Re: E-body crush can
[Re: RTSE4ME]
#3137115
04/11/23 08:04 AM
04/11/23 08:04 AM
Posts: 12,382 Looking for a way out of Middl...
IMGTX
I replaced my crush can with a B Body tuff wheel adapter almost as soon as I got my car. Never regretted it. I could drive without the steering wheel in my face. I put a 4 spoke grant steering wheel on it instead of the tuff wheel. The smaller grant wheel put the rim of the wheel in front of the speedometer and tach though. I put a monster tach over the clock and who needs a speedometer right..lol On a side note the E body turn signal lever is long and has a heavy bend in it to put the lever near the wheel when used with the crush can. I swapped the turn signal lever to a B body lever which is perfect when using the tuff wheel adapter.
[Re: RTSE4ME]
#3137910
04/14/23 08:47 AM
04/14/23 08:47 AM
Posts: 3,301 West Coast, USA
jbc426
West Coast, USA
You can have someone cut out the amount you want and tig it back together. A little prep-work and paint and you will never see the weld. A talented welder should leave it ready to paint. Probably cut it in a band saw or lathe to get it straight.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: RTSE4ME]
#3138152
04/15/23 08:44 AM
04/15/23 08:44 AM
Posts: 165 Canada
EW1BH27
Canada
When I finally got it off I looked at it there was no master spline.
IIRC, from the numerous times I've had my crush can removed, it did have a master spline. Look again and very closely, you want to 100% sure before it's welded back together.
[Re: RTSE4ME]
#3138225
04/15/23 01:10 PM
04/15/23 01:10 PM
Posts: 29,679 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
when I took the crush can off it was extremely difficult. Harder to pull than a balancer. When I finally got it off I looked at it there was no master spline. Car version has a master spline. Truck version does not.
[Re: RTSE4ME]
#3138370
04/16/23 01:34 AM
04/16/23 01:34 AM
Posts: 6,120 Valencia, España
NachoRT74
Valencia, España
The regular “non crush” wheel adapter makes to fit the steering wheel on an E Body so close to the dash pad that your hands can get in touch with it when turning around… a friend of mine installed one on his 70 ‘Cuda for a Tuff wheel and was not comfortable to drive due that reason.
I guess that’s one of the reason they were larger and made specificically for E bodies. The Dash pad “eyebrow” section over the cluster protudes more on them than on B and A bodies
[Re: IMGTX]
#3138529
04/16/23 05:03 PM
04/16/23 05:03 PM
Posts: 2,127 MD
RTSE4ME
MD
I replaced my crush can with a B Body tuff wheel adapter almost as soon as I got my car. Never regretted it. I could drive without the steering wheel in my face. I put a 4 spoke grant steering wheel on it instead of the tuff wheel. The smaller grant wheel put the rim of the wheel in front of the speedometer and tach though. I put a monster tach over the clock and who needs a speedometer right..lol On a side note the E body turn signal lever is long and has a heavy bend in it to put the lever near the wheel when used with the crush can. I swapped the turn signal lever to a B body lever which is perfect when using the tuff wheel adapter. I am liking this idea. Even though I do like my current rim blow it is expensive to restore or buy a repro. and big. Might be nice to try a bit smaller wheel and cheaper. My car is so far removed from stock a nice aftermarket wheel might be better.
[Re: Alaskan_TA]
#3138544
04/16/23 05:44 PM
04/16/23 05:44 PM
Posts: 20,536 north of coder
moparx
when I took the crush can off it was extremely difficult. Harder to pull than a balancer. When I finally got it off I looked at it there was no master spline. Car version has a master spline. Truck version does not. i remember that now about the trucks. but it does not involve a crush can for a tuff wheel. i had a truck one time the wheel was too big for my liking. i got a smaller diameter wheel, which also had a bigger and way more comfortable grip, from a chrysler in the junkyard. it fit perfectly, although having a master spline broached into the hub. as the female part of the master spline was in the hub of the chrysler wheel, i could put it on any way i wanted. the horn wire connected just as the truck wheel did, and that was a plus as well. it took a couple of tries to get it on straight after several road trips, but a couple of splines "around" later, it went "straight" down the road.
[Re: EW1BH27]
#3139650
04/20/23 11:32 PM
04/20/23 11:32 PM
Posts: 416 IL us
ink
IL us
IIRC , from the numerous times I've had my crush can removed, it did have a master spline. Look again and very closely, you want to 100% sure before it's welded back together. x 2 at least try it several ways first.
