Re: Flexible line to join trans cooler hardline
[Re: mshred]
#3243327
07/09/24 08:06 PM
07/09/24 08:06 PM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I am adding a cooler in series with the radiator cooler, and will have to cut into the factory hardline setup. I know that regular rubber hose and gear clamps are a no no, so what I am wondering is what kind of flexible line would be safe to run for temp and pressure in trans cooler lines that can join up to compression fittings? I bought stainless transmission lines from Summit with AN fittings and it one of the best upgrades I’ve e ever done.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: pittsburghracer]
#3243342
07/09/24 09:03 PM
07/09/24 09:03 PM
Posts: 12,476 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
-5 Teflon hose and ends. Cut and flare 5/16 tubing to make AN stuff work. Bullet proof
[Re: CMcAllister]
#3243368
07/09/24 11:53 PM
07/09/24 11:53 PM
Posts: 10,346 Someplace you aren't
SomeCarGuy
You could get a nozzle fitting and flare the hardline where you need to, then run the rubber hose.
I want my fair share
[Re: mshred]
#3243410
07/10/24 07:49 AM
07/10/24 07:49 AM
Posts: 4,760 On the parachute mount
n20mstr
I am adding a cooler in series with the radiator cooler, and will have to cut into the factory hardline setup. I know that regular rubber hose and gear clamps are a no no, so what I am wondering is what kind of flexible line would be safe to run for temp and pressure in trans cooler lines that can join up to compression fittings? Earls, Russel, Jegs, Summit, all make a compression fitting to AN adapters to go from hard line to AN. Use -6 then use teflon lines for the flex. Buy them premade from Induction Solutions or other nitrous supplier. It will make a nice appearing and safe installation that will last a long time also.
....BAD A$$ STREET CAR.....
[Re: mshred]
#3243490
07/10/24 02:28 PM
07/10/24 02:28 PM
Posts: 75,306 A gulag near you.
JohnRR
A gulag near you.
I am adding a cooler in series with the radiator cooler, and will have to cut into the factory hardline setup. I know that regular rubber hose and gear clamps are a no no, so what I am wondering is what kind of flexible line would be safe to run for temp and pressure in trans cooler lines that can join up to compression fittings? They make a rubber line that is specifically for Transmission/power steering as the temps of the fluid are higher. Also you'll need to put on a bubble of some sort, partial flare, to keep the line from blowing off at some point .
Mainstream Media is the new Pravda
