glove box door restoration.
#3237577
06/09/24 09:58 PM
06/09/24 09:58 PM
Posts: 4,871 Star Idaho
67vertman
Star Idaho
1979 Dodge truck. I need to fill in some cracks on my glove box door. Anybody attempted this before?
I am looking for tips. What to use for filler and how to get the textured look in those areas.
I have watched some You Tube videos, and most use spray foam flex fill. My cracks are not to deep about 1/2 inch. and then Bondo.
Any advice or tips are appreciated.
My Monster are real!
Living within your means makes life pretty easy.
Re: glove box door restoration.
[Re: Cab_Burge]
#3237626
06/10/24 10:04 AM
06/10/24 10:04 AM
67vertman
Star Idaho
Can you order a new one from a local Dodge dealer? Hmmm, didn't thank about that. I wouldn't think a 45 year old part wouldn't be stocked.
[Re: 67vertman]
#3237647
06/10/24 11:39 AM
06/10/24 11:39 AM
Posts: 882 Ohio
B5TA
Ohio
[Re: 67vertman]
#3237689
06/10/24 02:35 PM
06/10/24 02:35 PM
67vertman
Star Idaho
Found three so far. Two on Ebay, one is $349 and the other is $174.99 (green) ![runaway runaway](/ubbthreads/images/graemlins/custom/runaway.gif) These guys have a few starting at $150 http://mopartruckparts.com/group-09.htmlMine is not that bad and was trying to do it cheaply.... ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
[Re: topside]
#3237728
06/10/24 06:28 PM
06/10/24 06:28 PM
67vertman
Star Idaho
Buddy, I'd say that's smoked...but IIRC, they were in direct UV light all the time, so I wonder if any nice ones are left. The big problem for me with vinyl repair is getting the grain right; I've never been satisfied with my results when I've tried it. I wonder if anyone has made a dash-cap kinda thing for that, though the word is they're not great either... Haha, it not as bad a most I see. ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) Like you, texture is my biggest issue. I have watched a few people try to match it, Eastwood sells texture cards, and another guy uses hot glue and disc to create it. Neither looks like they could do a large section at one time. I ordered a texture spray from Eastwood, I am going to try it on a scrap piece I have, it won't look like original but if I do the dash pad and glove box door they well look the same. I am not going for the concourse look luckily.
[Re: 67vertman]
#3240097
06/23/24 03:05 PM
06/23/24 03:05 PM
67vertman
Star Idaho
Finally got some time to work on the dash. After watching a bunch of videos on restoring dashes and door panels I put together a game plan. I started with the instrument cover pad. After assessing its condition, after a through cleaning with Purple Power, scrubbed brushed and Green Brillo pad, then a soapy water wash. It had mainly scratches that went through the original texture and a chalky finish. I could have given it a light sanding and painted it, but I wouldn't be happy with the finished project. So, I wet sanded it with a 400 grit foam sanding pad until the scratches and chalkiness was removed, as well as about 90% of the original texture. ![nervous nervous](/ubbthreads/images/graemlins/custom/nervous.gif) I left some areas that where in good condition with the original texture to have a place to compare the new texture with the original. See pictures.
[Re: 67vertman]
#3240101
06/23/24 03:18 PM
06/23/24 03:18 PM
67vertman
Star Idaho
After watching the videos a few people used SEM Texture Coating 20 oz Can with 16 oz Fill Aerosol Can 39853 with good results. https://www.eastwood.com/sem-texture-coating-20-oz-aerosol-can-39853.htmlSo, on to step two. I cleaned the pad again and wiped it down with wax and grease remover. I did a couple of test sprays on some cardboard to get a fell for the product and how it sprayed. Distance a speed are your friends with this product. I held the can about 16 to 18 inches away from the panel and gave it a light coating moving rather quickly to just fog the pad. sorry no picture of that. The product said 3 to 5 minutes between coats. So coat two I gave it a heaver spray move slower until there was little of the original color left showing. First picture. I thought it was okay, but the texture was rough to the feel so I wet sanded it with 800 grit paper, very lightly just to knock down the high points. second picture.
[Re: 67vertman]
#3240103
06/23/24 03:25 PM
06/23/24 03:25 PM
67vertman
Star Idaho
Part three: ![coffee coffee](/ubbthreads/images/graemlins/custom/coffeetime.gif) I could have ![primer primer](/ubbthreads/images/graemlins/custom/primer.gif) it at this point and been happy with the results. ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif) But I new I could do better. Another cleaning with wax and grease remover. I again sprayed the pad focusing on getting an even texture with a wetter coat. It took to more passes. I think the results turned out nice. Yes it is not factory texture. But even texture with no shinny or bare spots.
[Re: 67vertman]
#3240106
06/23/24 03:39 PM
06/23/24 03:39 PM
67vertman
Star Idaho
Part four: ![smoke smoke](/ubbthreads/images/graemlins/custom/smoke.gif) I purchased my dash pad paint from LMC Truck, light tan. It is lighter that what the pad was from the factory, even though they state it is the same a factory color. Not a big issue for me, but thought I would bring it to everyone attention. Note, some people used adhesion promoter on the texture coat. I followed the manufactures recommendation and didn't. After letting it to dry, the texture product said to apply top coat with in 15 minutes. I sprayed the pad with adhesion promoter (which said to apply the top coat within 10 minutes). I sprayed the first coat of color by just barley fogging the pad. Let that flash for 5 minutes and applied a second coat, again just fogging the pad. You could still see a little black on the pad. I let that flash for 5 minutes and applied the third coat, heaver this time. No more black visible on the pad. After letting it flash again for 5 minutes I applied the final coat, working on getting a nice even coat. I think it turned out great. I will get a overall picture when it is fully dried. I wanted closeups of the pad in the same spot so you could see the results for yourself.
![Name: thumbnail_IMG_0037.jpg
ID: 509429 thumbnail_IMG_0037.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/509429/filename/thumbnail_IMG_0037.jpg)
[Re: A12]
#3240126
06/23/24 06:00 PM
06/23/24 06:00 PM
67vertman
Star Idaho
Completely dry. Now I just need to start on the glove box pad. ![sawzall sawzall](/ubbthreads/images/graemlins/custom/sawzall.gif)
