Re: New 540 build
[Re: 67_Satellite]
#3232390
05/12/24 08:43 PM
05/12/24 08:43 PM
Posts: 728 Southern Alberta
Uberpube
Southern Alberta
Ok, I'm as mopar as anyone, but please explain the math on a 600'' s. b.c, and how it all " fits"inside the crankcase. There is a write up of one on engine labs site, longer block, larger bore spacing and 4.9" stroke IIRC.
Re: New 540 build
[Re: Uberpube]
#3232393
05/12/24 08:56 PM
05/12/24 08:56 PM
Posts: 20,207 PA.
pittsburghracer
"Little"John
"Little"John
PA.
A lot of people underestimate the power that Victor heads can make. Any head that can easily flow 370-390cfm can make horsepower.
Re: New 540 build
[Re: powertrip]
#3232419
05/12/24 10:09 PM
05/12/24 10:09 PM
Posts: 38 Indiana
Mbrown
Indiana
Great power out of that build, especially when considering how many struggle with making 750+ with those heads. If you don't mind a couple of questions:
What compression? What are the rough cam specs? What were the flow #'s and what did you have to do to get those?
Thanks! Compression is 12.5 , camshaft is 275@.050 intake 279@.050 exhaust. 113 LSA intake is 109.5 centerline. A lot of thought went into the camshaft and particularly the intake closing point. The Victor head is way better than most give it credit for. Any of the 350cc cnc programs will get you right at 385cfm @.800 with the 2.2 valve. For my heads, I am 355cc, 2.2 valve and flow a TON. I stayed with the 2.2 valve on this set because the 2.25 on my first set didnt yield much. I thought it made the port a little too slow. I may post my flow sheets some time. I would like to get the car on the track and see what kind of power its making. Dynos and the track are 2 different animals.Valve train is atrocious on these heads. This is my second time using them. I recommend milling the rocker stands off and use longer valves. At the end of the day, thats the only way to get them right. Anything else is too compromised..
Re: New 540 build
[Re: Mbrown]
#3232454
05/13/24 06:52 AM
05/13/24 06:52 AM
Posts: 4,105 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Over the last several months I built a new 540 for my father-in-law's Duster. I was going to refrain from posting this until we got the car down the track, but I am bored. In my experience, very few will realize the corrected power that even a 'conservative' dyno will show. As long as I have been in the testing community just about ANY data is relative if you want to learn something. It's a point of reference that the skilled can use to anticipate potential. Regardless, you being apprehensive to post any information is respectable. But then the debating is entertaining, lol. After reading more of your posts, I have less doubt that's what it made. Does anyone know of any near 900HP (as verified in-car) Victor headed motors?
Re: New 540 build
[Re: HardcoreB]
#3232462
05/13/24 08:50 AM
05/13/24 08:50 AM
Posts: 10,051 MN
JERICOGTX
MN
Over the last several months I built a new 540 for my father-in-law's Duster. I was going to refrain from posting this until we got the car down the track, but I am bored. In my experience, very few will realize the corrected power that even a 'conservative' dyno will show. As long as I have been in the testing community just about ANY data is relative if you want to learn something. It's a point of reference that the skilled can use to anticipate potential. Regardless, you being apprehensive to post any information is respectable. But then the debating is entertaining, lol. After reading more of your posts, I have less doubt that's what it made. Does anyone know of any near 900HP (as verified in-car) Victor headed motors? I believe Peter Wille in Canada has proven his 1000hp Victor headed 555ci engine, in his 3400lb Cuda runs mid 8's.
69 GTX
68 Road Runner
Re: New 540 build
[Re: JERICOGTX]
#3232466
05/13/24 09:11 AM
05/13/24 09:11 AM
Posts: 38 Indiana
Mbrown
Indiana
Over the last several months I built a new 540 for my father-in-law's Duster. I was going to refrain from posting this until we got the car down the track, but I am bored. In my experience, very few will realize the corrected power that even a 'conservative' dyno will show. As long as I have been in the testing community just about ANY data is relative if you want to learn something. It's a point of reference that the skilled can use to anticipate potential. Regardless, you being apprehensive to post any information is respectable. But then the debating is entertaining, lol. After reading more of your posts, I have less doubt that's what it made. Does anyone know of any near 900HP (as verified in-car) Victor headed motors? I believe Peter Wille in Canada has proven his 1000hp Victor headed 555ci engine, in his 3400lb Cuda runs mid 8's. That was the first one that came to mind. There is a guy local to me that is upper 800's. I've seen his car run.
Re: New 540 build
[Re: HardcoreB]
#3232469
05/13/24 09:14 AM
05/13/24 09:14 AM
Posts: 10,040 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Over the last several months I built a new 540 for my father-in-law's Duster. I was going to refrain from posting this until we got the car down the track, but I am bored. In my experience, very few will realize the corrected power that even a 'conservative' dyno will show. As long as I have been in the testing community just about ANY data is relative if you want to learn something. It's a point of reference that the skilled can use to anticipate potential. Regardless, you being apprehensive to post any information is respectable. But then the debating is entertaining, lol. After reading more of your posts, I have less doubt that's what it made. Does anyone know of any near 900HP (as verified in-car) Victor headed motors? Also much consideration must be given to how well the car and driveline are scienced out. My dart as an example, many things are less than optimum. I leave soft for consistency. Tight converter. I could probably use a different set of trans ratios. Weather. Headers are close, but may not be the ultimate. Still, the car had some amazing performance show up on parts of my runs. So all in all, despite some guys saying it ain't got the oats the dyno sheet says, I believe it does, it just isn't applied perfectly. After all, nothing is ever perfect.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: New 540 build
[Re: JERICOGTX]
#3232492
05/13/24 10:18 AM
05/13/24 10:18 AM
HardcoreB
Shelby Twp. Mi
Over the last several months I built a new 540 for my father-in-law's Duster. I was going to refrain from posting this until we got the car down the track, but I am bored. In my experience, very few will realize the corrected power that even a 'conservative' dyno will show. As long as I have been in the testing community just about ANY data is relative if you want to learn something. It's a point of reference that the skilled can use to anticipate potential. Regardless, you being apprehensive to post any information is respectable. But then the debating is entertaining, lol. After reading more of your posts, I have less doubt that's what it made. Does anyone know of any near 900HP (as verified in-car) Victor headed motors? I believe Peter Wille in Canada has proven his 1000hp Victor headed 555ci engine, in his 3400lb Cuda runs mid 8's. LOL you are right!...I forgot all about that particular one that I have mentioned in the past.
Re: New 540 build
[Re: Mbrown]
#3232503
05/13/24 10:42 AM
05/13/24 10:42 AM
HardcoreB
Shelby Twp. Mi
[quote=HardcoreB][quote=Mbrown]Over the last several months I built a new 540 for my father-in-law's Duster. I was going to refrain from posting this until we got the car down the track, but I am bored. ........ That was the first one that came to mind. There is a guy local to me that is upper 800's. I've seen his car run. What did this car MPH/ and what does it weigh?
Re: New 540 build
[Re: Mbrown]
#3232515
05/13/24 11:29 AM
05/13/24 11:29 AM
Posts: 1,204 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I have no reason to doubt BES' numbers, but find it odd that their dyno printout doesn't include any of the basics like AFR, Fuel Flow, Air Flow, etc., included ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: New 540 build
[Re: fast68plymouth]
#3232537
05/13/24 12:57 PM
05/13/24 12:57 PM
Brad_Haak
Loudoun County, VA
That's nuts! (Get the squirrel / nuts reference there? ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) )
Re: New 540 build
[Re: HardcoreB]
#3232540
05/13/24 01:08 PM
05/13/24 01:08 PM
Posts: 38 Indiana
Mbrown
Indiana
[quote=HardcoreB][quote=Mbrown]Over the last several months I built a new 540 for my father-in-law's Duster. I was going to refrain from posting this until we got the car down the track, but I am bored. ........ That was the first one that came to mind. There is a guy local to me that is upper 800's. I've seen his car run. What did this car MPH/ and what does it weigh? His car is 3250, 120mph in the 1/8.
Re: New 540 build
[Re: Mbrown]
#3232558
05/13/24 02:30 PM
05/13/24 02:30 PM
Posts: 117 NW Indiana
powertrip
NW Indiana
Thanks! Compression is 12.5 , camshaft is 275@.050 intake 279@.050 exhaust. 113 LSA intake is 109.5 centerline. A lot of thought went into the camshaft and particularly the intake closing point. The Victor head is way better than most give it credit for. Any of the 350cc cnc programs will get you right at 385cfm @.800 with the 2.2 valve. For my heads, I am 355cc, 2.2 valve and flow a TON. I stayed with the 2.2 valve on this set because the 2.25 on my first set didnt yield much. I thought it made the port a little too slow. I may post my flow sheets some time. I would like to get the car on the track and see what kind of power its making. Dynos and the track are 2 different animals.Valve train is atrocious on these heads. This is my second time using them. I recommend milling the rocker stands off and use longer valves. At the end of the day, thats the only way to get them right. Anything else is too compromised.. Thank you, that agrees with what others on here have experienced. That much power with only 12.5 compression is even more impressive. I am assuming your cam lift is in the .800" range and you upgraded to individual rocker arms as mentioned. Would you have any more information on that modification that you would care to share?
Re: New 540 build
[Re: gregsdart]
#3232688
05/14/24 08:23 AM
05/14/24 08:23 AM
Posts: 38 Indiana
Mbrown
Indiana
Did you try revving it higher to make sure the motor had reach peak RPM and not started a dip that would go away in another hundred RPM? What type of cam and lifters and valve spring pressures? I'm running a Jones solid roller with crower lifter. Springs are 255 on the seat and 660#'s over the nose. I told Rich we were shifting at 6800 before we started, regardless of power curve. It may be flawed thinking on my part, but I believe an oem block has a better chance of living if you don't rev the piss out of it. I sized everything when designing the motor to peak at 65-6600. Heads, cam, intake, headers, ect i am solidly behind the path you chose here. Knowing my rpm graph shows actual rpm of the 1/2 shift to be higher than the programmed rpm in rhe electronics activated air shifter, if it were mine i would start by shifting by eye at 6400, 6500 if an air or electric shifter is in use. Add a hundred rpm for the 2/3 shift. From my limited experiance those heads are making about the limit of thier hp capability, and then some. What do you think is the cause of the discrepancy of the programmed shift rpm and actual shift rpm? We don't have any data logging yet. We may in the future.
Re: New 540 build
[Re: Mbrown]
#3232704
05/14/24 09:54 AM
05/14/24 09:54 AM
Posts: 2,530 PA
moparacer
PA
Thanks! Compression is 12.5 , camshaft is 275@.050 intake 279@.050 exhaust. 113 LSA intake is 109.5 centerline. A lot of thought went into the camshaft and particularly the intake closing point. The Victor head is way better than most give it credit for. Any of the 350cc cnc programs will get you right at 385cfm @.800 with the 2.2 valve. For my heads, I am 355cc, 2.2 valve and flow a TON. I stayed with the 2.2 valve on this set because the 2.25 on my first set didnt yield much. I thought it made the port a little too slow. I may post my flow sheets some time. I would like to get the car on the track and see what kind of power its making. Dynos and the track are 2 different animals.Valve train is atrocious on these heads. This is my second time using them. I recommend milling the rocker stands off and use longer valves. At the end of the day, thats the only way to get them right. Anything else is too compromised.. 355 cc?!?! Holy cow I had no idea..... I just keep slogging along with my old -1s and now guys are making Eddie's that are better lol.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
