4 speed transmissions
[Re: 6PAX]
#3232287
05/12/24 10:30 AM
05/12/24 10:30 AM
Posts: 243 Southwest Missouri
eenloe
Southwest Missouri
Mopar small block, big block, 23 spline, 18 spline, and overdrive rebuilding. Your unit rebuilt, trade in, or outright from my inventory. I have some era correct stuff to help with your special restoration or can build a non-era specific unit for you. I also have some good used bellhousings, shifters, and other parts. What I don't have, I can source to help with a conversion. All transmissions are thoroughly cleaned, painted, and rebuilt with American made parts. (main bearings, roller bearings, synchronizers, bushings and seals) See the attached flyer for contact information. This is a side line for me, so I work in spare time with flexible dead lines. Feel free to call or text me (Eric) to start a conversation. Thanks MOPARTS for the space.
TKO TKX T56 B Body Cross Member
[Re: Memongo]
#3234007
05/20/24 06:10 PM
05/20/24 06:10 PM
Posts: 170 West Palm Beach, Florida
Craig J
Not sure if this should be in the transmission section or not... if not please let me know and I will move it.
New and never installed. Nothing wrong with it, I am just selling parts off my Plymouth project. It is for a B Body with Tremec TKX, TKO or maybe also T-56. I would have had to add two more holes to use it in the Cuda or drill two more holes in the cross member. Jegs sells it for 199 I will take 65 plus shipping.
Re: Mopar Transmission For sale - 2nd Quarter
[Re: moparts]
#3239369
06/19/24 04:52 PM
06/19/24 04:52 PM
Posts: 378 NW Indiana USA
727specialist
NW Indiana USA
727 big block transmission Reverse manual with a Griner band on transbrake valve body. This is a fresh build. This is basically what it has in it contact me for more info. Keith 727 specialist Griner valve body owner and builder 219-718-3542 Thank you Moparts
DR2 727 Trans Brake Big block $3890.00 Griner Transbrake Band on valve body TCS Billet drum 16 spring and roller overrunning clutch Rollerised four pinion front planetary Custom design ft and rear bands Race ft and rear clutches Governor body eliminator package Modified oiling system in governor support Bell housing vented and case notched for easy access to the converter bolts
