Page 5 of 8 1 2 3 4 5 6 7 8
Re: progress on the race truck project [Re: RodStRace] #32352
01/17/07 02:26 PM
01/17/07 02:26 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline OP
Are you going to weld in the seat brace and belt mounts before you paint?
LOOKS GREAT!!!
I wish I could but I don't have the seats yet
so I want to paint the cage while its easy to get at.
then I will have to weld the window net,seats and belt mounts later and touch up the paint on those areas
also some of the cage will have padding,
so I am not sure how much of the cage will show anyways Ron...
Re: progress on the race truck project [Re: Mopar Ron] #32353
01/18/07 05:23 PM
01/18/07 05:23 PM
here are some pics of the rollcage, I got the cage painted today, I went with silver.
so maybe later today I will be able to get the back of the cab back on for the final time
then the front top section of the cab, then I need to cut some of the back of the cab to fit and weld the rear bars, then finish putting on the back,top of the cab and finish the chop top Ron....
Re: progress on the race truck project [Re: Mopar Ron] #32354
01/19/07 05:05 PM
01/19/07 05:05 PM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
Ron,
Since you had to add the extra 3" in the roof line to get the windshield lined back up, will you have to do any changes to the doors to get them to line back up?
Your work is incredible and is giving me a lot of motivation to get moving on my 48 Panel. I would love to do a chop on it, but I think it is way to ambitious for me at this point. But if you have a few days of spare time and want to come spend some time in the midwest let me know I will be happy to let you work your magic on the panel.
Thanks for the details, photos and discussion it is always good to see someone making progress.
Brian
Re: progress on the race truck project [Re: bohmer2] #32355
01/19/07 05:37 PM
01/19/07 05:37 PM
thanks Brian, I thought about making the door 3" longer but decieded to add 3" to the cab just behind the door area from the botton to the top and move the back of the cab back the 3" there.
with the chop the cab needed to be split and a filler piece made to fill that area, after the top was set back on we found that we need to make a 1 3/4" filler piece, but when you add in the 3" that i moved the cab back the filler piece needs to be 4 3/4"
I will make the filler piece 2" wider than the opening and overlap it across the roof. that way I can weld it inside and outside Ron...
Re: progress on the race truck project [Re: Mopar Ron] #32356
01/19/07 06:44 PM
01/19/07 06:44 PM
here are a few more pics from today, I am letting the paint dry on the rear bars, i have the back of the cab welded back on and the front top fitted, and the rear top section has been fitted and cut out for the rear bars, also the rear bars are finally welded in Ron..
where I added to the cab:
rear bars welded in and painted:
Re: progress on the race truck project [Re: Mopar Ron] #32357
01/20/07 09:13 AM
01/20/07 09:13 AM
Maryland
33Plymouth Offline
33Plymouth  Offline
Maryland
Hi Ron,
Once again I am simply amazed at your craftsmanship and would like to thank you for allowing us to watch the progress. How will you finish the cab where the rear bars come out? Also in one of the pictures I see your brother's sedan, if I remember correctly you are going to paint that for him, what color?
Hughey
Re: progress on the race truck project [Re: 33Plymouth] #32358
01/22/07 09:59 PM
01/22/07 09:59 PM
Hi Ron,
Hughey
sorry I didn't get back to this post sooner
I am thinking about making a little cover for where the Rear bars come through the cab(see pics below)
we plan to paint my brothers car candy brandywine with darker fenders, the body will be painted over burgandy base and the fenders will be painted over black base.
here are the latest pics of the finished rollcage and the chop top. got the back window area welded back in too,
I only chopped the back window 1 1/2" instead of 3 1/2" like the body.
you can see the pieces that I made to fill in the top area and the patches that needed to be made.
I still have a few more patches to do and a bunch more spotwelds. Ron..
Re: progress on the race truck project [Re: Mopar Ron] #32359
01/25/07 08:59 PM
01/25/07 08:59 PM
here are the latest pics of the race truck.
I finished the welds on the chop top and got the first layer of fiberglass on it, I used Tiger hair fiberglass,it has long strands of fibers to it.
I like to use that on all the welded areas first and then finish it up with regular bondo type filler. Ron...
here is the welded in back window
here is the front seam that I welded up so i can smooth it out
it wont take to much to leval it out
Re: progress on the race truck project [Re: Mopar Ron] #32360
01/25/07 09:47 PM
01/25/07 09:47 PM
moparx Offline
moparx  Offline
lookin good ron ! are the rear down tubes of the cage welded to the rear cab tin ? what are your plans for the firewall ?
Re: progress on the race truck project [Re: moparx] #32361
01/25/07 10:16 PM
01/25/07 10:16 PM
Yes the cab is now welded to the cage, I started to make cab to cage mounts and everything started to get very solid so i went ahead and welded the rear bars too., I plan to make some nice covers to weld over that area.
Not sure yet how the firewall will be.
I'm thinking about a slight curved one. Ron...
Re: progress on the race truck project [Re: Mopar Ron] #32362
01/25/07 11:51 PM
01/25/07 11:51 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
One thing I've never seen done real nice is a fire wall that follows the shape of the engine and still allows service. If you got a 4" thick piece of foam, Installed the drivetrain, then shaped the foam to tuck around the back of the motor and trans with an inch clearance, then pull the valve covers, Dist. etc. to make sure service was good. Replicate the final shape in metal and it would be beautiful! Just a wild thought, but you have the skills to pull it off.
Re: progress on the race truck project [Re: Mopar Ron] #32363
01/26/07 12:16 AM
01/26/07 12:16 AM
SW FL
dodgedartgt Offline
dodgedartgt  Offline
SW FL
Ron, Yes, you've been doing this for years and years, have huge amounts of practical experience and it is still INCREDIBLY AMAZING the speed at which you work!
I was looking at the filler pieces for the top. It looks like they are lapped rather than being edge or butt welded. (No doubt, much easier than needing to worry about arrow straight cuts.) But have you joggled or offset the edge to bring them close back up to flush or just relying on filler?
Mike Bynum
Re: progress on the race truck project [Re: dodgedartgt] #32364
01/26/07 12:39 AM
01/26/07 12:39 AM
Yeah Mike I just overlapped the filler piece and hammer and dollied it so it was pretty close and then glass it up . I thought about making a step on the filler piece but that tool is at my sons house and I didn't want to wait to get it back here.. Ron...
Re: progress on the race truck project [Re: Mopar Ron] #32365
01/29/07 12:00 AM
01/29/07 12:00 AM
here are some more pics of the progress.
I trimmed and fitted the dash in place and got it welded up and glassed in. Ron.....
Re: progress on the race truck project [Re: Mopar Ron] #32366
01/29/07 06:13 AM
01/29/07 06:13 AM
The Thumb O' Michigan
Fluffy Offline
Automotive STD Guy
Fluffy  Offline
Automotive STD Guy
Re: progress on the race truck project [Re: Fluffy] #32367
01/29/07 10:12 PM
01/29/07 10:12 PM
moparx Offline
moparx  Offline
ron, i like the way you tucked the tubes close to the a pillar ! since the cage has been painted, will the interior tin be the same color ?
Re: progress on the race truck project [Re: moparx] #32368
01/29/07 10:23 PM
01/29/07 10:23 PM
right now I plan on doing the interior black tweed and thought that the cage would look good in silver so that it stands out Ron...
Re: progress on the race truck project [Re: JonsGottaDusta] #32369
02/03/07 01:09 AM
02/03/07 01:09 AM
Lookin' good there Mr.
Re: progress on the race truck project [Re: Mopar Ron] #32370
02/03/07 03:32 PM
02/03/07 03:32 PM
Kentucky
Flipper1938 Offline
Flipper1938  Offline
Kentucky
Roll that thing out in the driveway so we can get a good look.
I am curious to see how natural the stretch looks.
Re: progress on the race truck project [Re: Flipper1938] #32371
02/03/07 10:37 PM
02/03/07 10:37 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
me too
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
