No longer racing unfortunately, selling the enclosed trailer. Darn near new, very little use. New today this trailer retails for $54K from Featherlite asking $46K . Willing to assist with delivery.
2020 Featherlite 4410 8.5 x 24 Car / Racing Trailer with rear ramp door
Upgraded with: lined walls & ceiling
upper and lower cabinets
30 Amp motorbase
Aluminum wheels
in addition to the many standard features listed below:
OVERVIEW
Featherlite enclosed bumper pull car trailer Model 4410 offers functionality, durability and value for custom car owners and racers. Featherlite's newest car hauler design features a spread axle, rear spoiler and flat nose. This car trailer, available in lengths of 20', 24' or 28', has a rear ramp and camper door standard to make accessing your cargo easy in this great looking, durable car trailer. While options are more limited on the Model 4410.
HIGHLIGHTS
Lengths of 24'
Width of 8'6"
Flat nose & spread axle design
Aluminum Floor Standard
Rear ramp with cable assist
Inside height of 7'0"
Sleek Rivetless Design
SPECS & FEATURES
Model: 4410
Hitch Type: Bumper pull
Wall to Wall Width: 99" (rear opening width = 94 1/4")
Fender to Fender Width: 82"
Inside Height: 7'0"
Loading Height: 20"
Axles: Two rubber torsion 6000# axles with electric brakes
Tire/Rim: 16" 6-hole silver aluminum wheels with Goodyear ST235/80R16 Load Range E tires (Qty: 4)
Tie Downs: Stainless steel swivel "D" ring tie downs (Qty: 4)
Floor: Smooth extruded aluminum floor
Side Door: 42" heavy-duty 2" double sealed door on curbside
Ramp: Full height & width rear ramp with cable assist, pressure latches, treadplate & vinyl hinge cover
Coupler: 2 5/16" coupler; Crank type jack with wheel
Exterior: White exterior sheets; Flat nose with stainless steel vertical & center panel; Spread axle design with drop skirt and fenderettes; Polished aluminum cast corners
Exterior Lighting: Rear spoiler with load light; Clear LED clearance lights; Slimline LED stop/turn lights (Qty: 4)
Interior Lighting: 6 Surface-mount LED dome lights with switch inside
36" beavertail
Spare tire carrier
2- 14" x 14" crank up roof vents
Skid plate
Custom Winch
