Re: Enclosed car trailersI
[Re: Rhinodart]
#3225777
04/08/24 12:24 PM
04/08/24 12:24 PM
Posts: 3,530 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
My advice would be to be sure and get 16" wheels and tires, at least 24 foot and a winch. Overkill for what he needs. I did look at a set of 16" 6-bolt aluminum wheels and tires for $1000 yesterday, just can't justify the cost. As much as he is going to use it the upgrade wouldn't be cost effective, he doesn't need 5200 lb axles either... As someone who has towed a whole lot I respect your opinion, however after he blows out a few 15" tires he might feel different, if buying new I don't think (but don't know) if it would be that much more. I recommended 24ft for resale value and the winch for convenience.
[Re: 340Cuda]
#3225794
04/08/24 12:56 PM
04/08/24 12:56 PM
Posts: 43,653 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
My advice would be to be sure and get 16" wheels and tires, at least 24 foot and a winch. Overkill for what he needs. I did look at a set of 16" 6-bolt aluminum wheels and tires for $1000 yesterday, just can't justify the cost. As much as he is going to use it the upgrade wouldn't be cost effective, he doesn't need 5200 lb axles either... As someone who has towed a whole lot I respect your opinion, however after he blows out a few 15" tires he might feel different, if buying new I don't think (but don't know) if it would be that much more. I recommended 24ft for resale value and the winch for convenience. I agree with all your statements, if he was planning on towing a lot. I did blow out 4 tires last year while towing 120K miles, but most of that was on me for knowing the tires needed replaced. The one thing I do recommend is to inflate your tires cold 10 lbs more than the tire rating says, and keep them covered when the trailer is sitting... ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) If you but a trailer for resale then you are doing it wrong, though most enclosed trailers lose little value over the years. 24' is always the best bet...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#3225827
04/08/24 02:39 PM
04/08/24 02:39 PM
Posts: 851 Avondale AZ
Prodart440
Avondale AZ
I have used a 24ft Interstate for the last 10 years to haul my 68 road runner. It has worked flawlessly!
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: moparx]
#3226144
04/09/24 08:43 PM
04/09/24 08:43 PM
Rhinodart
Rhinotruck
Rhinotruck
Then there are some of us who actually wear them out, and still blow them because we are pushing too hard... are these blowouts related to your transmission woes ? [asking for a fiend, er, i mean, friend.......... ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif) ] Nope, totally independent of my tranny problems. I am just ahead of the curve on tranny's... ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif)
A-Body's RULE!
[Re: Rhinodart]
#3226270
04/10/24 01:26 PM
04/10/24 01:26 PM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
Just for comparison...as far as fuel mileage.
2005 Chevrolet 2500HD 4x4 6.0 GAS engine. unloaded (no trailer) normal driving...12 mpg loaded OPEN car trailer...10-11 mpg and felt like it had plenty of power. loaded 24' ENCLOSED trailer...around 5 mpg (at best) and felt like it had NO power.
2006 GMC 2500HD 4x4 Duramax diesel unloaded (no trailer) normal driving...16-17 mpg never calculated it w/ the open car trailer b/c I rarely use it anymore. loaded 24' ENCLOSED trailer...10 mpg and has plenty of power. Feels like it would still drag it 80 mph w/ 4 flat tires. The truck is basically stock, no programmer/tuner or anything. I don't tend to drive very easy when pulling the trailer. It has the power so I like to use it, lol.
When I say the enclosed is loaded, it has my 3500 lb. cuda, a golf cart, plus tools and other crap in it.
[Re: an8sec70cuda]
#3226457
04/11/24 11:20 AM
04/11/24 11:20 AM
Posts: 21,539 It's a dry heat
gtx6970
It's a dry heat
When I say the enclosed is loaded, it has my 3500 lb. cuda, a golf cart, plus tools and other crap in it. My truck is a 2012 Ram quad cab, Hemi auto, 3.92 rear axle. Gets right at 18-20 mpg empty I rented an open U haul trailer last year to pick up a car in Ca averaged right at 14mpg. and you could barely notice it was even there. my trip back form Ky with this enclosed and a partial load is getting in the 8-10 range It never felt like it didnt have any power or did it have any trouble pulling or stopping it
![Name: on-Trailer.jpg
ID: 505880 on-Trailer.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/505880/filename/on-Trailer.jpg)
[Re: gtx6970]
#3226465
04/11/24 11:53 AM
04/11/24 11:53 AM
an8sec70cuda
The newer trucks are much better power-wise than the older stuff I drive. I was just sharing that for comparison reasons. I have a 2017 Ram 1500 hemi I drive daily, but after towing the open trailer w/ it, I don't feel it would handle my enclosed very well.
[Re: an8sec70cuda]
#3226851
04/13/24 11:10 AM
04/13/24 11:10 AM
Posts: 13,204 aZLiViN
J_BODY
aZLiViN
Living in tire he77 (desert SW) there’s no WAY I’d ever settle for a 15” trailer tire again, but our environment and towing needs are different than what the OP is after. Race car, golf cart, summertime 150 degree + road temps and tire temps that’ll run in the 160s. 16” G rated tire at 100psi has been a game changer over us throwing away good appearing tires every two years not to mention the side of the road “fun” changing a tire and repairing the trailer Funny thing on the modern 1500 is some have an equal job rating as my old 01 2500 diesel…… A nice 3500 srw crew 8ft bed 17 came in on trade two years ago at work so even though I’d convinced myself that a 6.4 Hemi 2500 would probably suit our needs nicely, we replaced the 01 with another oil burner. I will say it’s an absolute joy to tow with.
[Re: Rhinodart]
#3227116
04/14/24 11:02 PM
04/14/24 11:02 PM
Posts: 8,414 Highland, MI.
Sunroofcuda
Highland, MI.
Rule #1, DO NOT buy an enclosed trailer manufactured in GEORGIA! Now having said that, what do you plan on bringing with you to shows besides you car? I have owned around 20 enclosed trailers in the last 35 years and tow for a living. My minimum is 24' for that, but I also have a 32' LQ trailer with a 20' garage and it is adequate for most anything and will work for a Roadrunner. Being that you tow with a 1500 I would consider a 20'-22' but if you plan on taking a grille, lots of chairs, a pop-up tent, and larger coolers then a 24' would be good. Trailers have gone nuts in pricing and you get what you pay for. Aluminum such as ATC, Featherlite, and Rance are the best out there and pricey! Some of the better non-aluminum are Load Trail, H&H, Sure Trac, Stealth, and Vintage/Millenium. There are dozens of brands, so do your homework! Rhino - are any of them air-ride yet?
[Re: Sunroofcuda]
#3227121
04/14/24 11:49 PM
04/14/24 11:49 PM
Rhinodart
Rhinotruck
Rhinotruck
Rule #1, DO NOT buy an enclosed trailer manufactured in GEORGIA! Now having said that, what do you plan on bringing with you to shows besides you car? I have owned around 20 enclosed trailers in the last 35 years and tow for a living. My minimum is 24' for that, but I also have a 32' LQ trailer with a 20' garage and it is adequate for most anything and will work for a Roadrunner. Being that you tow with a 1500 I would consider a 20'-22' but if you plan on taking a grille, lots of chairs, a pop-up tent, and larger coolers then a 24' would be good. Trailers have gone nuts in pricing and you get what you pay for. Aluminum such as ATC, Featherlite, and Rance are the best out there and pricey! Some of the better non-aluminum are Load Trail, H&H, Sure Trac, Stealth, and Vintage/Millenium. There are dozens of brands, so do your homework! Rhino - are any of them air-ride yet? These are real nice, saw them at the PRI show, expensive but worth it. https://maxxdtrailers.com/drop-n-load-trailers/They hade an enclosed trailer there, I think it had removable sides...
A-Body's RULE!
[Re: Rhinodart]
#3227163
04/15/24 10:26 AM
04/15/24 10:26 AM
Posts: 20,205 PA.
pittsburghracer
"Little"John
"Little"John
PA.
There have been some fairly priced ones on Facebook over the past two months for some reason. They need some fancying up but have lots of miles left in Them for 5000.00-5800.00
[Re: pittsburghracer]
#3227181
04/15/24 12:37 PM
04/15/24 12:37 PM
gtx6970
It's a dry heat
Ive been watching for a decent enclosed trailer out here for the better part of the last 6 - 8 months or more. Trailers in that price range either dont exist. If they do, They are gone instantly. Ive not seen anything under about $7000 around here for a 20 plus year old trailer . I called on a 2014 ish 22ft with V nose back in Jan listed for $8500 and it was gone in an hour With expenses I spent to go get it Im in mine for right about $5000 . I bought it from a long time friend of mine . It isn't my ideal length. But will do exactly what I need it to do this summer and next spring. Then will most likely,,,get resold.
[Re: gtx6970]
#3229208
04/25/24 08:37 PM
04/25/24 08:37 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Once you decide on a trailer. You will have to consider upgrades.
I drove flatbed tow truck for 5 years. Secured the cars on the bed with chains, wheel straps through the rims and wheel straps. Holding the car by the frame is the worst thing you can do to a car. It feels solid but when that bed or trailer hits bumps it will bang into the chains and oval out holes. If the car dips on the suspension, all good. When it extends up, it will smash into the chains so hard dirt and rust will be sitting on the bed to prove what happened.
E tracks to secure all 4 tires is the best method. Have 3 fail and the car will still be there. This is how all the manufacturers tow the new cars.
