Re: 383 headed to the dyno 8/22
[Re: gregsdart]
#3253137
08/22/24 02:00 PM
08/22/24 02:00 PM
Posts: 10,167 MN
JERICOGTX
MN
Well, if we were playing a game of “The Horsepower is Right”, no one would have went over. Some engines are just over achievers, and this just happens to be one of them. I’m sure many will doubt the numbers, but here are the numbers:
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3253138
08/22/24 02:09 PM
08/22/24 02:09 PM
Posts: 1,488 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Got fuel flow data, atmospheric conditions, and correction factors to go w/ that?
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: JERICOGTX]
#3253154
08/22/24 05:38 PM
08/22/24 05:38 PM
Posts: 2,689 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I have no doubt about those numbers because they relate to the numbers I got on a similar combination but with the larger bore 400 block = 470" . 10.73 comp I am not sure how much our cams differ ? Mine is a Comp Cams 282s . Edelbrock heads and rpm intake , Comp rockers 440 source 3.91 rotating assy Ross pistons. https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2396623/1.htmlCongrats ! That will be fun for sure ! Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: JERICOGTX]
#3253159
08/22/24 05:54 PM
08/22/24 05:54 PM
Posts: 10,215 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Boy was i off the mark. Congrats Jeff on the great outcome! Looking back, inch for inch it matches a 408 smallblock stroker i built, but has real strong torque down low, where it will feal great with street gears!
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: ksj]
#3253186
08/22/24 07:51 PM
08/22/24 07:51 PM
Posts: 6,089 Star Idaho
67vertman
Star Idaho
That motor gets with it. Great numbers. Now get it in the car and post some times.
My Monster are real!
Living within your means makes life pretty easy.
[Re: AndyF]
#3253256
08/23/24 05:09 AM
08/23/24 05:09 AM
Posts: 10,167 MN
JERICOGTX
MN
I said 560 so I was close on the torque. I didn't think that cam would make more than 500 hp but the TF heads flow very well at low lifts so they actually work better with a small cam than they do with big cams. These are Edelbrock Performer RPM heads, that have only had a good valve job done on them. Still the original valve springs they were shipped with 20 years ago.
69 GTX
68 Road Runner
[Re: 67vertman]
#3253258
08/23/24 05:10 AM
08/23/24 05:10 AM
Posts: 10,167 MN
JERICOGTX
MN
That motor gets with it. Great numbers. Now get it in the car and post some times. Street car. It will never go to the track. I have a race car for that.
69 GTX
68 Road Runner
[Re: dvw]
#3253259
08/23/24 05:17 AM
08/23/24 05:17 AM
Posts: 10,167 MN
JERICOGTX
MN
That'll put smile your Dads face. Doug Oh he was smiling! Pretty sure the look on his face after the second pull, was a mix of happy, proud, and what the h#ll have I gotten into? A few things to take note on the dyno session: We used the dyno headers instead of the 1 7/8" TTi headers that will go into the car. There was also an air bell used instead of the factory air cleaner going on it, in the car. No drag of the water pump, fan combo is in use either. How much power does all that use up? Plenty, but we do not care. The engine runs great, and drivability will not be an issue. Would a different cam produce better results? Of course, but at what cost? My Dad is 73 years old, and just wants to drive his car again.
69 GTX
68 Road Runner
[Re: HardcoreB]
#3253276
08/23/24 06:29 AM
08/23/24 06:29 AM
Posts: 8,280 Plymouth, MI
Blusmbl
Plymouth, MI
Awesome results. Even with the accessories hooked up it'll still be well over 500 hp and be a riot with the 4 speed. That'll definitely put a smile on his face!
[Re: Brad_Haak]
#3253301
08/23/24 09:17 AM
08/23/24 09:17 AM
Posts: 10,167 MN
JERICOGTX
MN
Got fuel flow data, atmospheric conditions, and correction factors to go w/ that? Here is a screen shot from yesterday during the pull.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3253715
08/25/24 02:46 PM
08/25/24 02:46 PM
Posts: 18,085 S.E. Michigan
ZIPPY
S.E. Michigan
Nice! This engine has got to be the 484 purple shaft poster child. . He is going to love that
Rich H.
Esse Quam Videri
[Re: JERICOGTX]
#3253747
08/25/24 06:50 PM
08/25/24 06:50 PM
Posts: 10,167 MN
JERICOGTX
MN
Almost ready to drop into the car again.
69 GTX
68 Road Runner
[Re: Cab_Burge]
#3253814
08/26/24 08:22 AM
08/26/24 08:22 AM
Posts: 9,958 Weddington, N.C.
Streetwize
Weddington, N.C.
That's pretty incredible power! And what really stands out to me is how well the V.E. Must be working through the middle of the power curve.
Motors that build torque Early almost seem like they have almost a "slingshot" effect on the dyno where they make more HP at peak than you think they really should. I think it might have something to do with achieving near optimum port velocity at the brake low setpoint RPM and carrying that momentum through the RPM range of the sweep...as opposed to having to build velocity through a larger port against the brake.
Almost the same way a looser converter can accelerate the car harder with no increase in power output.
It also tells me the roll-on torque will be amazing.
What is the @ .050 Duration of the 484? like 234?
Quick question though....the Dyno Screen is at 5249RPM...almost right exactly right at the 5252 'crossover" where the HP and Torque should be the same reading? But it's showing 469TQ/526HP?
