Re: R134 converted ac systems charge level ???
[Re: Ramrod39]
#3071738
08/26/22 11:53 PM
08/26/22 11:53 PM
Posts: 10,241 Someplace you aren't
SomeCarGuy
I saw a chart recently, I’ll see if I can find it. Seems your number might be about what was on the conversion chart.
I want my fair share
[Re: Ramrod39]
#3071740
08/27/22 12:49 AM
08/27/22 12:49 AM
Posts: 21,539 It's a dry heat
gtx6970
It's a dry heat
Find some R12. I tried converting to 134A on some old R12 systems and the results were not good. Interesting. a buddy of mines 68 Coronet was converted above method and his blows ice cold and has for over 5 years now. He just cant remember the exact amount he put in it. I charged mine this afternoon putting 36 ounces in it. Its cold, Not as cold as the above 68 Coronet. BUT,,,,, based on my above 80 percent rule. It could use a tad more I just dont want to go to far and risk damaging reed valves in the compressor
[Re: IMGTX]
#3071784
08/27/22 10:44 AM
08/27/22 10:44 AM
Posts: 6,358 nowhere
Sniper
nowhere
As stated, R12 while hard to find is a better refrigerant.
And if you find it you need a license to buy it
[Re: gtx6970]
#3071803
08/27/22 12:09 PM
08/27/22 12:09 PM
Posts: 12,248 Looking for a way out of Middl...
IMGTX
The car had been converted long before my purchase. It was empty when i bought it. Previous owner told me was bad condenser...yet ive found no signs ot that.
Ive replaced a bad hose .. and expansion valve and will be replacing the dryer as well. Ive got 36 ozs in it right now to ck operation and for any other leaks. So far...so good. On the drive home yesterday. It was cool and comfy...but feel like it could / hope would be a little better. I havent put a thermometer in the vent yet.
And planning to evac it back out . Change the dryer. Then pull a good vacuum on it for like an hour or so .
Was curious the anount required to recharge it. Ill start with the same 36 ozs for now and see what pressures i get. Some people convert by draining the R12 and refilling it with R134a & Ester oil and others will drain, flush, replace the oil in the compressor sump, and replace the hoses & O-rings. It's a crap shoot how it was done if you don't do it or see it done, but no biggie. If you run ester oil you will be fine if they didn't remove the mineral oil. When you replace the dryer if the o-rings are black they didn't replace them. Old school rubber was black. Newer HBNR are usually green but sometimes blue. I have found that the old rubber hoses and rubber seals will leak the R134a to the tune of about 12 oz per year. This usually means that in the spring you may need to top it off and you would be good for the year. If you are loosing more than that look for a bigger leak. If you replace all the hoses with newer "barrier' hoses and the o-rings/seals with the new HNBR then it should hold a charge a lot longer but the oem compressor seal was made for lower pressure R12 so it may still loose pressure over time. Good news is if you don't have a noticeable leak you should not loose any oil. As SRT said R12 requires a license but craigslist /ebay is a good source for people who are not interested in licenses. Just sayin... ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
[Re: IMGTX]
#3071829
08/27/22 01:31 PM
08/27/22 01:31 PM
gtx6970
It's a dry heat
Was curious the anount required to recharge it. Ill start with the same 36 ozs for now and see what pressures i get. Some people convert by draining the R12 and refilling it with R134a & Ester oil and others will drain, flush, replace the oil in the compressor sump, and replace the hoses & O-rings. It's a crap shoot how it was done if you don't do it or see it done, but no biggie. If you run ester oil you will be fine if they didn't remove the mineral oil. When you replace the dryer if the o-rings are black they didn't replace them. Old school rubber was black. Newer HBNR are usually green but sometimes blue. I have found that the old rubber hoses and rubber seals will leak the R134a to the tune of about 12 oz per year. This usually means that in the spring you may need to top it off and you would be good for the year. If you are loosing more than that look for a bigger leak. If you replace all the hoses with newer "barrier' hoses and the o-rings/seals with the new HNBR then it should hold a charge a lot longer but the oem compressor seal was made for lower pressure R12 so it may still loose pressure over time. Good news is if you don't have a noticeable leak you should not loose any oil. As SRT said R12 requires a license but craigslist /ebay is a good source for people who are not interested in licenses. Just sayin... Ive done all new O rings myself. I have no problem changing compressor oil. Thats easy . Just to be on the safe side. I will pick up a bottle of ester oil when I pick the dryer up today
[Re: gtx6970]
#3071899
08/27/22 07:46 PM
08/27/22 07:46 PM
Posts: 20,720 in a cattle trailer down by th...
Guitar Jones
The rule is to multiply the R12 fill spec by 0.9 then subtract 0.25 pounds from the result. Example 40 oz. of R12 = 2.5 pounds X 0.9 = 2.25 pounds minus 0.25 = 2.0 pounds of R134a. Keep in mind those small cans are only 12 oz. Additionally if you would like it to cool better put an auxiliary fan on the condenser then you can add a few more ounces of refrigerant. Keep the high side around 250 psi.
[Re: gtx6970]
#3072067
08/28/22 12:50 PM
08/28/22 12:50 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
I start with 70% of R12 weight. Check your pressures after coming back from a drive on a hot day. Add more if pressures will allow. Buying a new modern design condenser made for r134 will help a lot with cold air temps as measured at the dash.
First choice though is R12. R134 is a smaller size molecule and designed to run at higher pressures, both of which can cause problems with leaks in an r12 system.
[Re: Guitar Jones]
#3074100
09/04/22 05:32 AM
09/04/22 05:32 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Best rule of thumb I have seen is to charge to a high-side pressure (in psi) of 2.2 to 2.5 times the air temp (in F) in front of the condenser/grille. That's how I do all my cars. If you're charging to 250 psi on an 80F day I think that's too much. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Oh, and drain and flush as much of the old mineral oil as you can. It doesn't mix with the PAG oil used for R-134a, so it's taking up space in the system somewhere (even if it just sits in a low spot, usually the receiver/dryer).
[Re: cudaman1969]
#3074369
09/05/22 05:21 AM
09/05/22 05:21 AM
Posts: 10,781 North Dakota
6PakBee
North Dakota
One thing I was told was to replace the hoses, the 134 will seep thru the old type hose. Your ends can be reused with the new hose. How is this possible with crimped ends? One of the reasons I'm asking is PS hoses. I've looked under all the rocks I could think of and never could find a procedure to re-use those hose ends with new hose. I would think A/C hoses are similar.
[Re: 6PakBee]
#3074414
09/05/22 09:52 AM
09/05/22 09:52 AM
gtx6970
It's a dry heat
Still with just the 36 ozs in it and the original receiver drier ( which I plan to change this week ) But so far, I think its working damn good
the OE water valve doesnt close so for now I have the heater core bypassed altogether . I just got an nos valve earlier this week I need to replace same time while drier is getting replaced
BUT,,,, center outlet temps are,,,,,,and This is sitting in the garage, at 85 degrees ambient temps , slightly above idle,
