Re: 71 Cuda Paint Job Project
[Re: modelmakerinc]
#3276430
12/16/24 07:22 AM
12/16/24 07:22 AM
Posts: 2,441 west palm beach, florida
modelmakerinc
Moved to the pass side and tore into lower A-pillar. Found a little rot, much more solid than drivers side. CUT, BLAST,FAB,PREP,WELD,GRIND,SAND, DONE, NEXT....
[Re: modelmakerinc]
#3280888
01/06/25 10:30 AM
01/06/25 10:30 AM
modelmakerinc
The lower front inner corner looked like gobs of bubble gum  when i stripped the paint off. The door skin has a bunch of high spots (dings) made from inside, and plenty of areas that will need attention.
[Re: modelmakerinc]
#3280897
01/06/25 10:52 AM
01/06/25 10:52 AM
modelmakerinc
Then I find the next surprise.  not really too bad, I will cut out some of the inner structure to access the backside of these areas and repair accordingly. The structure will be welded back into position. I am getting excited to move into the body work phase to really get a good look at a fresh straight and proper base for painting.
