Gas Tank Swap
#32472
12/02/06 02:17 AM
12/02/06 02:17 AM
Just wondering if anyone has swapped a ramcharger gas tank into a truck? I'm woring on my '85 shortbed...getting ready to swap on a warlock step side and am wanting to put a the rear mount tank in the truck like whats in the ramcharger. That way I could have the exhasut wxit in front of the rear wheels and modify the fuel door into the bed of the truck. If anyone has done this before and has any advice, I would greatly appreciate it. Thanks
Re: Gas Tank Swap
[Re: TooMany62s]
#32475
12/06/06 12:26 PM
12/06/06 12:26 PM
Where did you run the filler neck to the fuel cell? I was wanting to mount mine on the floor of the bed, but wasn't thinking that the rc fuel tank still has a side mounted filler neck...
Re: Gas Tank Swap
[Re: TooMany62s]
#32481
12/08/06 05:49 PM
12/08/06 05:49 PM
Posts: 188 South Central WI.
77BBPW
South Central WI.
The big tank is 36 gallons. There is a smaller one, it is 24 gallons, but I have only seen the larger tanks.
Re: Gas Tank Swap
[Re: Mr_fixit]
#32483
12/09/06 01:44 AM
12/09/06 01:44 AM
Posts: 1,295 Hawley, Texas
shinnery
super street
super street
Hawley, Texas
FYI The fullsize Van tanks are quite similar to the RamCharger or may be the same, when you are looking thru a junkyard. My 72 B300 Maxiwagon had a 24 gal metal tank IIRC. Been gone about 22 years. Bryce
Every electronic device is manufactured with smoke stored deep inside...
only a true genius can find a way to set it free.
The most terrifying words in the English language are: "I'm from the government and I am here to help!"
