Re: New personal best, but broken front end
[Re: 71Demon528]
#3255925
09/05/24 10:27 AM
09/05/24 10:27 AM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
My 572 hemi has a 276/284 at fifty cam and I shift at 6800.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: 71Demon528]
#3255938
09/05/24 11:16 AM
09/05/24 11:16 AM
Posts: 8,067 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Sure will. Its been a learning curve on this Hemi stuff. Originally planned on external oiling, but with all the complaints on loosing prime, i would rather use internal with the 1/2 pick up. BME says it will work, but i am yet to get the pick up tube and see for myself. Any of you with 4.5 stroke use internal oiling?
[Re: an8sec70cuda]
#3256087
09/05/24 11:10 PM
09/05/24 11:10 PM
Posts: 442 montana
BANDIT
montana
The 572 in my Arrow supposedly has this cam in it. Any suggestions on shift points? Have been shifting it at 6800, also, runs thu lights at about 6900. The DA at Acton track hangs around 6900 ft. Likes timing up at 39 degrees. Car wieghs 2600 lbs with me in it. Ran a 5.68 @122 in 1/8 last weekend. Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 1980 Plymouth Arrow 572 Hemi. 242" Mullis Dragster. 6.90@ 200mph
[Re: BANDIT]
#3256118
09/06/24 07:36 AM
09/06/24 07:36 AM
Posts: 193 Connellsville
71Demon528
Connellsville
The 572 in my Arrow supposedly has this cam in it. Any suggestions on shift points? Have been shifting it at 6800, also, runs thu lights at about 6900. The DA at Acton track hangs around 6900 ft. Likes timing up at 39 degrees. Car wieghs 2600 lbs with me in it. Ran a 5.68 @122 in 1/8 last weekend. Jim. with that ET and Speed I’d say the combo is pretty good. Personally I’d just increase shift rpm 100 at a time til it slowed down. What compression do you have? Intake? Heads? Carb? Does your Arrow have a glide or a 3 speed? What converter? I’d say 7,000 would be my starting point but hey if it doesn’t like it, it doesn’t like it. If it’s a bracket car and it is consistent, why mess with it? Especially with a Hemi, if it likes lower RPM, it’s only going to make it live longer. When the 540 was built we were hoping to shift it at 7,000. Quickly we realized that wasn’t going to happen and 7,500-7,700 it was. When the 572 was built we hoped the engine speed would come down a little bit, also didn’t happen lol. In fact the 572 seems to like more RPM than the 540. But in fairness we never got the 540 totally sorted out before it failed. I know our cam is on a 112 LSA installed around I believe 108-109, can’t remember. But I know the 112 LSA is also attributing to its love for RPM.
[Re: 71Demon528]
#3256695
09/08/24 10:54 PM
09/08/24 10:54 PM
Posts: 442 montana
BANDIT
montana
Motor has a single 4 intake, I believe its a Stage V. Heads are Stage V, from around 2003 or 2004 era. Supposedly it has 13 to 1 compression. 1250 dominator. TCI converter, feels like stall is around 5000 rpm. Its a ladder bar car with 4.10's and a T/flite. 15-33 Goodyears. Have tried launching car from 5400 rpm down to 3500 currently. It usually runs the best at 3500 launch rpm. Last pass it dead hooked and yanked wheels straight up about 4-5 ft and red lit me big time. Appears it 60 footed off back tires. Always comes down smooth and easy. Gonna try moving ladder bars and possibly a lower launch rpm. I want to try the 7000rpm shift, just ran out time. It has been going thru traps around 6800 to 6900 rpm. Jim
[Re: BANDIT]
#3256721
09/09/24 07:37 AM
09/09/24 07:37 AM
71Demon528
Connellsville
Motor has a single 4 intake, I believe its a Stage V. Heads are Stage V, from around 2003 or 2004 era. Supposedly it has 13 to 1 compression. 1250 dominator. TCI converter, feels like stall is around 5000 rpm. Its a ladder bar car with 4.10's and a T/flite. 15-33 Goodyears. Have tried launching car from 5400 rpm down to 3500 currently. It usually runs the best at 3500 launch rpm. Last pass it dead hooked and yanked wheels straight up about 4-5 ft and red lit me big time. Appears it 60 footed off back tires. Always comes down smooth and easy. Gonna try moving ladder bars and possibly a lower launch rpm. I want to try the 7000rpm shift, just ran out time. It has been going thru traps around 6800 to 6900 rpm. Jim Jim it sounds like how our cars are on the 1/8 mile as far as trap speed usually within 100-200 of shift rpm. Car sounds fun and is fast. You’ll have to let me know when you try out the higher shift if it likes it or not. My bet is it will. I’d be curious to see a GoPro video from in the car with focus on the tach to see what the converter flashes/stalls at on the launch and the fallback rpm on the shift. But I’d say with the cars ET and MPH it’s a good setup.
