Re: 4 Post Lift Sugeestions
[Re: DUSTER_340]
#3243234
07/09/24 01:07 PM
07/09/24 01:07 PM
Posts: 5,651 Michigan
oldjonny
Don't argue with me.
Advantage Hoist/Wildfire. I think the same hoist is marketed under multiple names. VERY well built, very solid and if you get a caster kit, very easy to move around (without a car on it of course.....don't try that, it wrecks the wheel kit)
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
[Re: DUSTER_340]
#3243357
07/09/24 09:44 PM
07/09/24 09:44 PM
Posts: 23,381 Here
jcc
Here
Car storage or parts storage? Seems a two-post lift is much more efficient space wise vs a 4 post, IMO.
"When one’s appeal is emotional, it does not matter if there is no substance."
[Re: moparx]
#3243463
07/10/24 12:28 PM
07/10/24 12:28 PM
Posts: 2,139 Byron, NY
W.I.N. Racing
Byron, NY
one of my dumbest "life moves" was not making the roof of my garage high enough for a lift when it was re-constructed way back around 1996 or so.......... sure could use one now, since my old body is just about wore out ! HA , Im close to admitting that same thing... built a shop with 9'6" ceilings so no full lift 'cause "Ill never need one"...how things change.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: DUSTER_340]
#3243483
07/10/24 02:04 PM
07/10/24 02:04 PM
Posts: 18,038 S.E. Michigan
ZIPPY
S.E. Michigan
To me, Mohawk is top of the line, still Made in USA and all that....and they are what I'd default to if cost was no object.....
....but they don't sell 4 post for smaller automotive apps.
Rich H.
Esse Quam Videri
[Re: jcc]
#3243492
07/10/24 02:34 PM
07/10/24 02:34 PM
Posts: 75,306 A gulag near you.
JohnRR
A gulag near you.
Car storage or parts storage? Seems a two-post lift is much more efficient space wise vs a 4 post, IMO. For what Car storage or parts storage ? IMO storing a car on a 2 post lift for long periods of time , especially an old unibody that doesn't have added bracing, isn't the smart thing to do. That said a few years ago I got lucky and found a guy on craigslist selling a Challenger 9k wide 4 post lift that was barely even scratched for $1800 bucks , ~6k msrp ... Made in USA and certified by what ever entity it is that certifies them. I have about an 11ft ceiling in the garage , just enough to get my Bee on top with the Dart under it . I'm removing the ceiling joists above the lift, put a high lift kit on my garage door so it clears the on top while it's up, and might have to put a small dormer on the roof so I can stand up under it with my truck on it .
Mainstream Media is the new Pravda
[Re: moparx]
#3243496
07/10/24 03:09 PM
07/10/24 03:09 PM
Posts: 4,356 Morrow, OH
markz528
Morrow, OH
one of my dumbest "life moves" was not making the roof of my garage high enough for a lift when it was re-constructed way back around 1996 or so.......... sure could use one now, since my old body is just about wore out ! Me too. But I remedied that in 2021 with my new 14' ceiling shop. Couldn't be happier with my 2 post BendPak.............
[Re: moparx]
#3243512
07/10/24 04:22 PM
07/10/24 04:22 PM
Posts: 23,381 Here
jcc
Here
one of my dumbest "life moves" was not making the roof of my garage high enough for a lift when it was re-constructed way back around 1996 or so.......... sure could use one now, since my old body is just about wore out ! Don't fret, the two car lift guys will soon be crying about not having enough height for the new 3 car lift set-ups
[Re: 1fastrunner]
#3243579
07/10/24 11:38 PM
07/10/24 11:38 PM
Posts: 15,941 Omaha Ne
TJP
Omaha Ne
Here is mine, it's a BendPak HD9, I am very happy with it. I looked at the others mentioned, most are made by the same manufacturer and then rebranded. I had to get the one I did because of spacing and needing a wider track for the Challenger. Shop around, if you decide on the other models listed above, you will find pricing all over the board for the same exact model. X2 on bend pak
[Re: W.I.N. Racing]
#3243580
07/10/24 11:41 PM
07/10/24 11:41 PM
TJP
Omaha Ne
one of my dumbest "life moves" was not making the roof of my garage high enough for a lift when it was re-constructed way back around 1996 or so.......... sure could use one now, since my old body is just about wore out ! HA , Im close to admitting that same thing... built a shop with 9'6" ceilings so no full lift 'cause "Ill never need one"...how things change. Might be able to add a "square or rectangular pocket" for the car roof to clear the ceiling without a lot of cost
[Re: TJP]
#3243637
07/11/24 10:13 AM
07/11/24 10:13 AM
JohnRR
A gulag near you.
one of my dumbest "life moves" was not making the roof of my garage high enough for a lift when it was re-constructed way back around 1996 or so.......... sure could use one now, since my old body is just about wore out ! HA , Im close to admitting that same thing... built a shop with 9'6" ceilings so no full lift 'cause "Ill never need one"...how things change. Might be able to add a "square or rectangular pocket" for the car roof to clear the ceiling without a lot of cost That's basically what I'm doing first , I can go up 1/3 the gable height and run collar ties from one side to the other ... but the length of the lift which is roughly 20 feet , if I need for head height then I'll look into a dormer. The one thing to pay attention to is the relationship of the door height to the car on a lift, I put in hi lift tracks, which raises the door an inch from the underside of the ceiling joist and switch from extension springs to a torsion spring setup that is above the door, that needs a small pocket in the ceiling for when I decide to drywall it. Also took out the opener and will run a jackshaft opener. the width of the lift is wider than my door opening so driving in is as easy as it was without the lift.
[Re: TJP]
#3243669
07/11/24 01:08 PM
07/11/24 01:08 PM
Posts: 20,419 north of coder
moparx
one of my dumbest "life moves" was not making the roof of my garage high enough for a lift when it was re-constructed way back around 1996 or so.......... sure could use one now, since my old body is just about wore out ! HA , Im close to admitting that same thing... built a shop with 9'6" ceilings so no full lift 'cause "Ill never need one"...how things change. Might be able to add a "square or rectangular pocket" for the car roof to clear the ceiling without a lot of cost the "pocket" part modifications to the roof trusses/rafters wouldn't be too terribly difficult to accomplish, as they are made from rough cut 2x8's. however, during the reconstruction, [the garage was built by the guy i ASSumed the mortgage from way back in 1983 when interest rates were in the mid 20% range, and by doing this, his interest rate was "only" 13 1/4%, and this guy was a real HACK when it came to home construction. ] i wanted a clear interior span without any posts, of which there were three, so i constructed a steel truss that goes from side to side identical to the one outside, shown supporting the 9ft overhang. i'm not sure how i could modify the inside truss to accommodate the height needed for the lift and still maintain it's structural integrity. i have sketched out several design elements of a modification, but none i could come up with that may work, seemed would be structurally sound.
