
62Val Offline OP
62Val  Offline OP
Hawai’i
I just saw an article on Ed’s mustang he cut a 7.12 and a 7.11 some rough math sez he’s doin 1500 maybe 1600 N/A, that’s crazy no BB wedge is gonna make that kinda power with the heads we have maybe a Hemi I don’t know?
Re: Drag n Drive build normally aspirated [Re: Al_Alguire] #3254462
08/29/24 05:35 AM
08/29/24 05:35 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Not sure if this was clickbait but the video launched was a campaign add for some incompetent lady running for office, IDK? laugh
Re: Drag n Drive build normally aspirated [Re: 62Val] #3254464
08/29/24 05:37 AM
08/29/24 05:37 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Good luck getting a Caltrac car that light!
Re: Drag n Drive build normally aspirated [Re: Dragula] #3254474
08/29/24 07:01 AM
08/29/24 07:01 AM
gregsdart Offline
gregsdart  Offline
There is a way around the hard hit of a bigblock. Use a CO2 throttle controller set at low launch rpm, and it will take about .05 aeconds to open fully on launch. Additionally it takes a very small amount of time for full airflow to reach the cylinders. The result forced me to take about .05 seconds out of my delaybox for good reaction times. Now i am at 1.04 versus 1.09. But the Dart now leaves like a pro stocker, no violent wheelstands and it no longer hits the wheelie bars hard enough to spin the rear tires. 1/4 8.60 et, 122 60 ft, launch rom 4000, stall 6200. I do have 51 percent front weight, 2905 lbs, 106 wb.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Drag n Drive build normally aspirated [Re: gregsdart] #3254476
08/29/24 07:30 AM
08/29/24 07:30 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
An MSD grid will retard the timing from a launch event (T/B or F/B) by as much as you want and for how long as you want. Fit an MSD ARC module and it will do this as soon as it sees too much wheelspeed any time during the pass from the launch event. up
