Re: 900+HP squirters/check everything [Re: fbs63] #3248765
08/01/24 09:49 AM
08/01/24 09:49 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Originally Posted by fbs63
Wonder if the "Umbrella" style of them causes a low pressure area to draw additional fuel?
If it does, I was thinking a bit of "Dremel Time!" to sawzall down the non-essential parts of the extended skirts would help offset that issue
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: 900+HP squirters/check everything [Re: Brad_Haak] #3248771
08/01/24 10:05 AM
08/01/24 10:05 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Yes, the .028 would come in a bit later. Dom has found some interesting stuff on emulsion placement as well. That guy really knows his way around a carburetor.
Re: 900+HP squirters/check everything [Re: racerx] #3249574
08/05/24 09:17 AM
08/05/24 09:17 AM
Shelby Twp. Mi
HardcoreB Offline OP
Shelby Twp. Mi
I didn't get any pics but Brad has the same posted here. I simply ordered '35' squirters and this is what was sent. Not sure the change made any significant difference because I tried the tbrake.
Re: 900+HP squirters/check everything [Re: dvw] #3249575
08/05/24 09:21 AM
08/05/24 09:21 AM
Shelby Twp. Mi
Shelby Twp. Mi
Originally Posted by dvw
My thought is if it has pull over you deal with it...
Doug
This is correct, just tune with what you can. Again for everyone, I didn't order these unique squirters for any issue other than a lean-bog.
