1969 instrument panel voltage regulator source? #3235101
05/26/24 06:03 PM
05/26/24 06:03 PM
Cab_Burge Offline OP
My water temp and fuel gauge have stop working on my 1969 dart GTS, I'm thinking it is the voltage regulator/reducer. Any hope on buying a new one? help luck
Re: 1969 instrument panel voltage regulator source? [Re: Cab_Burge] #3235110
05/26/24 07:30 PM
05/26/24 07:30 PM
BlueRacer69 Offline
BlueRacer69  Offline
I got one about a year ago off E-bay. Can't remember the seller's name. But they have both the points type and the electronic type. Yes they are new.
Re: 1969 instrument panel voltage regulator source? [Re: BlueRacer69] #3235156
05/26/24 11:38 PM
05/26/24 11:38 PM
Thanks bow up
Re: 1969 instrument panel voltage regulator source? [Re: BlueRacer69] #3235172
05/27/24 06:02 AM
05/27/24 06:02 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
IIRC wasn't it RT Specialties that made the electronic ones?
Angry white pureblood male
Re: 1969 instrument panel voltage regulator source? [Re: ruderunner] #3235183
05/27/24 08:22 AM
05/27/24 08:22 AM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
It was RT-Eng
Looks like you need the IVR4, Click on: "Which cars use the IVR4?" to be sure
https://www.rt-eng.com/index.php/RTE_limiter.html
