Re: Where to put vacuum port in Indy single plain ??
[Re: Stanton]
#3235021
05/26/24 09:55 AM
05/26/24 09:55 AM
Posts: 43,311 Bend,OR USA
Cab_Burge
What size and what use? If power brakes I would use one on the carb if available if for vacuum advance ported vacuum outlet on the carb
[Re: Stanton]
#3235031
05/26/24 10:56 AM
05/26/24 10:56 AM
Posts: 2,937 A shed in England
Tig
A shed in England
Wondering where others have drilled and tapped for a vacuum port on a big block Indy single plane intake. I'm thinking the crotch between the runners at the back of the plenum id too tight to get any sort of fitting in there. Photos if you have them. Thanks, On my 3X I was going to drill and tap for an 1/8th NPT port under the carb pad either right or left. This was to log manifold vacuum.I was going to use a right angle -3 fitting and some -3 line to the sensor which is 1/8th NPT male. It could also be done on a 1" spacer, if you have the room. The sensor was going to be mounted off the engine. I still haven't got round to it as I realised I'd got the wrong sensor and we switched to a T/R a few years ago. It's way easier to pick a spot on a T/R though.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Neil]
#3235097
05/26/24 05:40 PM
05/26/24 05:40 PM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Carb? What carb ?!? EFI !!!
Carb spacer ... uh-uh, ain't gonna happen.
The port is for 1) PCV and 2) MAP sensor
I think Diplomat360 has the answer ... looks like that spot will work on mine as well.
[Re: topside]
#3235107
05/26/24 06:48 PM
05/26/24 06:48 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
For a brake booster, I'd locate it at the rear. I only had a front photo of the motor - the port will be in the rear.
[Re: topside]
#3235385
05/28/24 03:32 PM
05/28/24 03:32 PM
Posts: 861 lancaster,california
johnnycuda
I drilled and tapped my Indy 4150 single plane where Diplomat360 shows his, I did mine 1/4" NPT with a 1/8" hose, just wanted to run a vaccum gauge.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
