Re: 1968 Valiant 1st Gen HEMI Project [Re: gtx6970] #3244640
07/15/24 11:23 AM
07/15/24 11:23 AM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
I’ve been getting the parts car and pieces ready to list for sale and finally got everything together (it’s listed on this site under A Bodies for sale).
[Linked Image]Z R34 by M Patterson, on Flickr
We still got a little done on the Green car. When I test drove the car before I bought it, the rear end howled like a banshee. The rear end had 4.10s in it, which I knew I was going to change out for a set of 4.30s anyway so that was no big deal. I had already ordered the gears when I determined it was a 489 housing.
Everything I’ve looked at on the Green car had been very well done with quality parts. Tearing the rear end apart was really no different; new brake drums, aftermarket axles, new Green bearings. When we got the carrier out it also had new bearings and had a new ring and pinion, but who ever set it up either didn’t know how to set it up or didn’t care and had ruined a new set of gears. Fortunately, the case and sure grip were still good. Honestly I don’t have the patience to set up rear ends, and I don’t think I could stand long enough to do it anyway so I sent it out to a guy I trust to do them. It came back yesterday and is ready to go back in next weekend.
[Linked Image]489 430 by M Patterson, on Flickr
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: 1968 Valiant 1st Gen HEMI Project [Re: Mike P] #3249599
08/05/24 12:27 PM
08/05/24 12:27 PM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
The 4.30s made it into the rear end housing a couple weekends ago and the rear end was buttoned back up. So progress I guess.
[Linked Image]Z 4.30 by M Patterson, on Flickr
And then there was the ashtray. Both Valiants I bought had the ashtrays removed and gauges stuffed in the hole. Fortunately the dash bracket was still in the parts car and rummaging around in the truck I found the ashtray. Unfortunately the 4 ball bearings and bracket they ride in was missing. I’d already determined I will probably never use the dash ashtray but if it’s not there it leaves a hole that the new center AC vent won’t quite cove and I know it would bug the dickens out of me. So I started looking for a complete astray/brackets assembly. That’s when I found out they are one year only for Valiants and Barracudas, are usually missing the bearings and slider bracket and are usually pretty pricey if you can find a complete assembly.
After some thinking I figured that the ashtray will only need to slide into the dash once. That being the case I picked up an assortment of bearings off Amazon and used 4 (9MM) bearings and tack welded them to the ashtray bracket. I ended up welding 2 in the wrong place and had to relocate them (and forgot to take a picture before I installed the bracket).
[Linked Image]Z AT2 by M Patterson, on Flickr
At least it holds the ashtray in the correct position and fills the hole.
[Linked Image]Z A by M Patterson, on Flickr
Next on the list was to install the new gas tank. Before I’d bought the new 18 gallon tank, I did crawl under the car to make sure it would fit with the coil-overs and ladder bars. It sure looked like it would….. (I suspect you know where this is going). The factory tank is designed to wrap around the spare tire well and when it’s back far enough to do that it interferes with the coil overs. Yup what was supposed to be a 20 minute job just got complicated. We’re currently in the process of redoing the trunk floor.
We also have just stared on the EPAS Electric power steering unit and are in the process of figuring out where and how to get the aftermarket AC/Heat unit installed under the dash. As none of those projects are done yet I’m going to hold off posting about them until the installations are complete.
Re: 1968 Valiant 1st Gen HEMI Project [Re: Mike P] #3253084
08/22/24 11:48 AM
08/22/24 11:48 AM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
So back to the gas tank and trunk. This is the trunk/fuel cell I started with. As this will be a street car/daily driver I wanted to have a functional trunk with enough room for a full size spare tire, tool box, jack, tire changing tools, plus enough room for a suitcase or 2.
[Linked Image]Fuel Cell by M Patterson, on Flickr
I had decided to go back to a stock tank so I bought a new 18 gallon tank but as mentioned there were interference issues between it and the rear coil overs. It looked like I had a couple of options short of going back to the fuel cell (which ain’t gonna happen). Some guys have cut the spare tire well completely out, plated over the trunk floor and run a Satellite/Coronet gas tank on their Valiants/Darts. I’ve also seen where others notched the spare tire well and moved the tank forward.
I looked at several tanks for adaptability and if I could have gained another 5 gallons or so of capacity, I’d probably would just have bought another tank and sender. Of the readily available tanks I looked at that would work with the flat trunk floor I’d only gain 1 or 2 gallons so the decision was made to notch the spare tire well and use the tank and sender I already have. Of course relocating the tank led to a few “down stream” issues that also had to be addressed.
The Valiant tank is designed to wrap around the spare tire well, so moving it forward requires part of the spare tire be removed.
[Linked Image]Z T 1 by M Patterson, on Flickr
[Linked Image]Z STW 1 by M Patterson, on Flickr
Doing this requires a custom fill pipe and cutting and welding (which thankfully I’m still be able to do). Losing the spare tire well is not a problem as it’s too small to hold a 28” tall tire anyway.
I found a rear cargo floor pan from a Jeep that’s big enough to cover the tire well and has reinforcement ridges rolled into it. By retaining part of the spare tire well and putting a hatch in it, I could have a nice storage compartment for a jack and impact wrench. The new floor was trimmed, fitted and welded in place and sealed.
[Linked Image]Z C by M Patterson, on Flickr
[Linked Image]Z TF by M Patterson, on Flickr
I used spray on urethane bed liner instead of undercoating on the bottom of the new floor pan. For inside of the trunk I used a tintable bed liner without the texture material. The green is not even close to a match (which I expected) but it’s paintable so that will be addressed down the road.
Re: 1968 Valiant 1st Gen HEMI Project [Re: Mike P] #3253085
08/22/24 11:49 AM
08/22/24 11:49 AM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
Now I had to do something with the fill pipe. The factory fill pipe has a piece of metal that runs from below the end of the pipe to almost the top of the pipe. When filling the tank this acts as an internal vent so when the tank is full and fuel runs up the bottom side of the pipe (and hopefully shuts off the pump). The part above the divider vents and allows the gas in the lower half of the pipe to go back down into the tank instead of spitting out on to the side of the car and person filling the tank.
[Linked Image]Z PV by M Patterson, on Flickr
When I modified the pipe I lost that feature. Fortunately I’ve been thru this before and knew a fix was to run a ½” fuel line from the top of the tank (slightly above the end of the fill pipe in the gas tank) to the top of the fill pipe (the same system some of the old Jeep Wagoneers’ used).
Putting a fitting for the ½” fuel line in the tank was pretty straight forward as where I located it was a flat area. I used copper washers on either side of the fittings to seal it. Because the fill pipe goes in at an angle the fitting is above the pipe’s end.
[Linked Image]Z TV by M Patterson, on Flickr
In order to get the fitting at the top of the fill pipe to seal I needed a flat spot in the pipe. After the hole for the fitting was drilled I used a ¼” thick washer/spacer I had laying around on the inside of the pipe, ran a bolt thru it and used another odds and ends piece with a flat surface I had in the drawer, tightening the bolt gave me the flat spot I needed for the washers to seal.
[Linked Image]Z TV2 by M Patterson, on Flickr
If I still had access to a pipe bender I probably would have just bent up a new metal fill pipe but fuel fill hose for a 97-80 Ford F150 gave me the bends I needed to mate the filler neck to the fill pipe (though it had to be extended a bit). With a little tweaking I was also able to also use the original tank vent. It’s not beautiful but then neither was the stock fill pipe and it is functional.
[Linked Image]Z FF by M Patterson, on Flickr
I like having a set of tools with me so a tool box was added to the trunk where the battery used to sit. I don’t like a tool box that slides around all over the trunk so I used a pair of Jeep hood hold downs on each end to hold it in place. I like this setup as it allows me to easily move the tool box between my different vehicles.
[Linked Image]Z TB by M Patterson, on Flickr
I added a spare tire hold down for the spare that’s the same height as the rear tires. Basically it’s done but I’ll probably be adding a latch for the hatch cover to keep it from rattling, but that’s a project for another day.
[Linked Image]Z ST by M Patterson, on Flickr
When all was said and done I have a functional trunk and new gas tank. Overall I’m happy with the way the trunk turned out (I’ll be happier when it’s all painted body color).
Re: 1968 Valiant 1st Gen HEMI Project [Re: Mike P] #3253707
08/25/24 02:28 PM
08/25/24 02:28 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Looks good! I like the way you handled the tank issue and the toolbox idea is just simply cool. up
popcorn
John
Re: 1968 Valiant 1st Gen HEMI Project [Re: SattyNoCar] #3254087
08/27/24 01:06 PM
08/27/24 01:06 PM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
With the trunk taken care of my Grandson and I started on the Heater/AC install. Heat and AC are mandatory for this build and of course the Valiant had neither. After looking at various options I eventually settled on piecing together a system for the car. I already have a new Sanden 508 compressor installed on the HEMI so that part’s taken care of. I found a behind/under-dash heat/AC unit on E Bay that looked like it would work so I picked that up.
[Linked Image]z ac by M Patterson, on Flickr
It took a bit of looking but I eventually found a set of under dash vents I liked (hardest part was finding ones that were set up for 2” ducting). The Y connectors will be installed in the ducting to the outer dash vents to divert the air to floor air when the heater is used. In order to keep things simple, the Y connectors and in-line water control valve will all be cable operated.
[Linked Image]Z Vents by M Patterson, on Flickr
We got the evaporator/heater unit mounted up under the dash Sunday. I’m really pleased with the way it tucks up under the dash.
[Linked Image]Z EVAP by M Patterson, on Flickr
And I got the under dash vents installed (I’ll run the ducting later this week). I could probably make the factory controls function with this, but I’m taking the easy way out and will just build a custom control panel and use the switches provided.
[Linked Image]Z V by M Patterson, on Flickr
I’m still figuring out which way to go on AC hoses and still have to pick a condenser and receiver dryer but we’ll get to that in time.
Re: 1968 Valiant 1st Gen HEMI Project [Re: Mike P] #3255046
09/01/24 08:20 AM
09/01/24 08:20 AM
tboomer Online content
tboomer  Online Content
Nice work! That is coming along nicely!! up
Re: 1968 Valiant 1st Gen HEMI Project [Re: tboomer] #3256738
09/09/24 10:13 AM
09/09/24 10:13 AM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
Thanks.
I’ve been working on the EPAS electric power steering. I had purchased their A Body unit a few months ago and the instructions and You Tube video for modifying the steering column and installing the unit seemed pretty straight forward. Also informative were a couple of the threads on the forums from guys who have used EPAS in their cars.
It was one of the threads on another site that I found out that in addition to the A Body Kit, EPAS also sells a kit for “Dodge Demon/Duster”. The “Demon/Duster kit” is actually the one needed for the 67 up cars. As far as components go the only parts difference between the 2 kits appears to be the floor bearing retainer which is triangular shaped on the A Body kit (which also includes an aluminum floor plate that is not used on the 67 and up cars) and diamond shaped on the Demon/Duster kit (which makes it easier to attach to the existing floor plate). The instructions (from the EPAS site on the internet) for the measurements on where to cut the column and shaft are also different.
[Linked Image]Z EPAS 1 by M Patterson, on Flickr
I had ordered my EPAS unit thru Summit, but rather than going thru their tech line when I had questions I looked up EPASs number and talked directly to their tech section. I can’t say enough good about EPASs tech support. I called them a couple of times when I was putting the system together. They were quick returning my calls, knowledgeable about questions I had and very helpful. When we determined I needed a different bearing retainer plate they sent it out immediately and I received it in 1 day.
One of the most helpful tips they gave me was that instead of using the supplied measurements for cutting the column that it might be better to reinstall the column and then set the EPAS unit up next to it to determine exactly where it would best index in my specific car and I’m glad I took their advice as my measurements for cutting the column and shaft ended up being slightly different than those recommended in in the instructions.
I was warned on one of the sites I would run into interference issues with the steering and exhaust using a First Gen Hemi in the 68 and he was right. When we went thru mockup on the parts car we were able to clear the steering box using 56 manifolds but the steering shaft to the manifold was really close……close enough that I was looking at possibly having to build a 2 piece steering shaft with U joints at the firewall to clear the manifold.
The EPAS A body and “Dodge Demon/Duster” kits are designed to run a single straight shaft from the power steering motor down to the steering box. If I had been doing a Small Block, Big Block, and probably even a second or third generation HEMI the installation would have been as straight forward as the instructions and videos depict.
I however am the idiot who’s bound and determined to use a first Gen Hemi. When we were test fitting the PS motor/column I noticed a couple of things. The floor plate that bolts to the firewall and supports the end of the original column (and is used to mount the EPAS floor bearing) has oversized holes punched into it. These were probably used to shift the plate as necessary for shaft alignment as the car went down the assembly line. By shifting the plate all the way to the left and even elongating the holes if necessary I can gain the clearance I need for the steering shaft to manifold clearance. Talking to the tech section at EPAS we determined I could use a U joint off the end of motor instead of the straight coupler (shown in the picture) and move where the shaft comes thru the fire wall for added clearance. The shaft coming thru the firewall will be cut off just past the fire wall, then a second shaft with U joints on each end will be used to connect the shaft from the motor to the steering box.
After a lot of measuring and test fitting I had the column modified and the PS motor attached.
[Linked Image]Z SC by M Patterson, on Flickr
Will I wish I’d put a new turn signal switch when I assembled it…..probably…. but the old one worked so we’ll see how long it lasts.
We got the column and motor installed yesterday, along with its control box. It’s hard to get a good picture of it, but I’m really happy with how it fits in the car.
[Linked Image]Z SCI by M Patterson, on Flickr
I’m waiting on the U-Joint for the end of the PS motor before I can finalize the shaft thru the firewall part of the project and I still need to get the wiring done including extending the wires on the rheostat so it will mount to the dash where I want it but the hardest part of the project is done.
