Re: Leaking 440 valve covers
[Re: bdgtfb]
#3240735
06/26/24 05:45 PM
06/26/24 05:45 PM
Posts: 20,844 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
I have not tried this yet on a steel valve cover, but it appears it's designed for that type of application. I was reading some customer comments on Summit awhile ago about cork oil pan gaskets being difficult to seal and a guy on there said this product is the way to do it. It never really fully cures so it maintains a degree of flexibility and doesn't crack or split. It's supposedly like a better version of the Indian Head stuff I think? https://www.permatex.com/products/g...ermatex-form-a-gasket-no-2-sealant-3-oz/The Right Stuff is so strong that it can be a real hassle to remove later. RTV = honestly not a fan of that stuff anymore. I don't even own a tube of it.
[Re: Neil]
#3240806
06/27/24 01:24 AM
06/27/24 01:24 AM
Posts: 43,391 Bend,OR USA
Cab_Burge
I have not tried this yet on a steel valve cover, but it appears it's designed for that type of application. I was reading some customer comments on Summit awhile ago about cork oil pan gaskets being difficult to seal and a guy on there said this product is the way to do it. It never really fully cures so it maintains a degree of flexibility and doesn't crack or split. It's supposedly like a better version of the Indian Head stuff I think? https://www.permatex.com/products/g...ermatex-form-a-gasket-no-2-sealant-3-oz/. i bought some of that to try ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) Not EVER again ![down down](/ubbthreads/images/graemlins/custom/down.gif) . It was design to work for motorcycles and marine motors coolant passages, not for standard automotive application ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif)
[Re: AndyF]
#3240857
06/27/24 11:26 AM
06/27/24 11:26 AM
Posts: 19,734 north of coder
moparx
although i never really measured it, many, many, [and many more] years ago, i got the notion that the holes cast into factory iron heads were not perpendicular to the sealing surface, thus causing sealing issues using the factory tin valve covers. not sure where i heard or read this information, or why it was done this way to begin with. just throwing this out there for consideration. if this is just conjecture or folklore, i don't know. if someone knows for sure, or can debunk this as a myth, please chime in. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: Stanton]
#3240948
06/27/24 07:25 PM
06/27/24 07:25 PM
Posts: 31,124 Oregon
AndyF
The blue Moroso gaskets. Not cheap, don't look "stock" but dammit, they don't leak !! Depends on the head and the valve cover. The wrong combination of parts will rip the Moroso gaskets to shreds. The rubber peels right off if you use some cast valve covers with the Moroso gasket and cast iron heads.
[Re: moparx]
#3240950
06/27/24 07:27 PM
06/27/24 07:27 PM
AndyF
although i never really measured it, many, many, [and many more] years ago, i got the notion that the holes cast into factory iron heads were not perpendicular to the sealing surface, thus causing sealing issues using the factory tin valve covers. not sure where i heard or read this information, or why it was done this way to begin with. just throwing this out there for consideration. if this is just conjecture or folklore, i don't know. if someone knows for sure, or can debunk this as a myth, please chime in. That is true. The bolt holes are angled 5 or 6 degrees on cast iron heads. Aluminum heads are drilled and tapped straight. The factory cast iron heads did it that way so the head of the bolts would dig into the valve cover and create a "lock washer" effect.
[Re: Stanton]
#3240956
06/27/24 08:07 PM
06/27/24 08:07 PM
Posts: 84 usa
bdgtfb
usa
The blue Moroso gaskets. Not cheap, don't look "stock" but dammit, they don't leak !! Are these the ones you are using - Part Number: 710-93055? - I have a pair of these but they came with a disclaimer regarding using them with original style pressed covers and original heads. What combination of heads / valve covers do you have? Also do you run them dry? Thanks for all the replies in this thread...a lot of good info.
[Re: bdgtfb]
#3240970
06/27/24 10:21 PM
06/27/24 10:21 PM
Posts: 8,928 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
What combination of heads / valve covers do you have? Also do you run them dry? Indy aluminum heads and Indy cast valve covers. Yes, dry.
[Re: B1MAXX]
#3241039
06/28/24 09:09 AM
06/28/24 09:09 AM
Posts: 21,091 Niles , Ohio
therocks
Niles , Ohio
Agree with B1 Mr Gasket ultra seals. Mine have been on at least 15 years no leaks. Its all we run SB and BBs. Mine have been off a few times to adjust .Even with cheap Sumot valve covers they still seal.My kids 413 they were on 10 years same with his 360.No leaks
Chrysler Firepower
[Re: AndyF]
#3241076
06/28/24 11:33 AM
06/28/24 11:33 AM
moparx
although i never really measured it, many, many, [and many more] years ago, i got the notion that the holes cast into factory iron heads were not perpendicular to the sealing surface, thus causing sealing issues using the factory tin valve covers. not sure where i heard or read this information, or why it was done this way to begin with. just throwing this out there for consideration. if this is just conjecture or folklore, i don't know. if someone knows for sure, or can debunk this as a myth, please chime in. That is true. The bolt holes are angled 5 or 6 degrees on cast iron heads. Aluminum heads are drilled and tapped straight. The factory cast iron heads did it that way so the head of the bolts would dig into the valve cover and create a "lock washer" effect. thanks for clearing this up for me Andy. i guess i can still remember some things that are kind of strange............. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: B1MAXX]
#3241081
06/28/24 11:45 AM
06/28/24 11:45 AM
Posts: 2,019 Apollo, PA.
B1MAXX
Apollo, PA.
mr. gasket 382, or cometic c5613-094 I what I use on that type of head/valve cover. I need to clarify..... this was in response to the Indy head indy cover statement . These will not work on a stock cover/ head application.
[Re: B1MAXX]
#3241089
06/28/24 12:30 PM
06/28/24 12:30 PM
AndyF
mr. gasket 382, or cometic c5613-094 I what I use on that type of head/valve cover. I need to clarify..... this was in response to the Indy head indy cover statement . These will not work on a stock cover/ head application. Exactly. There are gaskets that work great with aluminum heads and cast valve covers that won't work with cast iron heads and sheet metal valve covers. Sheet metal valve covers are almost impossible to seal, especially when mated to factory cast iron heads which do not have a smooth sealing surface.
[Re: AndyF]
#3241135
06/28/24 04:13 PM
06/28/24 04:13 PM
Posts: 4,773 Moved to N.E. Tennessee
GomangoCuda
The blue Moroso gaskets. Not cheap, don't look "stock" but dammit, they don't leak !! Depends on the head and the valve cover. The wrong combination of parts will rip the Moroso gaskets to shreds. The rubber peels right off if you use some cast valve covers with the Moroso gasket and cast iron heads. Yep, I have a ripped up set of Morosos hanging in my shop to remind me to never spend $40 for these and try to use them with iron heads and/or stock valve covers. I have always used (before and after the Moroso debacle) Mr Gasket ultra seal gaskets glued to the valve cover with 3M trim adhesive. The yellow stuff that is like contact cement. I call it gorilla snot. No need to put anything on the head side. I also recommend cast valve covers no matter what gasket you use but a good set of stock covers is usable just more likely to resist sealing. Do not under any circumstance use anything like "Right Stuff" unless you're ok with using a BFH to get the covers back off. Do Not use Rtv sealants unless your ok with finding chunks of Rtv in your oil pickup screen. By the way the gorilla snot also works good on oil pan and timing cover gaskets
