440 w/Edelbrock performer RPM heads
[Re: tgt51]
#3233999
05/20/24 05:38 PM
05/20/24 05:38 PM
Posts: 1,012 Central US
grancuda
Central US
1971 440 Engine Runs great, fresh top end & cam with 1000 miles, selling as long block with intake & C-body pan. Still in car & can hear run.
Stock Forged Crank Stock Forged Rods Balanced TRW Forged pop-up 60 over pistons ATI damper Edelbrock Performer RPM heads 84cc Crane gold aluminum roller rockers New Mancini shafts Comp Solid Flat Tappet Cam XS282S Advertised Duration: 282 int./290 exh. Comp Solid Lifters Weiand Single Plane with polished runners
4,800 OBO Located 25 miles W. of Tulsa OK
1967 Barracuda Formula S 383 1967 Chevy C10 Short Stepper 1980 Macho Power Wagon LWB 318 2021 Toyota Supra
1967 383 nearly NOS flywheel
[Re: moparts]
#3234173
05/21/24 08:15 PM
05/21/24 08:15 PM
Posts: 1,552 Mattituck NY.
FJ6AAR
Mattituck NY.
**SOLD**
Hi all., I have a 130 tooth flywheel that came off a 1967 383. This engine was used in a college on a dyno for 50+ years. The pressure plate and disc was installed by Chrysler in 1967 and was never released until I unbolted it last year. The clutch disc was connected to a water flow meter that would add load to the engine. This is as close to an NOS flywheel as you will find. If you look closely at the photos not only can you still see the lines from the milling machine but you can also see the halo imprint left by the clutch disc in the surface as it was pressed together and never released for 50+ years. I'm asking $150.00 plus shipping. Good old fashioned postal money order only or cash in person. Please PM me here for fastest response. Thanks for the ad Moparts! Rob
**I will trade even for one nice original and never cut 426 Hemi connecting rod - looking for a perfect original**
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
Holley list 4669 1971 440+6 manual center carb
[Re: FJ6AAR]
#3234721
05/24/24 01:45 PM
05/24/24 01:45 PM
Posts: 3,530 Lansing, MI
70gtx440dana
Lansing, MI
Nice original Holley list 4669 440-6 center carb for 4 speed application dated 2040 or July 1970. Nice piece for resto. $525+ shipping from Mi 48837. Message me for more info. Joe 517-243-7115
SOLD!!!!!!!!
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
1971 Holley 4670 440-6 center carb dated 9/70
[Re: 70gtx440dana]
#3234722
05/24/24 01:47 PM
05/24/24 01:47 PM
70gtx440dana
Lansing, MI
I have a very nice 1971 Holley automatic 440-6 #4670 center carb dated 2530 (9/70). Would look perfect on a survivor car. Or, restore for concourse. $600+ shipping from MI 48837. PM me for more info. Joe 517-243-7115
SOLD!!!!!!!!
Re: For Sale - Big Block Engine - 2nd Quarter
[Re: Jstern]
#3236871
06/05/24 06:57 PM
06/05/24 06:57 PM
Posts: 12,423 Taxes & Virus's R-US, NY
Dragula
512/400 low deck for sale. carb to pan $15k obo
This is a fresh build and has 3 passes on it.. Its based off a stock 400 block with 440Source internals. It is pump gas friendly at 10.7:1 and has the upgraded ARP 2000 bolts, Ultra light crank, and their girdle as well. Block is not filled and not partially filled...
Indy 325 heads upgraded to 2.19 valves and Comp T&D 1.5 rockers, Morel Lifters, Indy ported 4500 low deck intake. 1050 4500 carb, Milidon oiling system, Indy timing cover and valley cover, ARP damper, Milodon chassis oil pan, & Summit valve covers. MSD distributor
Cam card available upon request.
[Re: Dragula]
#3236881
06/05/24 08:05 PM
06/05/24 08:05 PM
Posts: 973 Mooresville, NC
A70Runner
Mooresville, NC
Comp steel roller rockers. The good: Only used to warm engine up in dyno and half a pull. The bad: 3 rockers are seized to the shaft due to to much spring pressure for these. Not sure how bad they are seized, haven’t tried to get them off. Also have surface rust in places due to being in my garage for years. Good if you need the others for spares or to fix.
$125 obo shipped to lower 48. PM me here on the board. Thanks!
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
[Re: A70Runner]
#3237084
06/07/24 06:08 AM
06/07/24 06:08 AM
Posts: 11,915 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
NOS USA MADE AUTOLITE/NIEHOFF MAJOR TUNE UP KIT PLUS WILL FIT; 1962-1963-1964-1965 DODGE 330,440,POLARA, CORONET 361-4BBL,383 HP,383 2 4BBL INLINE, 413 HP&MW,426SW,426MW WITH CHRYSLER/PRESTILITE/AUTOLITE DUAL POINT DISTRIBUTOR 1962-1963-1964-1965 CHRYSLER 300 413,426W WITH CAST IRON DUAL POINT 1962-1963-1964-1965 PLYMOUTH SAVOY,FURY,BELVEDERE, 361 HP 4BBL, 383 HP, 413 4BBL,2-4 MAX WEDGE, 426 4BBL STREET WEDGE, 426 MAX WEDGE WITH AUTOLITE/PRESTOLITE/CHRYSLER CAST IRON DISTRIBUTOR INCLUDES AN NOS AUTOLITE IBK-1003, DISTRIBUTOR CAP,MADE IN USA LOGO ON TOP&IBK-1003 INSIDE. , A NORS NIEHOFF VACUUM ADVANCE , NOS AUTOLITE CONDENSER IBB-2042SS-1 2-32, NOS AUTOLITE POWER POINTS 1-42V, AND A NOS AUTOLITE ROTOR IBK-1016. BOTH THE CAP AND ROTOR WERE SOLD TO ATLAS BY PRESTOLITE/AUTOLITE ABD BOXED AND RESOLD UNDER THE ATLAS BRAND ALL USA MADE PRODUCTS.. ALSO INCLUDES A NOS BLACK METAL 90 DEGREE PVC VALVE, NoVo ARROW TO MANIFOLD , WITH PAL NUT.$125 cowgerwilliam035@gmail.com
440 six pack complete - 1971 carbs OTC manifold
[Re: moparts]
#3239312
06/19/24 11:48 AM
06/19/24 11:48 AM
Posts: 738 New York
R/T1968R/T
New York
For sale is a very nice Edlebrock manifold (over the counter) with a set of 1971 carbs. 4670, 4671, 4672 Complete with fuel line, choke and linkage. Will need to be rebuilt. Very good mechanical condition. SOLD SOLD s
Re: 383 Intake
[Re: R/T1968R/T]
#3240259
06/24/24 09:56 AM
06/24/24 09:56 AM
Posts: 253 Cent, OH
Mopar.70
Cent, OH
Edelbrock performer 383 AL intake, used in good shape, $200 plus the ride or can deliver to the Nats if paid in advance. PM me here on the board. Thanks Moparts!!!!!!!!
