A/C leak, how to find?
#3237486
06/09/24 01:58 PM
06/09/24 01:58 PM
Posts: 4,763 Florida
BDW
Looking for suggestions on finding an A/C line leak. New 3G install, so new compressor and condenser. Using the factory evaporator that worked when the 340 was pulled. Bought a hydraulic crimper and made all new lines. Hooked up HF gauges and vacuum pump, it pulled down to -30 within just a few minutes. Turned off pump and it quickly, within 2 mins, leaked to -5 and settled there. Plenty of hoses fittings and the adapters needed for the new style compresser, so the leak could be anywhere. How do I track it down?
Is it normal for there to be oil in the yellow line, hooked to vacuum pump? When I pulled the lines off the gauge, there was at least 2-3tsp in the line? I also noticed the vacuum pump was not up to the fill line, where did that go?
Thx
Re: A/C leak, how to find?
[Re: BDW]
#3237488
06/09/24 02:02 PM
06/09/24 02:02 PM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
use ac Dye & use the special light to find it
[Re: CSK]
#3237502
06/09/24 03:13 PM
06/09/24 03:13 PM
Posts: 15,567 Omaha Ne
TJP
Omaha Ne
use ac Dye & use the special light to find it The leak is while under vacuum so I'm not sure the dye will work unless the system is pressurized even then without running the system I'm not sure the dye will travel through the lines. fell free to correct me if I'm wrong. They use a gas to pressurize they systems and detector for that gas to find a "gross leak" such as this. there also have been some issues with fittings needing to be "over crimped" to seal I believe that was mainly in the size 6's. what type of crmper did you use? I might suggest inspecting every Crimp connection, o-ring and their sealing surfaces as a leak of this magnitude should be pretty easy to find (I SAID SHOULD). one could also try water or compressor oil while under a vacuum to see if it gets sucked in. So be aware that the o-ring's seal on the ID and OD and that is where you need to look for lateral damage on the sealing surfaces and rings keep us posted ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: Andrewh]
#3237509
06/09/24 03:40 PM
06/09/24 03:40 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
since it isn't up and running, to get the dye flowing and find the link you should also look at pressurizing it with nitrogen. there are adapters to hook it to the a/c ports. This , pressurize the system and see if it leaks down first.
[Re: JohnRR]
#3237512
06/09/24 03:50 PM
06/09/24 03:50 PM
Posts: 5,970 ohio
ruderunner
ohio
Close. Pressurize and RUN the system. You need to get the oil and dye to circulate in order for the dye to show a leak point.
Every connection and adapter is suspect. Including the gauges. Schrader valves are a common leak point.
If the system didn't leak before the engine swap, good bet the evaporator core is ok. Condenser? New or original?
If you have the right fittings, it's possible to Pressurize the system with shop air and go over parts with soapy water.
Angry white pureblood male
[Re: ruderunner]
#3237519
06/09/24 04:22 PM
06/09/24 04:22 PM
BDW
Don't have nitrogen, so I guess I need to throw some R134a with dye in it and see what happens. I used reduced barrier hoses for flexibility, there are #6, #8, and #10 fittings. The condenser is new, but odds are 1 of the crimps or the adapters to the compressor are leaking.
I haven't even wired up the electrical yet, need power to the compressor and the low pressure switch on the dryer, yet another leak possibilty.
[Re: TJP]
#3237529
06/09/24 05:18 PM
06/09/24 05:18 PM
Posts: 26,039 Rio Linda, CA
John_Kunkel
Rio Linda, CA
This has been my experience, if I crimp to the recommended limit line they're more likely to leak. I over-crimp all sizes. If you have the means to make adapter fittings, you can pressurize the hoses with shop air and test for leaks with leak testing solution or soapy water.
[Re: John_Kunkel]
#3237563
06/09/24 08:37 PM
06/09/24 08:37 PM
BDW
This has been my experience, if I crimp to the recommended limit line they're more likely to leak. I over-crimp all sizes. If you have the means to make adapter fittings, you can pressurize the hoses with shop air and test for leaks with leak testing solution or soapy water. I had read some of issues, so I went to town and really clamped the h*ll out of it. Can too much pressure on the crimp cause a problem?
[Re: BDW]
#3237576
06/09/24 09:53 PM
06/09/24 09:53 PM
TJP
Omaha Ne
Bought a hydraulic crimper and made all new lines. Hooked up HF gauges and vacuum pump, it pulled down to -30 within just a few minutes. Turned off pump and it quickly, within 2 mins, leaked to -5 and settled there Plenty of hoses fittings and the adapters needed for the new style compresser, so the leak could be anywhere. How do I track it down?
Thx
Sorry but I am sometimes a victim of the Evelyn Woods "SPEED READING" course Intel had me take many years ago ![frown frown](/ubbthreads/images/graemlins/custom/frown.gif) Did you close the valves on the gauges before turning the pump off????
[Re: BDW]
#3237733
06/10/24 06:36 PM
06/10/24 06:36 PM
Posts: 5,970 ohio
ruderunner
ohio
I did not, didn't see that on the gauge/pump directions. Could it be that easy (that I'm a dummy)? Might just be it. Try again and see!
[Re: BDW]
#3237744
06/10/24 07:25 PM
06/10/24 07:25 PM
Posts: 531 SW CO
HemiSportFury
SW CO
How long did you leave it at -30? If there is any moisture in the system you may need to leave it at a deep vacuum to "boil" the water off. Also, if it stabilizes at -5 and does not continue to raise, it may be temperature equalizing. Hold it over night and see what it is. As others have said, turn of the gauges before you turn off the pump and consider the above.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: moparx]
#3237770
06/10/24 10:41 PM
06/10/24 10:41 PM
TJP
Omaha Ne
always need to "close" the system before turning off the vacuum pump. i use a small ball valve in the pump line to do this, then turn off the pump. Closing the gauge valves Isolates the pump. If there is a leak the gauges will creep up. I have ball valves on both lines so I can isolate the high and low side. To the OP, yes it could be that simple. What I am not sure of is what effect if any the pump oil may have ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I believe the do make a "FLUSH" for the system 🤔 but I am not an expert in this area. one other thing to be aware of is when you do hook up the freon to charge the system, use the schrader valve to burp the air out of the line and manifold before opening the valve to start charging. If using small cans you must close the charging valve before removing the empty can and burp the line again before reopening ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
