Re: Neutral Safety Switch issues??
[Re: MI_Custumz]
#3249201
08/03/24 11:16 AM
08/03/24 11:16 AM
Posts: 20,326 Park Forest, IL
slantzilla
Park Forest, IL
Like poorboy said, is the shift linkage good and in adjustment? I have a Buick that sometimes doesn't start in Park, but will if you pull the shifter further up. It will also start if you play around with the shifter in neutral.
[Re: slantzilla]
#3249238
08/03/24 02:13 PM
08/03/24 02:13 PM
Posts: 26,462 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Like poorboy said, is the shift linkage good and in adjustment? I have a Buick that sometimes doesn't start in Park, but will if you pull the shifter further up. It will also start if you play around with the shifter in neutral. Two possibilities, the plastic bushings in the shift linkage are worn/missing and the remote possibility that the shift shaft has come loose in the rooster comb which will result in lost motion.
[Re: John_Kunkel]
#3249368
08/04/24 12:22 AM
08/04/24 12:22 AM
Posts: 15,827 Omaha Ne
TJP
Omaha Ne
Like poorboy said, is the shift linkage good and in adjustment? I have a Buick that sometimes doesn't start in Park, but will if you pull the shifter further up. It will also start if you play around with the shifter in neutral. Two possibilities, the plastic bushings in the shift linkage are worn/missing and the remote possibility that the shift shaft has come loose in the rooster comb which will result in lost motion. it's a Monte carlo John
[Re: MI_Custumz]
#3249401
08/04/24 09:01 AM
08/04/24 09:01 AM
Posts: 6,224 ohio
ruderunner
ohio
So just to clarify a couple things
The NSS is on the shifter in this application?
Your intermittent no crank still happened with the NSS bypassed?
Does this only happen hot? Or will it happen on first starts too?
This really sounds like typical GM solenoid failure, but iirc you've already replaced it.
I'd make a high draw test light (generic turn signal socket and 1157 bulb with long leads and alligator clips) and put the bulb where you can see it. Test for power at the solenoid and work your way back to the ignition switch. The semi permanent installation will be present when the problem occurs, not hours later after a tow call. Sometimes with intermittent problems you have to do things like this.
Angry white pureblood male
[Re: TJP]
#3249466
08/04/24 03:32 PM
08/04/24 03:32 PM
John_Kunkel
Rio Linda, CA
Like poorboy said, is the shift linkage good and in adjustment? I have a Buick that sometimes doesn't start in Park, but will if you pull the shifter further up. It will also start if you play around with the shifter in neutral. Two possibilities, the plastic bushings in the shift linkage are worn/missing and the remote possibility that the shift shaft has come loose in the rooster comb which will result in lost motion. it's a Monte carlo John OOPS.
[Re: ruderunner]
#3249546
08/05/24 06:27 AM
08/05/24 06:27 AM
Posts: 5,738 Port Huron, Michigan
MI_Custumz
I'd make a high draw test light (generic turn signal socket and 1157 bulb with long leads and alligator clips) and put the bulb where you can see it. Test for power at the solenoid and work your way back to the ignition switch. The semi permanent installation will be present when the problem occurs, not hours later after a tow call. Sometimes with intermittent problems you have to do things like this. Happens hot, cold, after storage, no rhyme or reason it seems like. I have not replaced the starter or solenoid, but have removed it to mount a new battery cable to it. Connections there all seem good by looks. I now live alone and sometimes getting someone to turn the key so I can get a multi meter or test light on it is hard because there aren't a lot of people in the neighborhood I can ask and they come right over. I never thought of a test socket set up. I get power to the NSS every time I test it. However, I don't think I tested it when it wouldn't crank. I will keep a test light in the car as a reminder to check that next time. The NSS is in the console on the shifter so I can get to that easily to test it. I appreciate the input and keeping it simple for me.
[Re: MI_Custumz]
#3249579
08/05/24 10:52 AM
08/05/24 10:52 AM
Posts: 20,230 north of coder
moparx
i have been bit very hard more than once by the "connections look good by the looks of them" bug, [you can visualize where] and it even hurts just to think about that ! not saying that is the problem, but just relaying my own [hurtful] life experiences. with that said, could the wires going to the starter have internal breaks or "green death" hidden somewhere in the insulation that can't be seen ? those particular problems have got me more than a couple of times. just tossing stuff out there to look for. whatever you find, please let us know.
[Re: MI_Custumz]
#3249608
08/05/24 12:47 PM
08/05/24 12:47 PM
Posts: 6,224 ohio
ruderunner
ohio
Negative on just keeping it in the car. It needs to be hooked up full time.
By the time you gather things together the symptom might disappear.
Solenoids are a well known weakness on the older GM starters
[Re: MI_Custumz]
#3249618
08/05/24 02:03 PM
08/05/24 02:03 PM
Posts: 10,835 Freeport IL USA
poorboy
Freeport IL USA
I'd make a high draw test light (generic turn signal socket and 1157 bulb with long leads and alligator clips) and put the bulb where you can see it. Test for power at the solenoid and work your way back to the ignition switch. The semi permanent installation will be present when the problem occurs, not hours later after a tow call. Sometimes with intermittent problems you have to do things like this. Happens hot, cold, after storage, no rhyme or reason it seems like. I have not replaced the starter or solenoid, but have removed it to mount a new battery cable to it. Connections there all seem good by looks. I now live alone and sometimes getting someone to turn the key so I can get a multi meter or test light on it is hard because there aren't a lot of people in the neighborhood I can ask and they come right over. I never thought of a test socket set up. I get power to the NSS every time I test it. However, I don't think I tested it when it wouldn't crank. I will keep a test light in the car as a reminder to check that next time. The NSS is in the console on the shifter so I can get to that easily to test it. I appreciate the input and keeping it simple for me. This sure makes it sound a lot like the solenoid on the starter is dying. Years ago, you could buy replacement solenoids pretty cheap and they were not hard to change. If that starter has been on the car for many years, and a replacement solenoid is still available, I believe I would just go ahead ans replace the solenoid on the starter.
[Re: poorboy]
#3249628
08/05/24 02:25 PM
08/05/24 02:25 PM
Posts: 1,892 South Bend
John Brown
South Bend
One more thing to add to the mix, GM starter solenoids get their ground flow through the starter brushes. Bad brushes lead to problems getting the solenoid to kick in.
[Re: MI_Custumz]
#3249687
08/05/24 07:45 PM
08/05/24 07:45 PM
Posts: 6,224 ohio
ruderunner
ohio
I like using the socket and 1157 bulb for a test light since it puts more load on the wiring than a traditional test light.
Weak wiring might have no problem lighting a regular test light, but the bigger setup will expose weakness.
Diagnosis costs time. Firing the parts cannon costs money.
[Re: stumpy]
#3249745
08/06/24 06:13 AM
08/06/24 06:13 AM
MI_Custumz
To help eliminate the starter and solenoid jump the NSS plugs. That will allow it to start in any gear. If it works then the starter is ok and the problem will lie in the NSS or linkage adjustment. You could also hold the key in the start position and move the shifter between park and neutral. If it tries to start then you have a linkage adjustment issue. I had a jumper wire on the NSS and it worked for a while and then it didn't. I am going to do the test light socket idea next. I believe the issue is from the wire from the NSS to the bulkhead or bulkhead to the starter or possibly the Solenoid. The wire from the fuse box to a momentary button then to the solenoid was working when I needed it, but that stopped as well. I replaced the button as it was an easy cheap fix. The old button wasn't testing continuity like it should. The button/wire set up was there when I bought the car.
