Re: Harland Sharp BB rocker shafts question [Re: Stanton] #3250106
08/07/24 06:04 PM
08/07/24 06:04 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
The RAS shafts I use with my Hughes rockers also have upper and lower oiling holes, but I have never noticed a low-RPM oil pressure issue. Never used any restrictors with the previous Stage VI heads, but have .090-ish restrictors with the current Victors because the oil feed passages of the Victors are bleepin' huge.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Harland Sharp BB rocker shafts question [Re: Brad_Haak] #3250199
08/08/24 12:09 PM
08/08/24 12:09 PM
GA
roadrunninMark Offline
GA
I agree the people at Harland Sharp are top notch. I had a set of rockers I was going to sell. I bought Indy heads so I needed a different set of rocker arms. Since they are an expensive item, I wanted to make sure my set was fine as two of the rockers had some wear on the bodies. I didn't want someone to put them on their engine and have a rocker ruin it. I called H.S. and sent them a picture. They said they should be fine but if you want to definitely make sure they are good, to send them for an inspection. I mailed them in and they inspected them for free. They told me they are fine to run. They then shrink wrapped them in plastic and sent them back at their own expense! I couldn't have been happier from their customer service.
If you contact them, I am sure they will be able to answer your questions and figure out what you need to do to get the oil pressure to where it is supposed to be.
Re: Harland Sharp BB rocker shafts question [Re: roadrunninMark] #3250250
08/08/24 03:20 PM
08/08/24 03:20 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Quote
Which Indy heads ??
