727 torqueflite high psi relief #3226929
04/13/24 08:00 PM
04/13/24 08:00 PM
Minnesota
TrackPack Offline OP
Minnesota
Did a 1966 torqueflite 727 come without the 3/8 ball/spring relief valve?
I was looking for an unmolested valve body to use in a rebuild and found a nice one in a 66 parts transmission. Surprised to see that there was no relief valve when I took it apart for cleaning?
Re: 727 torqueflite high psi relief [Re: TrackPack] #3227079
04/14/24 06:07 PM
04/14/24 06:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The relief ball didn't arrive until late '68.
The '66 VB had some issues , look for a crack shown in the pic below and, if you intend to do many manual 1-2 upshifts, an orifice restrictor shown by the red arrow needs to be drilled out to at least 1/8".
Re: 727 torqueflite high psi relief [Re: John_Kunkel] #3227106
04/14/24 09:53 PM
04/14/24 09:53 PM
Minnesota
Minnesota
Thanks for the reply!
Any advice on drilling out the restictor? Looks like any drilling will have to be done at an angle?
Re: 727 torqueflite high psi relief [Re: TrackPack] #3227179
04/15/24 12:30 PM
04/15/24 12:30 PM
moparx Offline
moparx  Offline
one can use a spare chuck and turn it with your hand, going up a couple drill sizes at a time, or use a cordless drill at a somewhat slow speed, [also a couple sizes at a time.]
lightly clamp the valve body in a vice, using two pieces of unmolested plywood [without dirt, metal chips, etc embedded in them] covered with two pieces of clean cardboard, will hold it at an angle that is comfortable for you to drill.
just be sure you don't use anything in the clamping process that will mark up the valve body.
beer
Re: 727 torqueflite high psi relief [Re: TrackPack] #3227184
04/15/24 12:40 PM
04/15/24 12:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I drill it at the original angle with a 1/8" bit then, when the bit goes through to the channel, I walk the bit up vertical to remove the remaining partition.
Re: 727 torqueflite high psi relief [Re: John_Kunkel] #3227252
04/15/24 06:29 PM
04/15/24 06:29 PM
Minnesota
Minnesota
Thanks for the help. Everything went well and she's back together.
Re: 727 torqueflite high psi relief [Re: TrackPack] #3227335
04/16/24 03:22 AM
04/16/24 03:22 AM
How does it drive now?
Re: 727 torqueflite high psi relief [Re: Cab_Burge] #3227385
04/16/24 08:58 AM
04/16/24 08:58 AM
Minnesota
Minnesota
Project car with a way to go yet. Good to have the trans done though!
Re: 727 torqueflite high psi relief [Re: John_Kunkel] #3227897
04/18/24 01:26 PM
04/18/24 01:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
John , what causes the valvebody to crack there ?
Re: 727 torqueflite high psi relief [Re: JohnRR] #3227901
04/18/24 01:59 PM
04/18/24 01:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I dunno, I've seen at least two crack in the same place. shruggy
Re: 727 torqueflite high psi relief [Re: John_Kunkel] #3227916
04/18/24 03:23 PM
04/18/24 03:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ok thanks , I'll be sure to look at that location if I'm into one that old.
