Mopar 8-3/4" parts:
Yokes: 7260 coarse, 10 spline, threads good, needs speedi-sleeve. $25
7260 fine 29 spline, threads good with 1 helicoil $25
7290 29 spline, threads good, seal surface nice. $35 ***Pending***
(3) New Mopar #02931687 489 crush sleeves. $10 each or $25 for 3 ***pending***
(1) New Ratech #3102 489 crush sleeve $8.00
NEW original Mopar #02881313 axle spacer kit with instructions. $25
(2) used 741 1-3/8" straight pinion bearing pre-load spacer $5.00 each ***pending****
(1) used Axle housing adjuster with lock retainer $25
(2 pr) New axle retaining plates for 'Green' style ball bearings $5.00 / pair
(1) used "Limited slip lube tag" $6.00 ***SOLD****
PM or cal 507-373-59zero7
1967 Dart GTS 426 Gen III Hemi
1968 Hemi Cuda 572 SS/AH Clone
1988 Chrysler LeBaron Coupe S/S
2003 Dodge Ram 1500 4dr SLT lowered
2012 Ram 1500 2wd Lowered
1970-1/2 Camaro Z-28
1974 VW Karman-Ghia
