Re: Pedal gasket ??
[Re: Stanton]
#3248349
07/30/24 09:07 AM
07/30/24 09:07 AM
Posts: 75,271 A gulag near you.
JohnRR
A gulag near you.
The gasket would only be useful between the plate and the firewall .
Mainstream Media is the new Pravda
Re: Pedal gasket ??
[Re: gtx6970]
#3248565
07/31/24 10:00 AM
07/31/24 10:00 AM
Posts: 302 Hinckley, Ohio
KWF340
Hinckley, Ohio
order is Big gasket on first,' then plate. then small gasket to seal master cyl to plate. then master cyl I'm at this stage with my road runner. I've read that for manual brake B bodies a gasket was placed between the plate and the firewall but not between the master cylinder and the plate. Can anyone verify if this is correct?
1968 Charger R/T, 440, Auto, GG1; 1969 Super Bee, 383, 4-speed, T5; 1969.5 Road Runner, 440-6, 4-speed, 96; 1970 Duster 340, 4-speed, EV2; 1970 Charger R/T SE, 440 (496), Auto, EB3; 1970 Dart Swinger 340 (416), 4-speed, EV2; 1966 Corvette convertible, L79, 4-speed, Red 1970 Corvette coupe, LS5, 4-speed, Daytona yellow; 2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
Re: Pedal gasket ??
[Re: KWF340]
#3248633
07/31/24 03:00 PM
07/31/24 03:00 PM
Posts: 2,640 Nashville, TN
MOPARMIKE69
Nashville, TN
Yes that is correct. Big gasket between plate and body, small gasket between Master and plate.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
Re: Pedal gasket ??
[Re: Stanton]
#3248675
07/31/24 07:09 PM
07/31/24 07:09 PM
Posts: 9,020 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I'm at this stage with my road runner. Are you assembling a bare shell? Do you have a copy of Rick Kreuziger's assembly sequence ??
Re: Pedal gasket ??
[Re: Stanton]
#3248740
08/01/24 08:28 AM
08/01/24 08:28 AM
Posts: 66 Michigan
mopar4don
I'm at this stage with my road runner. Are you assembling a bare shell? Do you have a copy of Rick Kreuziger's assembly sequence ?? Where can I get this assembly sequence ??
Re: Pedal gasket ??
[Re: mopar4don]
#3248745
08/01/24 09:25 AM
08/01/24 09:25 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Where can I get this assembly sequence ?? Send me a PM with your email address
Re: Pedal gasket ??
[Re: Stanton]
#3248934
08/02/24 08:26 AM
08/02/24 08:26 AM
KWF340
Hinckley, Ohio
I'm at this stage with my road runner. Are you assembling a bare shell? Do you have a copy of Rick Kreuziger's assembly sequence ?? Yes, bare shell. I followed the sequence somewhat - I had to jump around depending on what parts I had ready to go. Saw this Link (post 2) and held off on installing the gasket until I could confirm if one should go between the master cylinder (manual brake car) and plate.
