Page 3 of 3 1 2 3
Re: Does anyone make a fuel sender that works?? [Re: TJP] #3233858
05/20/24 05:13 AM
05/20/24 05:13 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
73 empty and 10 full is correct for Ford and Chrysler in the era.
Angry white pureblood male
Re: Does anyone make a fuel sender that works?? [Re: ruderunner] #3235415
05/28/24 09:24 PM
05/28/24 09:24 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
Picked up a Tanks sender from Summit for 60 bucks hooked it externaly to get a idea of where the float is with the gauge seems to be fairly accurate so I installed it and but gas in the ride and the gauge reads to where I figured it would..so far I'm happy with it
Re: Does anyone make a fuel sender that works?? [Re: stinger] #3235434
05/28/24 11:14 PM
05/28/24 11:14 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Does that mean it reads correctly ? shruggy beer
Re: Does anyone make a fuel sender that works?? [Re: TJP] #3235686
05/30/24 05:29 PM
05/30/24 05:29 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
While not exactly for stock OE gas tanks, how is the accuracy of the Tanks Inc floatless and reed sending units? Holley also has a laser sending unit. Wonder if these are any better. Most gas tanks are tucked way up under, so using an EFI gas tank (minus pump of course) on a restoration build or one with carburetor, might be a solution to the sending unit issue.
1972 Dodge Challenger
Re: Does anyone make a fuel sender that works?? [Re: PLUM_72] #3236280
06/02/24 12:54 PM
06/02/24 12:54 PM
New Jersey Bada Bing
bremotorsports Offline
I have offered top quality fuel tank sender units for almost two decades, always from the same manufacturer. And everything else I offer follows this same philosophy.
With a couple hundred sold, I have had to replace exactly ONE!
Yes, mine are significantly more in terms of price, so the lesson here is this:
LIKE MOST THINGS IN LIFE, YOU GET WHAT YOU PAY FOR!
Sender units are found in Group 14 Fuel on my website.
www.billrolikenterprises.com
Bill Rolik
bremotorsports@verizon.net
201-394-5533 Cell/Text
Re: Does anyone make a fuel sender that works?? [Re: bremotorsports] #3236643
06/04/24 09:54 AM
06/04/24 09:54 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Bill Rolik
I looked at your website and I don't think your pricing is out of line. The concern really is not if the sender works (they all move the needle) it's if it is accurate. I'm going to try one of Bill's for my '67 GTX as so far nothing I've found for the '66-'67 B-bodies is accurate.
Page 3 of 3 1 2 3
