Page 3 of 7 1 2 3 4 5 6 7
Re: Help ID Radiator [Re: Mad-Max] #3241122
06/28/24 02:10 PM
06/28/24 02:10 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
cool - my local metal supplier also has large metal-working equipment, and was able to brake a perfect 3/4" lip across the front of my dash cover panel, and it turned out great - just some edge work and it'll basically be done.  Now there's tons of storage for any/all small gear, the radio, gloves, etc...and hey like 300 ducks - ha! (...no...)...
71 Demon (project): 318, A-833od, 8-3/4, 3.23's
14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s
52 Willys M-38 "Poncho"
Re: Help ID Radiator [Re: Mad-Max] #3241303
06/29/24 11:23 AM
06/29/24 11:23 AM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
nice fab work on the dash. up
beer
Re: Help ID Radiator [Re: moparx] #3241930
07/02/24 11:47 AM
07/02/24 11:47 AM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
thanks - I'm really diggin' how it's turning out -
Couple more with the defroster vents and GMR-25 in place - I'll have a couple dividers to keep items from sliding around, and of course end caps, but this is pretty much it -
...and here's my wheel, along with a simple way to re-center it after some full-hydro 'drift' wink
Re: Help ID Radiator [Re: Mad-Max] #3242173
07/03/24 01:07 PM
07/03/24 01:07 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
orbital valve and column linkage - tried to get the o.v. as far away from the exhaust manifold as possible -
final push [Re: Mad-Max] #3243030
07/08/24 12:37 PM
07/08/24 12:37 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
Got the glove box lid figured out, made another access port for the t-case linkage, pulled the body back off, and now am going front to back finishing everything I figured out over the last couple months, the first of which is taking the tranny to a local shop to be 're-sealed' - it's leaking many places and I'm going to have my tranny guy make those pesky problems go away once and for all.
Also, just before deciding to ditch the Dakota and build a Jeep, I started noticing a significant engine oil leak at the back of the block, and the good news is...as far as I can tell anyway...the oil leak was actually coming from the intake seal, and not the rear main...I think -
Re: final push [Re: Mad-Max] #3245014
07/16/24 11:56 AM
07/16/24 11:56 AM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
Ok - time to make stuff purty before final assembly -
Manifolds are sandblasted, and coated with POR-15 high-temp grey -
Frame/axle priming in work -
Re: final push [Re: Mad-Max] #3245246
07/17/24 10:48 AM
07/17/24 10:48 AM
moparx Offline
moparx  Offline
looks good ! up
however, i have been meaning to ask you for quite a while, how do you post more than four pictures at a time, when i was under the impression four was the limit ?
beer
Re: final push [Re: moparx] #3245259
07/17/24 11:29 AM
07/17/24 11:29 AM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
Thanks, and regarding the pic count...hell I dunno - I didn't know there was a limit. All of my pics are hosted on Imgur...if that helps...
Re: final push [Re: Mad-Max] #3248979
08/02/24 10:09 AM
08/02/24 10:09 AM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
...got a lot of prep/priming/painting done (using good ole' rustoleum rusty metal primer and satin black paint), including the frame n hardware, gas tank cover, Barnes 3/16 shield, and front axle. Gas tank, front axle & suspension are bolted in -
Re: final push [Re: Mad-Max] #3248980
08/02/24 10:10 AM
08/02/24 10:10 AM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
...think I read there needs to be just a smidge of toe-in, so I measured right at 3/16 -
was able to utilize the 4th (d-side) ram mount by welding half of it to the removable plate for diff cover access - worked great -
Re: final push [Re: Mad-Max] #3249003
08/02/24 11:35 AM
08/02/24 11:35 AM
moparx Offline
moparx  Offline
great progress ! up
beer
Re: final push [Re: moparx] #3249597
08/05/24 11:16 AM
08/05/24 11:16 AM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
360, 46rh, Atlas, and front shaft are in for good - rear 14b gets sprayed today.
We're heading to Moab in October and I'm gunnin' to have it ready (at a 'minimum' capacity) for that gig...but it's cool if it doesn't make it cuz I can still take the wife's big 08 JKU on 37s, and either way I'll just keep jammin' until it's ready.
Re: final push [Re: Mad-Max] #3249611
08/05/24 12:47 PM
08/05/24 12:47 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Goal dates are always good, they keep you moving towards them.
I am impressed with the amount of planning and the great craftsmanship you are putting into this project.
Keep posting, I'll keep following. Gene
Re: final push [Re: poorboy] #3249807
08/06/24 10:44 AM
08/06/24 10:44 AM
moparx Offline
moparx  Offline
me too !
beer
Armorall! [Re: moparx] #3257565
09/13/24 10:27 AM
09/13/24 10:27 AM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
alright - after a month of measuring/marking/cutting/grinding/drilling/welding/sanding...I have both sections of the belly armor ready for paint. The main core section 'interfaces' with the Barnes gas tank shield and carries the shield to the other side, and completely protects the t-case, and trans cooler, which I'm mounting behind the t-case. It's all 3/16" steel, including 20 feet of 2" strap to reinforce the long panels against 'caving in'.
The engine/trans shield 'interfaces' with the core shield, all connecting up on the trans crossmember. The entire thing is completely 'smooth' - no bolt heads or edges to catch on stuff - just the drain holes...if those really count.
Next, the exhaust goes right along the d-side along with a corresponding heat shield. I'll be tacking the exhaust together for good once I have some other hardware in place. Ok - pics -
Core Shield -
Re: Armorall! [Re: Mad-Max] #3257567
09/13/24 10:31 AM
09/13/24 10:31 AM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
Engine/Trans shield (about 1" of gap between the shield and oil pan(s)) -
Re: Armorall! [Re: Mad-Max] #3258438
09/17/24 05:11 PM
09/17/24 05:11 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
...one thing I neglected to fully evaluate was how to drop the belly shield without inducing undue stress to the trans cooler lines, so I decided to mount the cooler and lines to the chassis and have them 'hover' above the shield, making it much easier and less messy when I have to pull the shield. The main bracket is welded to the big rear support bracket, which is removable/bolts to the crossmember, which makes the whole bracket removable, making it possible to pull/service the t-case, etc. Still some finish work to do, but here it all is -
line clamps attached to a plate welded to the trans mount bracket -
...progress... [Re: Mad-Max] #3259964
09/25/24 10:10 AM
09/25/24 10:10 AM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
...ahhhh - love the smell of oil-based paint - always takes me back to my early days helping Dad and my bro-in-law paint the Jeep smile . Belly armor is primed and painted - should be ready to bolt it all up tomorrow -
...and if I ever flop on my side this will be the view 😁
ISSPRO fuel level float/sending unit installed - sanded the tank at the seal to smooth it out/help eliminate leaks - put Gasoila E-Seal on the threads and cranked the bolts tight into the collar, and it acts like studs and won't fall out if I ever need to service the float unit -
Re: ...progress... [Re: Mad-Max] #3259965
09/25/24 10:10 AM
09/25/24 10:10 AM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
Just an assembly tip - for those doing full hydro or any other application with a very shiny and perfect rod like shocks, etc., use a piece of leftover radiator or fuel line hose to protect the surface area from dirt, debris, and for sure welding slag -
Lastly, here's an interesting view under the 2bbl throttle body -
Re: ...progress... [Re: Mad-Max] #3260019
09/25/24 12:33 PM
09/25/24 12:33 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Man, your doing some really nice work.
The stuff I do is down and dirty get the job done stuff. You make my stuff look really crude. Keep going, its inspiring me to improve what I do.
