Re: Front steering linkage, suspension assembly help needed
[Re: ThermoQuad]
#3231828
05/08/24 08:59 PM
05/08/24 08:59 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
I'll get a measurement hopefully in the next day or so and I've read more on the pitman arms and apparently, the manual and power are the same so I'll try putting my other one from the power box on for comparison.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
[Re: 73cuda340]
#3234688
05/24/24 11:47 AM
05/24/24 11:47 AM
73cuda340
clarks summit pa
I measured the steering arm differences and they are only 1/8" difference from drivers side to passenger side. I also just noticed that the pitman arm now hits the header tube as well. I'm figuring at this point it has to be either the pitman arm or the pst steering box.
[Re: 73cuda340]
#3234718
05/24/24 01:23 PM
05/24/24 01:23 PM
73cuda340
clarks summit pa
I installed a shim on each of the top steering box holes and the pitman arm and steering rod bolt both clear now, but the centerlink still isn't parallel with the ground. Is this a problem? I don't want to add a ton of shims to correct it if it won't cause any issues.
