Re: Cranks but doesn't fire!
[Re: B300 VanDanage]
#3231999
05/10/24 06:47 AM
05/10/24 06:47 AM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
"Could a bad neutral safety switch cause it not to start?" It would not crank or turn over at all if there is no neutral safety switch contact. Have you checked for spark?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Andrewh]
#3232014
05/10/24 09:07 AM
05/10/24 09:07 AM
Posts: 8,683 Buford, GA
I_bleed_MOPAR
Buford, GA
As mentioned, check for spark. Been a minute since I had one that old but were ballast resistors an issue in '79? ![work work](/ubbthreads/images/graemlins/custom/work.gif) Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) )
[Re: I_bleed_MOPAR]
#3232018
05/10/24 09:20 AM
05/10/24 09:20 AM
Posts: 6,362 nowhere
Sniper
nowhere
As mentioned, check for spark. Been a minute since I had one that old but were ballast resistors an issue in '79? ![work work](/ubbthreads/images/graemlins/custom/work.gif) Tim If it has a ballast, it would be bypassed in start. It would start then as soon as you let go of the key it would die. Assuming the system is wired properly. During start mode the electrical system is at it's most loaded down state, not uprising that any marginal part of the ignition system would not work then, but work in run. Without any troubleshooting info, hard to say what failed.
[Re: Andrewh]
#3232046
05/10/24 12:21 PM
05/10/24 12:21 PM
Posts: 357 Chino Valley
B300 VanDanage
Chino Valley
neutral saftey as said above would stop cranking.
as for the bypass, if you ran it to the wrong side of the ballast, you could have burned up the coil as it shouldn't take that many volts.
but also as said above, check for spark before throwing parts at it.
the odd part is that it ran and wasn't a problem till you tried to restart. so I would also be checking for power at the various spots you messed with as a starting point. you might also put it in run and then jump the relay for the starter and see if it fires up, in which case it would be the start circuit to chase down. I ran the bypass to both sides of the coil...
[Re: Andrewh]
#3232081
05/10/24 04:26 PM
05/10/24 04:26 PM
B300 VanDanage
Chino Valley
then you killed the coil with the bypass. the ballast resister takes the voltage down in run to about 8 volts. by running 12 volts to it you burned it out.
there are 12 volt coils, so you can replace it with one of those, but in the future recheck which side of the ballast has 12 volts first. and only put 12 volts to that side. Sorry, I meant ballast resistor not coil! I ran a bypass wire from the battery to both sides of the ballast resistor (pictured) due to the overcharging issue....
[Re: stumpy]
#3232083
05/10/24 04:35 PM
05/10/24 04:35 PM
B300 VanDanage
Chino Valley
Have you checked for power to the positive side of the coil? Yes, I just did! There's 11.9 volts going to the positive side of the coil with the key in the ON position... and incase it matters there's 11.7 volts at the negative side of the coil...
[Re: Andrewh]
#3232087
05/10/24 05:11 PM
05/10/24 05:11 PM
B300 VanDanage
Chino Valley
the coil cannot run on 12 volts for long or it will die. in run you should only have about 8 volts going to it. I don't remember how the 4 post ballast works, but you have to only jumper the side that reads 12 volts with the key in run, not both sides. so remove your jumpers and check voltages again to see which side reads 8 vs 12 and only jumper the 12 volt side. or you will be getting another new coil.
or you can eliminate the ballast and use a 12 volt coil. Here's the thing about the bypass I installed... I ran a wire from the battery to a switch and from the switch to both sides of the ballast so that I wouldn't have to remove the bypass from the resistor every time. The readings I posted are without the bypass engaged!
[Re: stumpy]
#3232106
05/10/24 07:52 PM
05/10/24 07:52 PM
Posts: 10,676 Freeport IL USA
poorboy
Freeport IL USA
You guys are jumping into an ongoing mess with this van.
The reason for the bypass he talks about is because there was a voltage drop between the key and the ballast resistor. The by pass was suppose to be a temporary thing until he had time to chase down the reason for the voltage drop. Apparently since the van has been starting he felt there was no need to look into the cause of his original problem, its been a few months. There has also been a big over charging issue with this van, I don't remember if that got resolved or not. Then there was a fuel pump dumping fuel into the oil pan. I believe he got that changed, but I'm unsure if he ever changed the oil.
The way the bypass has been wired, the ballast is still fully functional. The bypass eliminated all the wiring connections on the van between the key switch and the ballast, it has done nothing else..
So he is back looking for another cheap temporary fix to get it running until the next time it won't start. Not that most of us have not been in that position before, a time or two.
This is going to sound dumb, but look at the position the rotor is pointing at on the distributor, then crank the motor just a little, and see if the rotor has turned at all. The motor may have a bad timing chain. If the rotor is turning, pull # 1 spark plug out of the cylinder and see if there is compression while the motor is cranking over. .if you have compression, see if you can bump the motor so that the timing marks are lined up at "0" and look to see if the rotor is pointing at the place on the distributor cap where the wire to cylinder #1 is. If its off 1 spot, the timing chain may have slipped and it needs to be replaced. If the rotor is pointing at the place the #1 wire is, then move on.
If you have power to the coil, the problem is in the ignition system, It could be as easy as a bad coil wire from the coil to the distributor, a bad coil, or a fried electronic ignition part. The coil wire, and then the coil are the cheapest places to start. If you have something there that runs that has a similar coil wire, or coil, you could swap them over onto the van (one at a time please) and see if the van will start. If it starts, replace which ever one was bad with a new one.
If that doesn't work, your going to have to remind us what ignition system is on your van (it may or may not be original to the can), before we can move forward from here.
[Re: poorboy]
#3232187
05/11/24 12:51 PM
05/11/24 12:51 PM
Posts: 19,708 north of coder
moparx
i ran into a bad coil wire last fall on my charger. it would sometimes start easy, and sometimes take forever to start. after it started, it ran good. the problem turned out to be the brass connector that attaches to the wire, then plugs into the coil. it had been a bad connection for a while, as the brass had a bunch of burn marks and pits, and had actually started to melt through the rubber coil boot on the bottom. [coil is mounted horizontally, thus, the bottom of the boot couldn't be seen.] new coil wire and all has been well since. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: stumpy]
#3232773
05/14/24 02:15 PM
05/14/24 02:15 PM
B300 VanDanage
Chino Valley
My advice is get rid of the add ons you did and go back to factory wiring. It worked for years and there is no reason for it not to work now. Just a suggestion. I can't! There's a reason for the bypass... I don't have any other 'add-on's' other than that! I started another thread a couple of months ago about it. I was(still) having an overcharging issue with van and I still haven't had time to find that problem so as suggest I installed the bypass so I could drive it! Believe me, I don't want all these extra little things on my van! I want to fix the issues so that it goes back to working the way the factory intended!
[Re: poorboy]
#3232779
05/14/24 02:30 PM
05/14/24 02:30 PM
B300 VanDanage
Chino Valley
The reason I still haven't address the underlying issues for the bypass is because my daily driver as an S10 which I was replacing the clutch in which I finally finished and have been driving... I was driving the van because that's my backup vehicle but I'd still like to keep chipping away at it to get it fixed properly because I know I'll need to drive it again very soon! I still have more work to do to my truck so I'd like to get the van properly fixed... I thought we already identified the problem was the coil at the beginning of this thread! No spark coming out of the sparkplug wires and there's 11.9 volts going to the coil at the positive side and that number has nothing to do with the bypass because the bypass isn't engaged! Edit: I did end up changing the oil twice and I probably didn't even have too because there wasn't much fuel that made it down into the cylinders if any but I still changed it to be safe!
[Re: Andrewh]
#3233418
05/17/24 07:50 PM
05/17/24 07:50 PM
B300 VanDanage
Chino Valley
or you can eliminate the ballast and use a 12 volt coil. Andrewh! You are 100% correct! I just installed the new coil and it fires up and runs great! The problem was exactly what you said it was! I ran the bypass to both sides of the resistor when I should've only ran it to the side that goes to the ignition control module! So one side of the resistor goes to the coil directly and one side goes to the ignition control module! I removed the bypass from the coil side and now the coil is getting 8.5volts! Thank you sir for all your help! I'll still be back to figure out the overcharging issue when I have time but for now the van is drivable again!
#3233422
05/17/24 08:29 PM
05/17/24 08:29 PM
Posts: 1,854 South Bend
John Brown
South Bend
There are 12 volt coils, and there are 12 volt coils.
Coils normally marked as 12 volt are made to have a resistor in front of them. Other 12 volt coils have the resistor built into the coil.
Rambler was one of the few that used a coil that had the resistor built in.
[Re: Andrewh]
#3233455
05/18/24 12:21 AM
05/18/24 12:21 AM
B300 VanDanage
Chino Valley
glad you got it up and running. Thanks! Not sure if you've been keeping up with the old thread I started a couple of months ago about the overcharging issue but after installing the new coil the voltage has dropped down to normal levels and it's not overcharging anymore!!!! I'm talking between 13.2 - 14.2 volts from idle to acceleration!!!! Could it be the coil or a connection on the coil was the issue and the reason it was overcharging??? I don't think it's a coincidence but maybe it is... ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
#3233627
05/18/24 11:18 PM
05/18/24 11:18 PM
Posts: 15,575 Omaha Ne
TJP
Omaha Ne
glad you got it up and running. Thanks! Not sure if you've been keeping up with the old thread I started a couple of months ago about the overcharging issue but after installing the new coil the voltage has dropped down to normal levels and it's not overcharging anymore!!!! I'm talking between 13.2 - 14.2 volts from idle to acceleration!!!! Could it be the coil or a connection on the coil was the issue and the reason it was overcharging??? I don't think it's a coincidence but maybe it is... have you Ohmed out the coil? possible internal short pulling the Voltage down ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) You could always reinstall to see if the issue recurs ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) But sometimes at the end of a long journey it's best to leave things alone ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: moparx]
#3233634
05/19/24 12:29 AM
05/19/24 12:29 AM
Andrewh
"had one go out like that while driving and it vaporized 2 inches of copper and about 5 inches of insulation under the dash. showed something crazy like 100 volts output." and i'll just kinda' guess all the "magic smoke" escaped, causing a great deal of consternation.............. the smoke pouring out from under the dash at 55 with all the windows down was quite impressive, I will say. I don't think I have ever pulled over that fast before and jumped out of a car. the fact it still was running and everything seemed to be working was amazing. I was near some small town in podunk and a garage was on main street and they offered to take a look, since the car wasn't on fire. lol.
[Re: A990]
#3233835
05/19/24 10:13 PM
05/19/24 10:13 PM
TJP
Omaha Ne
No good. These are for positive earth systems. Perfectly fine if you turn the container upside down before injecting the smoke. Doing so reverses the electrons polarity 🤫🤣
[Re: Andrewh]
#3237902
06/11/24 01:56 PM
06/11/24 01:56 PM
TJP
Omaha Ne
no, the starter relay always gives 12 volts. ballast resistor usually goes open when bad, but I guess I would start with a new coil and a new ballast resister just in case. or rewire the entire circuit. As I recall, your pictures showed a need for a good pair of wire cutters. no offense meant just stating my observation. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: Andrewh]
#3237916
06/11/24 02:53 PM
06/11/24 02:53 PM
B300 VanDanage
Chino Valley
no, the starter relay always gives 12 volts. ballast resistor usually goes open when bad, but I guess I would start with a new coil and a new ballast resister just in case. I have a new coil and ballast on the way! Ok so it's obvious the ballast resistor is bad! I did a bunch of resistor tests a few months ago when I first started working on the whole 'overcharging' issue the van was and is still having because of a voltage drop somewhere which there is a thread for and I posted a few pictures with all the readings and one of the readings for example was 13 volts going into the resistor and 8.25 volts coming out, with the key ON and bypass engaged to both sides... The reading I'm getting now with the key ON and no bypass is 12.3 going in and 12.2 coming out! I had previously mentioned that I removed the bypass from the coil side of the resistor but what I didn't understand at the time is that it didn't matter that I did that because the power wires going into the ballast are part of the same circuit and I was still running the bypass to the voltage regulator side of the resistor and even though only one side was being fed battery power through the bypass both sides were getting that same voltage! Even with the bypass the battery was still getting higher than normal voltage so if I have a wire coming straight from the battery to the resistor and the battery voltage reading is between 13.8-14.8 when driving that would mean the resistor was getting that same voltage and that would mean I fried the resistor with the bypass! Is that correct??? I know I need to figure out that voltage drop which was causing the voltage regulator to overcharge the batter which is why I ran the bypass to the resistor in the first place and that's what's caused the system to fry the coil and the resistor! Am I on the right track here?
[Re: TJP]
#3237925
06/11/24 03:13 PM
06/11/24 03:13 PM
B300 VanDanage
Chino Valley
no, the starter relay always gives 12 volts. ballast resistor usually goes open when bad, but I guess I would start with a new coil and a new ballast resister just in case. or rewire the entire circuit. As I recall, your pictures showed a need for a good pair of wire cutters. no offense meant just stating my observation. I know what you're referring to.... Here's a clear picture of that mess... It's part of the battery isolator and non of those wire are connected to anything! Here's a picture of that, take a close look!
[Re: Andrewh]
#3238006
06/11/24 10:06 PM
06/11/24 10:06 PM
poorboy
Freeport IL USA
The Ballast resister will not reduce the voltage until it gets hot. It is the heat that causes the resistance. If you are checking the resistance while the resister is cold, it will read battery voltage. With in about 30 seconds of having voltage pass through it,, the resistance should start to increase. After the resister has warmed up, you should be able to see the voltage reduction.
3 miles on a coil with 12 volts should not be enough to cook a coil, unless it was nearly junk to start with. I'm betting the coil is not your problem.
My guess is you have a different problem, but I have no idea where to start looking, given the history of the van.
At this point, I believe I would test the electronic pickup in the distributor. There is a test procedure, but I would have to look it up and don't have time to do that right now.
There is a way to test the coil as well to see if it will produce a spark, but I'm not sure how to communicate that to you. All I can say is with the old points, the negative wire off the coil grounded through the closed points. When the points were closed, the coil was energized. when the points opened, the coil would shoot off a spark. Back in those days, if you closed the points, with 12 volts to the coil, then opened the points with a screw driver on the points arm, the coil would produce a single spark spark each time you let the points close, then opened them again. That entire process of closing the points and opening them to have the coil give off a spark only takes a matter of seconds. Opening the points broke the 12 volt circuit ground and caused the coil to create a spark.
You should be able to use a test wire connected to the negative side of the coil, have a good coil wire (the one that goes to the center of the distributor cap) in the center post of the coil resting on a good ground with a little less then a 1/4" air gap to the ground, where you can easily see the spark jump. With 12 volts going to the positive side of the coil, and the test wire connected to the negative side of the coil, and the bared other end on a good ground, with a coil wire in the coil terminal, position yourself where you can clearly see the open end of the coil wire and the nearby ground (1/4" or less away), watch for the spark and remove the test wire from the ground. The spark should happen immediately. If the set up is correct, every time to connect the test wire to ground a few seconds and remove it, you should get a spark. With the motor running a 1,000 rpm, that spark is happening 1,000 times each second.
Test the coil. Test the distributer pick up. If both test good, test the plate the distributer pick up plate is screwed down to and make sure it has a good ground. if all 3 test good, the problem is likely a bad brain box for the ignition, or a wiring problem some place. .
[Re: Andrewh]
#3238384
06/13/24 07:08 PM
06/13/24 07:08 PM
B300 VanDanage
Chino Valley
yeah, the voltage should not be the same coming in and going out. I would still bet some other wiring issue, but getting a new ballast is a place to start. like I said, they normally fail open, but I wouldn't say it is impossible to fail with no resistance. if after changing it you still get 12 volts to the coil I would say you have other wiring to chase down to make sure something upstream at the bulkhead or the splice isn't wired wrong, burned through and shorted or whatever. I haven't changed the configuration of any of the components or wiring since I've had the van... I've owned it for at least 12 years and have replaced most electrical components under the hood and signal relays etc... Just parts swaps, simple stuff like that... It's possible the previous owner switched some stuff out(changed the configuration of the wiring) but I assume I would've ran into the issues I'm having now years ago if that was the case... I'm discovering a few things about the van that just don't seam right like the ballast resistor for example... In the wiring diagram out of the Haynes manual it's showing a single wire resistor(one wire in and one wire out) for my year van and taking a look at the diagram for vans years 1971-1976 and 77 and 78 show the dual resistor which I have in my van and mines a 79'.... The splices haven't been rewired or look bad and I've tested all these circuits for current and it all seams fine! The bulkhead is fine as well! Remember, my van still has that overcharging issue that I started a thread for months ago and I did a pretty thorough inspection of all the connections in the bulkhead and tested the voltage on both side of the circuits in question....I still haven't had time to figure that out and I'm assuming this coil/ballast problem may be related to that in some way so I think the most important and obvious place to go is to revisit that thread and get that taken care of! I ran the bypass from the battery to the ballast so that I could still drive the van to work temporarily while I got my daily driver fixed...
[Re: poorboy]
#3238391
06/13/24 08:01 PM
06/13/24 08:01 PM
B300 VanDanage
Chino Valley
Test the coil. Test the distributer pick up. If both test good, test the plate the distributer pick up plate is screwed down to and make sure it has a good ground. if all 3 test good, the problem is likely a bad brain box for the ignition, or a wiring problem some place. . I'm pretty sure the resistor had plenty of time to warm up when checking the voltage. I had the key in the ON position for more than 30 seconds for sure and I also checked multiple times! I'll check again in a little while... Yeah, I don't see how 3 miles of driving could've fried the new coil especially since the last coil lasted such a long time with much higher voltage... That last coil was the same coil it had when I bought the van over 12 years ago! I don't have an electronic pickup in my distributor! It's a magnetic pickup in a relatively new distributor of which I just set the gap in... BUT the reason I was in the distributor to begin with was because it was having trouble starting one morning and after checking things over I found that the two pickup wires coming out of the distributor wire were cracked open!!! I figured they were shorting on eachother and what I did was splice them open, twist them and sealed them with some shrinkwrap and after that the van was running great! That was around the same time I discovered the overcharging issue and opened that thread a few months back... Going back to the coil... There's no spark coming out of it and I checked with different wires! There's the 12 volts that it shouldn't have going to the positive side of it so if the coil was still good I should see spark right??? Thanks for taking the time to detail the instructions to test the coil! I'll do my best to try and understand and do that test in a little while when I go recheck the resistor! Before I forget! Another little detail that might be related which I found strange was that when I got home from that 3 mile drive with the new coil it stalled out on me in reverse and then backfired once when I started it back up! I parked it and that was the last time it ran! I found it strange because about 100 miles ago I spent all night tuning everything according to the manuals! I set the curb idle and fast idle correctly! I set the timing to about 12° advanced and adjusted the air/fuel mixture in the carb! That van was running so nice and still is when it's running which is why I found it strange that it backfired and that's why I mention that because it might be an important clue!
[Re: poorboy]
#3238393
06/13/24 08:26 PM
06/13/24 08:26 PM
B300 VanDanage
Chino Valley
Magnetic not electronic.... I did the gap a couple of months ago and I did it with the nonmagnetic feelers!
#3238398
06/13/24 08:50 PM
06/13/24 08:50 PM
B300 VanDanage
Chino Valley
Here's the second component that seams out of place and I don't see this one in the diagram at all!!! It's obviously some sort of ballast resistor... The black wire at the top goes to the oil pressure switch and the one on the bottom goes to the choke thermostat... Is that even right?? Could this be causing an issue??? When I replaced the coil this was the only component I touched because it uses the same bolt the coil bracket does and after that the whole "overcharging issue" went away for a few minutes... Maybe it was just a coincidence but I thought I'd bring it up...
#3238597
06/15/24 12:07 AM
06/15/24 12:07 AM
poorboy
Freeport IL USA
Test the coil. Test the distributer pick up. If both test good, test the plate the distributer pick up plate is screwed down to and make sure it has a good ground. if all 3 test good, the problem is likely a bad brain box for the ignition, or a wiring problem some place. . I'm pretty sure the resistor had plenty of time to warm up when checking the voltage. I had the key in the ON position for more than 30 seconds for sure and I also checked multiple times! I'll check again in a little while... Yeah, I don't see how 3 miles of driving could've fried the new coil especially since the last coil lasted such a long time with much higher voltage... That last coil was the same coil it had when I bought the van over 12 years ago! I don't have an electronic pickup in my distributor! It's a magnetic pickup in a relatively new distributor of which I just set the gap in... BUT the reason I was in the distributor to begin with was because it was having trouble starting one morning and after checking things over I found that the two pickup wires coming out of the distributor wire were cracked open!!! I figured they were shorting on eachother and what I did was splice them open, twist them and sealed them with some shrinkwrap and after that the van was running great! That was around the same time I discovered the overcharging issue and opened that thread a few months back... Going back to the coil... There's no spark coming out of it and I checked with different wires! There's the 12 volts that it shouldn't have going to the positive side of it so if the coil was still good I should see spark right??? Thanks for taking the time to detail the instructions to test the coil! I'll do my best to try and understand and do that test in a little while when I go recheck the resistor! Before I forget! Another little detail that might be related which I found strange was that when I got home from that 3 mile drive with the new coil it stalled out on me in reverse and then backfired once when I started it back up! I parked it and that was the last time it ran! I found it strange because about 100 miles ago I spent all night tuning everything according to the manuals! I set the curb idle and fast idle correctly! I set the timing to about 12° advanced and adjusted the air/fuel mixture in the carb! That van was running so nice and still is when it's running which is why I found it strange that it backfired and that's why I mention that because it might be an important clue! So the red highlighted area says that you "spliced them open, twisted them, and sealed them with some shrinkwrap." You are assuming those wires that are twisted together are making good contact under that shrink wrap. If that connection is not good, you won't have any spark. By the looks of the entire wire (in the picture on your next post), I would suggest that you find a complete new replacement wire harness (or pigtail) for the wires from the coil to the pickup in the distributer. They might be available ordered through a parts store) If either of those two wires are grounding anyplace (like where they pass through the distributer housing) you will not get a spark. The green highlighted area: That backfire and the motor dying was probably caused by the twisted wires in the shrink wrap loosing connection, or the wires shorting to ground someplace between the distributer and the coil. Replace those wires, and solve your problem.
[Re: poorboy]
#3238652
06/15/24 02:39 PM
06/15/24 02:39 PM
B300 VanDanage
Chino Valley
I understand that if the pickup wires aren't making connection there won't be spark coming out of the distributor but I'm not checking for spark coming from the distributor, I'm checking for spark coming out of the coil! If the coil is getting voltage, whether it's too high or not then I should still see spark coming out of the coil wire until the coil gets fried right? I just installed the new coil and ballast and it's fixed nothing! Infact there's actually 0.3 more volts going to the coil now with the new resistor! How would the pickup factor in to no spark coming out of the coil and 12 volts coming from the resistor when it's suppose to be around 8.5??? It's a long way from the pickup to the coil and they're not directly connected as I see it... The wires from the pickup go to the ignition control module and the only wire I see that would tie the coil and the pickup together is a green wire that comes out of the ICM and directly to the resistor... The wire on the opposite side of the resistor is the coil wire that runs from the resistor to the starter relay and then to the coil... Edit: taking another look at the diagram I see that the negative wire from the coil goes directly to the ICM so I can see how the pickup would be directly tied in with the coil! Please be patient with me people! I've already said it before that I don't know much about electrical and this is how I learn... Sorry, not trying to be difficult it's just if I don't understand how these things work and go together it just frustrates the hell out of me!
[Re: stumpy]
#3238661
06/15/24 04:21 PM
06/15/24 04:21 PM
B300 VanDanage
Chino Valley
If the distributor is shorted you won't get any signal to the control module and that means no signal to the coil... Throwing parts at this willy nilly isn't going to fix it. Throwing parts at it is definitely NOT what I'm trying to do!!! I'm trying to figure out what's wrong, what's the cause and how to fix it! Let me explain... I don't know much about electrical and it's hard for me to understand what you guys are talking about sometimes... You guys understand how these components work and are tied in together... I don't! I just figured out in the past hour how the pickup and coil are connected and that's through the ICM which I didn't see before so now I understand how the bad wires on the pickup can affect the coil from not producing voltage to the distributor!
#3238687
06/15/24 08:52 PM
06/15/24 08:52 PM
B300 VanDanage
Chino Valley
Ok guys.... I figured it out! ![penguin penguin](/ubbthreads/images/graemlins/custom/penguin-006.gif) It wasn't the pickup! It wasn't a short or bad ground! Not the bulkhead etc... I like to save all my old parts so I installed the old pickup and it did nothing and at that moment I knew that wasn't the problem and the common denominator in all of this has been the ICM so I swapped that out with the original one and the van fired right up! I even installed the original coil that I thought had burnt out and it's actually still good! The numbers are all back to normal! I'm assuming they're normal but anyways here are the numbers I'm getting now... The positive side of the coil is getting 5.6 volts with the key ON and the battery is reading between 13.0 - 14.0 volts from idle to full acceleration! Swapping the ICM took care of the 'overcharging' issue that started months ago! So this whole time all of the issues with the van were being caused by a failing Ignition Control Module!!!!!
#3238797
06/16/24 12:24 PM
06/16/24 12:24 PM
moparx
happy to hear you got it back running ! electrical issues, especially ones that have my brain in overload "circuitry", have contributed to the "shinyness" on the top of my head that some of my so called friends chuckle at. ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif) please don't get too upset, but it took me many years to finally gain the courage to bull into the electrical side of this "fun with cars" thing, and although i now have success, it can still get one's goat when something crop's up that is a [censored] to figure out. just keep after it, and success will be yours as well, as hopefully, you have finally figured out your problem. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: poorboy]
#3238807
06/16/24 12:51 PM
06/16/24 12:51 PM
B300 VanDanage
Chino Valley
If you did not change the wires going through the distributer to the pickup coil, you will probably be back in a couple months with the same old story.
Good luck. The style magnetic pickup that goes into the distributor in my make and model is made with the wires attached! I can't swap the pickup without swapping the wires also.... The wires are not separate of the pickup and here's a picture of it! I also wrote that I swapped that unit out with an old pickup I had but you must've missed that part... i also mentioned that I ordered another and it's on the way but you must've missed that too...
[Re: moparx]
#3238812
06/16/24 01:05 PM
06/16/24 01:05 PM
B300 VanDanage
Chino Valley
happy to hear you got it back running ! electrical issues, especially ones that have my brain in overload "circuitry", have contributed to the "shinyness" on the top of my head that some of my so called friends chuckle at. ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif) please don't get too upset, but it took me many years to finally gain the courage to bull into the electrical side of this "fun with cars" thing, and although i now have success, it can still get one's goat when something crop's up that is a [censored] to figure out. just keep after it, and success will be yours as well, as hopefully, you have finally figured out your problem. Thanks! Yeah I've definitely lost some hair since I started working on the overheating issue that started months ago! Going through the bulkhead multiple times, following circuits, cleaning connections and grounds etc... I had to disassemble the steering column a few times also and in the end it was simply the ICM! That's how it goes sometimes but it wasn't all for nothing! I'm alot more familiar with my van's electrical system now and I know that most of those connections and grounds are clean and making good contact! Oh! The ammeter also started working which it didn't before so... I still have a ways to go to fully understand how this stuff works and I'm sure I'll be back! I'm glad you guys are here to help!
#3239126
06/18/24 12:22 PM
06/18/24 12:22 PM
moparx
another item you should seriously consider is running a wire from the alternator output stud to the main stud on the starter relay. this is where the positive battery cable attaches to on the starter relay. this wire should be an 8 or 6 gauge wire with a fusible link at the end that attaches to the starter relay. this will bypass the bulkhead somewhat, and the amp gauge will just show the discharge used by lights, etc. when running. a volt gauge should then be installed so you can keep track of your charging system. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
