Re: Thinking of getting out....
[Re: jcc]
#3246510
07/22/24 11:17 AM
07/22/24 11:17 AM
Posts: 4,754 On the parachute mount
n20mstr
one thing i have learned, the faster you go, the more work you have to do on the car.
This hobby is not for everyone, and yes it is a lot fo work and always seems to be a lot of money also.
IF you really want to keep racing, maybe slow your car down, or just deal with it or quit.
I have spent more money that i ever have in the last 2 years ....is it worth it to me?? YES
Whatever you decide, its what makes you happy.
It does make it easier that i do almost all my work, and paint and body are what i do
....BAD A$$ STREET CAR.....
[Re: jcc]
#3246522
07/22/24 11:41 AM
07/22/24 11:41 AM
Posts: 18,038 S.E. Michigan
ZIPPY
S.E. Michigan
Well, everyone is different. Come back when you're ready.
"Sustainability of the activity" can be hard to figure out, and what works for awhile can suddenly fall apart later and turn impossible.
Good luck with whatever you decide.
I do as much as I can myself, but I don't demand it be done yesterday or to a level of absolute perfection in every detail. "Really good" is the overall level I enjoy being at the most. I'm not there anymore, but I used to be there back when I drove my '68 Charger everyday. "Seriousness of the Effort" is another variable that sometimes requires an ego vs. time vs. money check to get things aligned.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3246525
07/22/24 12:13 PM
07/22/24 12:13 PM
Posts: 5,035 new jersey usa
11secdart
new jersey usa
Yep.. what Tony said , thats why I slow my car down from 10.70s to 11.50s .. leave at 2,000 shift at 6500 easier on parts and $$$ and much more competitive for the classes I run. I am making just about as much hp ( 4 hp less ) with my 9.5 to 1 pump gas 410 inch small block and 70 more lbs of torque than I did with my race gas 11.5 to 1 motor. I used to run a faster class and chase E.T.s always looking to go faster , I had another 408 inch small block that wasn't reliable and eventually cracked the crank and kept breaking rockers rather than spend the money to fix it I sold it as is for a good price, With a roller cam , good rockers and more compression it had the potential to run in the nines . Based on my finances it wasn't feasible to do , just fixing it was going to be several grand. My operation still wasn't cheap but its with in my financial means and I get enjoyment and round wins out of it . In my case going slower is just as much fun.
[Re: n20mstr]
#3246618
07/22/24 06:35 PM
07/22/24 06:35 PM
Posts: 8,234 Plymouth, MI
Blusmbl
Plymouth, MI
one thing i have learned, the faster you go, the more work you have to do on the car. I haven't owned anything actually fast but a bunch of my friends have, and I've asked all of them if they had to do it over again where they would stop on the enjoyment/price/pain in the butt scale, and most of them had the same answer - somewhere in the 10's/9's depending on the motor and how much the car weighed. Beyond that for typical street strip stuff, especially n/a or nitrous, it seems the maintenance starts going up dramatically and it also gets exponentially more expensive to go faster. About the only exceptions now are some of the 8.50-ish turbo LS's in generic wrappers like Mustangs, they seem to be relatively low maintenance and still are decent on the street. One of my friends has owned a couple outlaw 632/LDR style cars that were competitive in our local heads up series. He has to have 3x the total investment in his current car and it's only 3-4 tenths quicker in the 8th. But if you're aiming for the top of a heads up class, there isn't any way to do it besides spending money. The other thing that helps is focusing on one car. Just the thought of 2 race cars and building a 3rd sounds like a recipe for burnout, and it's hard with limited time/resources to give all of them the attention they deserve. They never hurt getting pushed in the corner though, they'll always be waiting for you if the motivation comes back!
[Re: GomangoCuda]
#3246663
07/22/24 10:36 PM
07/22/24 10:36 PM
Posts: 2,543 PA
moparacer
PA
Bad year for me too.
First outing of year, car was on rails. Won. I remember thinking "man this might be a pretty good year!
The the rain started, didn't run for a month, then first race after the monsoon season I have an electrical problem. Didn't make first round.
Then more rain.....
Then Memorial Day weekend my $350 starter decides to let me hanging in the Semi's of Sunday race......
Then a few weeks later I try to make a quick 16 field. 2 passes and didn't qualify. $150 travel and entry for 2 passes.
Then too hot to race. 100 Degrees....Um not anymore.
Then next race when it cooled down to a comfortable 95 degrees and track finally got hot I developed a spinning problem.
Buy a new set of slicks for $800. freaking 3 inches larger than the marked rollout. Car slows down.....
Then 4th of July weekend towing home I lose the lockup in my 48re transmission.
Still on lift with trans scattered all over garage. $800 converter, $700 rebuild kit, $800 input shaft, $200 stator tube, and $300 worth of sensors and fluid.
Might get the truck fixed this week and not even try to go to the races for awhile lol.
But knowing my stubborn *ss I won't quit!
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3246686
07/23/24 01:11 AM
07/23/24 01:11 AM
Posts: 6,409 Heaven
EvilB1Dart
Heaven
Dragula,
Definitely some solid advice or feedback in this thread. Your dilemma is almost identical to a friend of mine’s. He is juggling two different cars, and trying to make both into fast street/strip cars. He is quickly growing tired of the endless expenses and frustration associated with owning two cars. His real issue is he gets in a hurry, makes mistakes that cost him time, and money resulting in constant do-overs. I told him to make one a dedicated race car and make changes to the other to make it a mild pump gas street car and never take it back to the track LOL. I believe he is finally going to make some changes so it’ll be interesting to see what happens. Good luck with your decision.
"Any fool can know. The point is to understand"
- A. Einstein
[Re: moparacer]
#3246711
07/23/24 07:17 AM
07/23/24 07:17 AM
Posts: 1,784 Keymar, MD
DusterKid
Keymar, MD
Then more rain.....
Then next race when it cooled down to a comfortable 95 degrees and track finally got hot I developed a spinning problem. I've heard several other's that have been having similar issues as of late. Not sure if they changed something with the prep or are over prepping, but be prepared to fight that issue. Also wonder why you weren't at the last Q16 race as it was STUPID hot and the bump was only a 6.23. I'm sure I'll see you at the next street race
[Re: DusterKid]
#3246721
07/23/24 08:32 AM
07/23/24 08:32 AM
Posts: 13,514 Marion, South Carolina [><]
an8sec70cuda
Like said before, you've had way more trouble w/ that hemi than anyone should have. No reason that engine should be having so many problems. Sounds like your biggest issue is where you live. There's a reason people are fleeing that area. Having more than one car just adds to the frustration when you're getting burnt out. I know it has w/ me...hence the reason I'm thinning the herd. I've gotten rid of 3 project cars in the past year. Still have one to go. Time means more than money, have to prioritize.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#3246726
07/23/24 08:56 AM
07/23/24 08:56 AM
11secdart
new jersey usa
Like moparracer I have had little things go wrong too .. second round of pro dial a month ago I am 003 on the tree to my opponents 030 shift second gear the car lays over.. my fuel pressure regulator went bad ( I tried to adjust it earlier and somehow managed to make it past first round ) to add to the pain I would have had the bye next round based on my r.t.. Over the winter I replaced my exhaust with a TTI "H" pipe after spending $400 for it and had the collector ends welded for a few more bucks.. I start hearing noises under the car , since my car sits so low the mufflers were hitting my driveshaft I had to replace last year after breaking one at another race. I was able to finagle the hangers temporarily to get them away from the driveshaft but they still hit a little.i have since had the muffler end of the pipe bent to move the mufflers further away seems to be ok now. its always something . but I keep going. About the only trouble free vehicle I race is my low 15 second D150 I put new drag radials on this year and its been deadly consistent , I have raced it about four times so far this year with zero problems , it actually has way more eliminator and round wins than the Dart and its Won two First place show trophies one at a Mopar show and another at a truck show recently...still not as fun as the Dart though!
[Re: Blusmbl]
#3246742
07/23/24 09:53 AM
07/23/24 09:53 AM
Posts: 1,347 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I had the same thought... too easy to get drawn & quartered by spreading yourself too thin across multiple vehicles to maintain.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3246782
07/23/24 12:18 PM
07/23/24 12:18 PM
Posts: 20,380 north of coder
moparx
being in my 70's and finally getting my charger back together and running, it makes me feel [kind'a] young again. however, being roughly two hours away from any track, and on a fixed income plus some health issues that make me pretty intolerable to heat, i'm considering a "dragy" device. that way, i could get out to a local stretch of semi-deserted/seldom used road, and make a pass or two occasionally. better than nothing, i guess.......
[Re: moparx]
#3246784
07/23/24 12:22 PM
07/23/24 12:22 PM
Posts: 19,575 Las Vegas
Al_Alguire
Las Vegas
Thin the herd and concentrate on one car. Keep the one that makes you the happiest sell the rest Its just stuff
[Re: an8sec70cuda]
#3246787
07/23/24 12:31 PM
07/23/24 12:31 PM
Posts: 12,481 Taxes & Virus's R-US, NY
Dragula
Like said before, you've had way more trouble w/ that hemi than anyone should have. No reason that engine should be having so many problems. Sounds like your biggest issue is where you live. There's a reason people are fleeing that area. Having more than one car just adds to the frustration when you're getting burnt out. I know it has w/ me...hence the reason I'm thinning the herd. I've gotten rid of 3 project cars in the past year. Still have one to go. Time means more than money, have to prioritize. You're not wrong....Lost a lot of time and money of the last couple of engines. Hopefully I learned somthing and the new one should run good and last..The wiring bit me and melted down under the hood and all needs replaced. The other thing that helps is focusing on one car. Just the thought of 2 race cars and building a 3rd sounds like a recipe for burnout, and it's hard with limited time/resources to give all of them the attention they deserve.
I had the same thought... too easy to get drawn & quartered by spreading yourself too thin across multiple vehicles to maintain. Yeah, I like the little collection I have....And it is very easy to get side tracked. I will just keep collecting parts and get everything together at a later date I guess.
[Re: 69dart]
#3246823
07/23/24 02:58 PM
07/23/24 02:58 PM
Dragula
Its supposed to be fun... if its not then take a break and try other stuff.
There are alot of things to do in life so do whatever makes you happy.
I've heard a smart fella mention that most folks start to lose interest in racing after about 15 years and only a few hang on for longer. Seems pretty accurate.
We have cut back this year - I simply dont enjoy racing when its 90 and miserable hot anymore. Well if 15 years is the preverbal limit for racing, I am way past that! Closer to 30 years I think....ouch!
[Re: 69dart]
#3246826
07/23/24 03:10 PM
07/23/24 03:10 PM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
We have cut back this year - I simply dont enjoy racing when its 90 and miserable hot anymore. This guy may be smart at some thing but that’s a stupid comment. I’m at 48 years and no guys with many more than I.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: pittsburghracer]
#3246834
07/23/24 04:11 PM
07/23/24 04:11 PM
Al_Alguire
Las Vegas
I ama firm believer in if something no longer brings you joy to let it go personally Clearly the cars are not doing it for you. But parking and ignoring them won't cost anything except possibly maintenance when you go back
