Re: RMVB w/column shifter
[Re: topside]
#3241053
06/28/24 09:54 AM
06/28/24 09:54 AM
Posts: 4,703 On the parachute mount
n20mstr
So - file the 2nd gear detent or not ? A buddy convinced me it's a good idea, and filed on it, but I'm having 2nd thoughts. I'm not altogether sure it's getting all of the 2nd position, but I just now found a pic Cudaman1969 posted a while back (thank you!), and will verify the new width of the N-1-2 slot. Found the info (.610" being the width measurement he posted) after the deed was done. Guess if it's too wide, we'll put a bit of weld on it.
I don't see this car running better than 12s, so it's not like there's big G-force at play... I don't want to wrestle the column apart twice, it's misery ! THATS what i did ....8.30's with the column shift ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3241075
06/28/24 11:33 AM
06/28/24 11:33 AM
Posts: 8,192 Plymouth, MI
Blusmbl
Plymouth, MI
THATS what i did ....8.30's with the column shift Love that so much!! The 2nd gear detent is filed on mine with a RMVB, have gone low 11’s so far and hoping for low 10’s eventually. Without the detent filed you have to pull back some and it will be hard to consistently not to go from 1st to 3rd. With the detent ground you just push forward and down for 2nd which prevents accidentally grabbing 3rd, and pull back and down for 3rd.
[Re: Blusmbl]
#3241087
06/28/24 12:13 PM
06/28/24 12:13 PM
Posts: 20,993 A collage of whims
topside
A collage of whims
I should probably mention that I'm hip to RVMB with a Cheetah, so I understand the operation. Appreciate the input, just never worked in that plane before, if that makes sense. Over-thinking again ! ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
