Re: Hard water
[Re: larrymopar360]
#3227716
04/17/24 02:20 PM
04/17/24 02:20 PM
Posts: 15,959 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Lots to consider. Seems diverting or setting up only certain faucets for softened water is a must. I never thought about salt content in water heater too although as mentioned they don't last long as it is. I don't know what to look for in our water report for the city. I probably need independent test. If anyone knows what specifically to look for on this report please advise... I'm certain it's hard water though. I can feel on my skin and just by the faucets, etc. https://www.melbourneflorida.org/de...ities/water-quality/water-quality-report
Facts are stubborn things.
Re: Hard water
[Re: larrymopar360]
#3227741
04/17/24 04:37 PM
04/17/24 04:37 PM
Posts: 4,861 Star Idaho
67vertman
Star Idaho
Lots to consider. Seems diverting or setting up only certain faucets for softened water is a must. I never thought about salt content in water heater too although as mentioned they don't last long as it is. I don't know what to look for in our water report for the city. I probably need independent test. If anyone knows what specifically to look for on this report please advise... I'm certain it's hard water though. I can feel on my skin and just by the faucets, etc. https://www.melbourneflorida.org/de...ities/water-quality/water-quality-report Hard water is usually defined as water, which contains a high concentration of calcium and magnesium ions. However, hardness can be caused by several other dissolved metals; those forms divalent or multivalent cations, including aluminum, barium, strontium, iron, zinc, and manganese. None of these are reported in your cites drinking water report. Getting a report on minerals which cause water hardness from your cities drinking water is possible. Although they may test for the minerals, they rarely report them to the public, you can contact them and ask directly if the water is hard. Without having to go too far out of your way, one of the easiest options for a hard water test is with a clear, clean, empty bottle with a cap, pure liquid soap and water right from your tap. Fill the bottle one-third full, add a few drops of pure liquid soap and shake vigorously for a few seconds. If there is a distinct lack of fluffy bubbles and the water appears cloudy and/or milky, your water is hard. Soft water would have copious bubbles, and the resting water at the bottom of the bottle would be clear. Keep in mind that because most soaps are formulated with detergents, they lather regardless of your water type. For the best results, use a basic soap, such as Castile, which is free of dyes, perfumes and detergents.
My Monster are real!
Living within your means makes life pretty easy.
Re: Hard water
[Re: 67vertman]
#3227753
04/17/24 05:40 PM
04/17/24 05:40 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Lots to consider. Seems diverting or setting up only certain faucets for softened water is a must. I never thought about salt content in water heater too although as mentioned they don't last long as it is. I don't know what to look for in our water report for the city. I probably need independent test. If anyone knows what specifically to look for on this report please advise... I'm certain it's hard water though. I can feel on my skin and just by the faucets, etc. https://www.melbourneflorida.org/de...ities/water-quality/water-quality-report Hard water is usually defined as water, which contains a high concentration of calcium and magnesium ions. However, hardness can be caused by several other dissolved metals; those forms divalent or multivalent cations, including aluminum, barium, strontium, iron, zinc, and manganese. None of these are reported in your cites drinking water report. Getting a report on minerals which cause water hardness from your cities drinking water is possible. Although they may test for the minerals, they rarely report them to the public, you can contact them and ask directly if the water is hard. Without having to go too far out of your way, one of the easiest options for a hard water test is with a clear, clean, empty bottle with a cap, pure liquid soap and water right from your tap. Fill the bottle one-third full, add a few drops of pure liquid soap and shake vigorously for a few seconds. If there is a distinct lack of fluffy bubbles and the water appears cloudy and/or milky, your water is hard. Soft water would have copious bubbles, and the resting water at the bottom of the bottle would be clear. Keep in mind that because most soaps are formulated with detergents, they lather regardless of your water type. For the best results, use a basic soap, such as Castile, which is free of dyes, perfumes and detergents. Good information, thank you! And I'll try that simple test.
Re: Hard water
[Re: 67vertman]
#3227765
04/17/24 07:26 PM
04/17/24 07:26 PM
Posts: 1,269 Nor here, Nor there
Dart 500
Nor here, Nor there
Lots to consider. Seems diverting or setting up only certain faucets for softened water is a must. I never thought about salt content in water heater too although as mentioned they don't last long as it is. I don't know what to look for in our water report for the city. I probably need independent test. If anyone knows what specifically to look for on this report please advise... I'm certain it's hard water though. I can feel on my skin and just by the faucets, etc. https://www.melbourneflorida.org/de...ities/water-quality/water-quality-report Hard water is usually defined as water, which contains a high concentration of calcium and magnesium ions. However, hardness can be caused by several other dissolved metals; those forms divalent or multivalent cations, including aluminum, barium, strontium, iron, zinc, and manganese. None of these are reported in your cites drinking water report. Getting a report on minerals which cause water hardness from your cities drinking water is possible. Although they may test for the minerals, they rarely report them to the public, you can contact them and ask directly if the water is hard. Without having to go too far out of your way, one of the easiest options for a hard water test is with a clear, clean, empty bottle with a cap, pure liquid soap and water right from your tap. Fill the bottle one-third full, add a few drops of pure liquid soap and shake vigorously for a few seconds. If there is a distinct lack of fluffy bubbles and the water appears cloudy and/or milky, your water is hard. Soft water would have copious bubbles, and the resting water at the bottom of the bottle would be clear. Keep in mind that because most soaps are formulated with detergents, they lather regardless of your water type. For the best results, use a basic soap, such as Castile, which is free of dyes, perfumes and detergents. The shower test works too! If it dont lather, its hard as a rock
Re: Hard water
[Re: Stanton]
#3227793
04/17/24 10:46 PM
04/17/24 10:46 PM
67vertman
Star Idaho
Well the OP has certainly come to the right place for expert advice !!! I did sleep in a Motel 6 last night.
Re: Hard water
[Re: ]
#3227845
04/18/24 09:14 AM
04/18/24 09:14 AM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
You can also soften your water with Potassium Chloride, which will not add Sodium to your water.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Hard water
[Re: Soopernaut]
#3227856
04/18/24 10:32 AM
04/18/24 10:32 AM
Posts: 2,779 St. Louis, Missouri area
Cometstorm
"Beat It"
"Beat It"
Lots of great information already given. Most of it right in target. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Do softeners add sodium to drinking water? Technically yes. Actuality is that it’s is so minuscule, the FDA rates it significantly LOWER than average untreated water across the country. Google; Do water softeners add sodium / salt to water. There’s tons of articles on the subject. Our eastern Missouri home was constructed 1991. Water heater gave up in the first year: corroded lower elements. We got our first water softener. It regenerated every night at 3 AM. That type of water softener was a salt hog. And it broke down and had to be replaced about every eight years. Roughly $1500 each replacement: parts/installation and haul away. About a year ago, and after a LOT of research, we went to an upper end (not top line) Culligan system. It only regenerates on demand useage. Our salt useage has been reduced by around 80%. That in itself is a huge improvement for wife and I. Total cost was around $3200. I forget what the warranty is exactly, but it is substantial. My advice: Deal with a dedicated and well reputed “water softener only” company. Although this is a 2020 video, I find it one of the best in water softener systems, and what to look for based in your individual needs: https://youtu.be/NYYYKglrKX4?si=1e9Agr3FN11TPlNmBest of luck! ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Hard water
[Re: Rhinodart]
#3228269
04/20/24 01:17 PM
04/20/24 01:17 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Thanks Cometstorm, good information. Besides the obvious damage I see to faucets and water heater, yes I can feel the difference on my skin. I have dry skin and have to use lotion after every shower (TMI? LOL). I could seriously go a week without washing my hair (I don't) and it would not be oily. I think I wrote earlier that I've traveled to places with soft water and a shower feels so different!
I have an excellent plumber and I'm going to ask him to refer me to a company.
Re: Hard water
[Re: Cometstorm]
#3228392
04/21/24 11:01 AM
04/21/24 11:01 AM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
Larry...Have you had a water heater change in the last few years? Hard water really hits them... And washing machine valves. Don’t ask me how I know! I had that happen, opened the door to the front loader and a bunch of water poured out. Thankfully the inlet valves are easy to replace and cheap. They just crust up with minerals and stop sealing.
Re: Hard water
[Re: tboomer]
#3228395
04/21/24 11:20 AM
04/21/24 11:20 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Larry...Have you had a water heater change in the last few years? Hard water really hits them... Yes actually that's kind of what prompted the question. I just replaced my WH and old one didn't last very long. Also faucets get restricted and need cleaning.
Re: Hard water
[Re: larrymopar360]
#3228426
04/21/24 03:15 PM
04/21/24 03:15 PM
Posts: 9,600 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
I must have ok water. Water heater is 32 years old and works as good as it did when new. Gas powered though. Washer is 32 as well and works good. I just probably jinxed myself.
STOP POTATO HATE!
Re: Hard water
[Re: Mr PotatoHead]
#3228430
04/21/24 03:50 PM
04/21/24 03:50 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I must have ok water. Water heater is 32 years old and works as good as it did when new. Gas powered though. Washer is 32 as well and works good. I just probably jinxed myself. WOW! The only thing I have that comes close to that age is my clothes washer. Old style, agitator and no digital controls and no water saving b.s. This thing actually cleans your clothes. It's pushing 20 years.
