Re: CORONET,GTX,CHARGER 383-440 POINT TUNE UP
[Re: 70mopes]
#3254007
08/27/24 06:22 AM
08/27/24 06:22 AM
Posts: 11,921 WILKES-BARRE PA
Joesixpack
WILKES-BARRE PA
NORS USA MADE 383-440 MOPAR SINGLE POINT(ALUMINUM DISTRIBUTOR) MAJOR TUNE UP KIT PLUS WILL FIT; 1968-1969 DODGE CORONET R/T,CHARGER R/T,SUPER BEE,POLARA,MONACO,DART,383-440 1968-1969 PLYMOUTH ROADRUNNER,GTX,,CUDA,FURY, 383HP,440HP, FACTOR ALUMINUM SINGLE POINT DISTRIBUTORS INCLUDES ;
A NORS SHELL USA MADE TAN, HD,BAKELITE, BRASS INSERT, DISTRIBUTOR CAP
A NORS MOTORCRAFT USA MADE ROTOR
A NORS ATLAS PCV VALVE WITH GROMMET&PAL NUT.
A SET OF TAILORED ATLAS HP IGNITION WIREs
NORS USA MADE ATLAS SINGLE POINT&CONDENSER
8 ATLAS HP COPPER RESISTOR SPARK PLUGS,CASE PIC IS SHOWN BUT YOU WILL ONLY GET THE 8 PLUGS, NO CASE)
AN ATLAS NORS USA MADE VOLTAGE REGULATOR
AN ATLAS NORS OIL FILLER CAP
$100 PLUS $25 USPS LARGE PRIORITY MAIL FLAT RATE BOX can send pics via email,or text
cowgerwilliam035@gmail.com
Re: CHALLENGER,CUDA,CHARGER 383-440 DUAL POINT TUNE UP KIT,W
[Re: Joesixpack]
#3254009
08/27/24 06:26 AM
08/27/24 06:26 AM
Joesixpack
WILKES-BARRE PA
NORS USA MADE MAJOR TUNE UP KIT PLUS WILL FIT; 1970-1971 DODGE CHALLENGER,CORONET R/T,CHARGER R/T,SUPER BEE 1970-1971 PLYMOUTH ROADRUNNER,GTX,BARRACUDA,CUDA 383HP,440HP, 440 3X2 CAST IRON FACTOR DUAL POINT DISTRIBUTORS INCLUDES ;
A NORS ATLAS USA MADE TAN, HD,BAKELITE, DISTRIBUTOR CAP
A NORS ATLAS USA MADE ROTOR
A NOS NoVo metal/plastic PCV VALVE, WITH CORRECT MANIFOLD UP ARROW NoVo stamping, correct colors
NORS USA MADE ATLAS DUAL POINTS&CONDENSER
8 ATLAS SPARK PLUGS USA MADE
ALL USA MADE NORS/NOS PARTS $100 plus $25 LARGE PRIORITY MAIL FLAT RATE BOX
pics can be sent via email or text
Re:CHRYSLER,DODGE&PLYMOUTH 400-440 TUNE UP KIT,WIRES,PLUGS,R
[Re: Joesixpack]
#3254011
08/27/24 06:32 AM
08/27/24 06:32 AM
Joesixpack
WILKES-BARRE PA
NOS USA MADE MAJOR TUNE UP KIT PLUS WILL FIT; 1973-1974-1975-1976-1977-1978 DODGE,CHRYSLER,PLYMOUTH B,C&Y BODIES 400-440 WITHOUT LEAN BURN SYSTEM INCLUDES ;
A NORS USA MADE SHELL BRASS INSERT, TAN ,BAKELITE HD DISTRIBUTOR CAP
A NORS USA MADE ROTOR
A NOS MOPAR PCV VALVE
A SET OF TAILORED ATLAS ORANGE HP IGNITION WIRE SET
A NORS ATLAS RADIATOR CAP(MADE IN TAIWAN)
8 ATLAS RESISTOR SPARK PLUGS
1 EMMISION FILTER FOR THE CANNISTER
ALL USA MADE NORS PARTS EXCEPT RADIATOR CAP $100 PLUS $25 LAREG PRIORITY MAIL FLAT RATE BOX
pics sent via email or text
Holley 700 cfm DP carburetor
[Re: Joesixpack]
#3254258
08/28/24 10:46 AM
08/28/24 10:46 AM
Posts: 7,897 Witness Protection Program
Kudakidd
SOLDI have a clean rebuilt Holley double pumper (#4778). It is 700cfm and is ready to bolt on. This carburetor should be good w/ any big / small block engine. There isn't a choke, but in warm weather, you won't need it. This was on my 440 Cuda and ran exceptionally well. I'm going back to my engine's original Carter AVS carb. This carburetor has not been left w/ fuel in it. I emptied the gas, blew out all passages and ran WD-40 in all areas that would need to stay free of oxidation. There are no stripped or rounded screws, or cracks anywhere. $160.00 Shipping is via USPS priority mail for $25.00
Re: For Sale/ Wanted - Big Block Engine - 3rd Quarter
[Re: moparts]
#3254660
08/29/24 11:44 PM
08/29/24 11:44 PM
Posts: 1,385 Out of the State of Confusion
blue_stocker
Looking for old Cam Dynamics 7000+ 383-440 'cheater' cams produced in the 80s-90s. I'm looking for one undamaged to use as a regrindable core. If you have something, pm me here thanks...wb
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Freedom must be repurchased by every new generation General Daniel Jones, WW2 Tuskegee Airmen
1970 WATER PUMP HOUSING AND PULLEY for Sale
[Re: dragon slayer]
#3255930
09/05/24 10:52 AM
09/05/24 10:52 AM
Posts: 804 BRIDGEWATER, CT.
WINGNUT
BRIDGEWATER, CT.
Date code 169, comes with most factory bolts and upper pulley $150 shipped in U.S. No Paypal. U.S. money order only. VEIGHTPETE@GMAIL.COM
