Re: Weiand X-Celerator on 340?
[Re: tboomer]
#3232898
05/15/24 09:09 AM
05/15/24 09:09 AM
Posts: 9,791 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
I have one on a solid cam 318-392 stroker/850 brawler and with 4:56 gears and mild vert it works great but all the research ive done seems to point its a better intake for my type setup vs your mild setup with it being a single plane intake.
Many are going to say the current $450 edelbrock air gap is the way to go or as much as I hate to say it the $150 china man air gap would work just as well. Or even a factory cast iron 4bbl intake.
STOP POTATO HATE!
[Re: Mr PotatoHead]
#3232902
05/15/24 09:18 AM
05/15/24 09:18 AM
Posts: 20,222 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Many are going to say the current $450 edelbrock air gap is the way to go or as much as I hate to say it the $150 china man air gap would work just as well. Or even a factory cast iron 4bbl intake. The Chinese air gap is a copy of the LD4B with 318 sized runners so I would shy away from it.
[Re: tboomer]
#3232991
05/15/24 02:34 PM
05/15/24 02:34 PM
Posts: 5,445 Indiana
YO7_A66
Indiana
I have one that I gasket matched for my 340/420 combo. It may be a little small, but the TF Track Heat unit is never in stock when I search for it.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Mr PotatoHead]
#3233246
05/16/24 11:20 PM
05/16/24 11:20 PM
Posts: 15,653 Omaha Ne
TJP
Omaha Ne
Many are going to say the current $450 edelbrock air gap is the way to go or as much as I hate to say it the $150 china man air gap would work just as well. Or even a factory cast iron 4bbl intake. We used to bore the primary side openings on stock intakes and slip a 440 AVS on. great for street racing back in the day as it looked stock 🙄🤣🤑🤑
[Re: pittsburghracer]
#3233475
05/18/24 07:26 AM
05/18/24 07:26 AM
Posts: 4,801 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Those old small plenum single plane intake manifolds such as the Weiand Accelerator and Edelbrock Torker are a great high perf intake manifold. Not recommended for low comp, no cam duration smog engines. Vut with good comp, gutsy cam, some gears and appropriate stall (or 4 speed) and they are right at home. I say run it and see. If you must - and have the $$ you can try an RPM or RPM Air Gap- or Weiand Air Strike or etc.
Keep old mopars alive.
