Re: Best way to revive used nuts and bolts
[Re: BloFish]
#3244535
07/14/24 10:41 PM
07/14/24 10:41 PM
Posts: 3,386 KY USA
mopargem
KY USA
i have two drawers of nuts and bolts and just hit them on the wire wheel bench grinder when i need one
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: Neil]
#3244916
07/16/24 03:48 AM
07/16/24 03:48 AM
Posts: 1,661 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
After soaking in white vinegar, hand wire brushing worked very well for me.
[Re: kentj340]
#3244917
07/16/24 03:50 AM
07/16/24 03:50 AM
kentj340
Cut and Shoot, TX
For fasteners originally phosphated and oiled or Parkerized, the next step is re-phosphating.
[Re: kentj340]
#3244918
07/16/24 03:54 AM
07/16/24 03:54 AM
kentj340
Cut and Shoot, TX
Keeping the temperature steady at 200 degrees without boiling is important and can be accomplished by using a double pot method. I used an electric frying pan filled with water as the heat source, and the phosphating solution was in another stainless pot sitting in the water.
[Re: kentj340]
#3244920
07/16/24 03:58 AM
07/16/24 03:58 AM
kentj340
Cut and Shoot, TX
For fasteners with phosphated as the final finish, RPM wax looks better than than "oiled".
[Re: kentj340]
#3245249
07/17/24 11:55 AM
07/17/24 11:55 AM
Posts: 16,631 On the run…
BloFish
On the run…
After soaking for 48 hours, the hand wire brushing begins.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3245258
07/17/24 12:22 PM
07/17/24 12:22 PM
Posts: 1,531 AZ
Mike P
AZ
I’ve used vinegar in the past and it works. My go to now is powdered citric acid dissolved in water. It’s used in canning believe it or not, and I usually buy it in a 5 pound bag off amazon. Y Citric by M Patterson, on Flickr It seems to work quicker than the vinegar, and doesn’t have that nasty vinegar smell. I’ve used it on nut and bolts, small parts and I have a big tub and even used it on heads and blocks (Mostly to clean water jackets). Y RP by M Patterson, on Flickr H3 by M Patterson, on Flickr Years ago I’d wire wheel the old nuts and bolts and throw them in a 5 gallon bucket then take them up to a commercial plater and he’d zinc plate them for me and I had a choice of clear or gold anodize as the final step. It was actually pretty cheap, but either OSHA or EPA shut the place down after a fire….go figure.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
[Re: ackpht]
#3245275
07/17/24 01:26 PM
07/17/24 01:26 PM
Posts: 21,685 N.E. OHIO, USA
A12
N.E. OHIO, USA
I used to have a "Tumble Vibe" which was a bowl filled with abrasive material and shaken by an electric motor. You put small parts in and let it run overnight. For larger parts I just use a blast cabinet. Anyone have photo samples of results of a "Tumble Vibe" on nuts, bolts, etc.,? Thanks
[Re: moparx]
#3245526
07/18/24 03:41 PM
07/18/24 03:41 PM
Posts: 10,044 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
I use many of the above chemicals AND in a sonic cleaner. Not much manual input needed then. Sonic cleaners have gotten very affordable.
Ive bad lungs so the heated sonic cleaner and simple dish washer pods also work great.
Set at 180 degrees and 30 minutes run time and thats it.
STOP POTATO HATE!
[Re: moparx]
#3247023
07/24/24 02:12 PM
07/24/24 02:12 PM
BloFish
On the run…
Here’s how they look after a wire brushing session.
