Re: What makes a TH400 stronger than a 727?
[Re: Al_Alguire]
#3227490
04/16/24 03:18 PM
04/16/24 03:18 PM
Posts: 9,871 MI, usa
dvw
MI, usa
We also ran Dizusters turbo car (3575) with a brake and radials. Pretty much the same set up. Both cars have stock 65 output shafts, And 71-76 input shafts. Neither car ever hurt one. Dizusters snaped a pinion shaft and a Dyno -Tech drive shaft yoke. I've cracked 3 Dana pinions. Both cars have the shafts they were built with. Doug
[Re: dvw]
#3227604
04/17/24 06:25 AM
04/17/24 06:25 AM
Posts: 2,933 A shed in England
Tig
A shed in England
We've broken an O/P shaft, at the time the car was making around 880hp and weighed 3950ish (w/d). We had just put a new set of slicks on. We upgraded both the i/p and o/p shafts while it was apart. We got round the speedo issue going to a Dakota Dig dash with a GPS speedo.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: cudaman1969]
#3227624
04/17/24 08:55 AM
04/17/24 08:55 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Hope this isn’t too far off topic but a lot of guys run 904s in high horsepower cars, are parts more available for them than 727s? I know they can be run behind a big block but I think the adapters to do that are pricey but if money is no object is it a viable option?
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: Tig]
#3227633
04/17/24 09:28 AM
04/17/24 09:28 AM
Posts: 4,700 Wichita
GY3
Wichita
We've broken an O/P shaft, at the time the car was making around 880hp and weighed 3950ish (w/d). We had just put a new set of slicks on. We upgraded both the i/p and o/p shafts while it was apart. We got round the speedo issue going to a Dakota Dig dash with a GPS speedo. Yikes! Killed the sprag, too!
[Re: GY3]
#3227639
04/17/24 09:49 AM
04/17/24 09:49 AM
Tig
A shed in England
We've broken an O/P shaft, at the time the car was making around 880hp and weighed 3950ish (w/d). We had just put a new set of slicks on. We upgraded both the i/p and o/p shafts while it was apart. We got round the speedo issue going to a Dakota Dig dash with a GPS speedo. Yikes! Killed the sprag, too! It did !! You can see the weak point on the shaft was the oil feed. I also heard you can run 904 internals in a 727 case and that they are maintenance intensive, the reason to do it is likely to be it takes less H/P to run. A lot of the stock eliminator / super stock folk run them I'm told. A and A also do different ratios for the 727 but only 4 or 5, I was looking at a 2.28 1st gear set but it was cheaper to change the ratio in the rear (Dana 60). Try as I may, I could not find a 3.73 Ratio for a Dana in a pro gear and ended up using a street gear but that's another story.
[Re: Tig]
#3227650
04/17/24 10:43 AM
04/17/24 10:43 AM
Posts: 8,182 Plymouth, MI
Blusmbl
Plymouth, MI
Thanks Tig, that is helpful and definitely indicates at 900 hp and 4000 pounds the stock shafts are questionable. I think the other option would be to add a gear vendors, since it moves the speedo gear to after the 727 output shaft, but then it's adding even more weight to the car.
[Re: cudaman1969]
#3227663
04/17/24 11:13 AM
04/17/24 11:13 AM
Posts: 3,527 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
About gear ratios, doesn’t the Pro-Flight guys (A1?) make many different gear sets for a 727 Yes Pro-Trans has many different ratios for 727s and 904s. Unfortunately their website is way out of date (shows them still in CA) and has no information. Current contact information on Facebook, I guess you would have to call or email them for a list. 4256 Gholson Road, Waco, TX, United States, Texas (254) 749-5689 protrans@msn.com
[Re: 340Cuda]
#3227678
04/17/24 11:49 AM
04/17/24 11:49 AM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Yes there are many rations available for the 727/904 as well as the Th400. We have three different sets for the Vette, two transmissions and one extra gear set. Never hurt one ever, just different rations for differing weather conditions really, also why we have a number of stators and rear gears as well. Here is a link to the available gearsets for a TF. My 64 has a B-3 set 2.28/1.40/1.00 http://www.protransracing.com/images/PRO%20TRANS%20RATIO%20CHART.pdf
[Re: Al_Alguire]
#3227692
04/17/24 12:30 PM
04/17/24 12:30 PM
Posts: 325 Northport, al.
tvt59
Northport, al.
I've got a 904 that Keith Long at 727 specialist built for me. It's all roller ized., billet in and output shafts. 2.10 first gear. I really like it . And no problems so far. Best et 9.33 @ 141 mph. My car is two tenths quicker in the 1/4 over the 727 and almost one tenth quicker than with a power glide. But my car only makes 680 hp.
Nothing worth anything comes easy. It is always harder to do the right thing.
My Grandfather
[Re: dvw]
#3227704
04/17/24 01:33 PM
04/17/24 01:33 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Thats the 2nd shaft I've ever actualy seen that broke. The other was years ago in Dan Dye's blown alcohol modified street Cuda. Doug Monte Smith broke one years ago, running a load of nitrous and over 1,000 hp. That kind of a combo would provide the shock and or torque load strong enough to kill stock shafts. So depending on your combo, like mine, under 1,000 hp should live a while.
[Re: gregsdart]
#3227823
04/18/24 07:02 AM
04/18/24 07:02 AM
Tig
A shed in England
Thats the 2nd shaft I've ever actualy seen that broke. The other was years ago in Dan Dye's blown alcohol modified street Cuda. Doug Monte Smith broke one years ago, running a load of nitrous and over 1,000 hp. That kind of a combo would provide the shock and or torque load strong enough to kill stock shafts. So depending on your combo, like mine, under 1,000 hp should live a while. The 655 motor we are going to install is well into 4 figures and peak tq was almost 970lb/ft n/a. We are going to run it n/a and hopefully get it into the 8's. Then the plan to put a dual fogger on it, so a 9" type rear and a TH400 derived 'box are to be installed before we press the button. I'd like to keep it all mopar but I can't see either the 727 or the Dana 60 living with it all
[Re: Blusmbl]
#3227834
04/18/24 08:09 AM
04/18/24 08:09 AM
Posts: 4,075 Mo.
racerx
Mo.
Thanks Tig, that is helpful and definitely indicates at 900 hp and 4000 pounds the stock shafts are questionable. I think the other option would be to add a gear vendors, since it moves the speedo gear to after the 727 output shaft, but then it's adding even more weight to the car. Anyone here ever weigh a gear vendors unit? Also what makes a Turbo 400 more reliable than the 727 i think someone mention the bell housing being smaller than the 727.Are those shafts made of some sort of different material or what?
[Re: Blusmbl]
#3227843
04/18/24 09:03 AM
04/18/24 09:03 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Yours, Chip's, Tony, Al and Doug's experiences are promising. I should be around the 950 hp mark (but unfortunately at 4300 pounds...) in my car once the 540 is done, and am worried about the longetivity of any 727. Figure it needs the parts Doug has listed in it for sure and I'll also move to a LBA valve body, and debating the billet input and output shafts as well. Bummer with the billet output shaft though, it doesn't have the speedo gear provision and I'd hate to lose the speedo on a mostly street car. Nick...my 727 is still living, but I don't race my car very often. I killed a sprag a few years ago that took out the case. It let go mid wheelie in 1st gear, crunched the oil pan, but drove back in the trailer. It still has stock shafts in it, but it wouldn't surprise me if it broke one on its next pass. I have a 5 pinion steel planet, billet steel drum, non LBA Turbo Action transbrake, deep cast aluminum pan, etc. Nothing real fancy. My car will go 8.60s, but my best 60' is a 1.30 (may not have tripped the beam w/ the front tire?).There's a fine line b/t wheel spin and wheel stand w/ my combo. Scott Cheek still has a 727 in his blue '69 Dart. Wedge w/ one fogger. He's been 1.15 sixty foot I believe.
[Re: turbobitt]
#3227884
04/18/24 12:24 PM
04/18/24 12:24 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
Stock TH400 can handle some power if they are properly prepped but they do have there weaknesses with stock componentry like anything else. Where one may consider them better is that they have a stack-shift strategy where on every shift a new clutch pack is engage without having to disengage or have a timed shift. That makes the shift quality superior over a TF727/904 that always have a timed shift and no matter what, you have to deal with some degree of overlap. This is of course no correlation to overall strength.
Just to note some of the mechanical differences. The TF727 has bigger clutches and can run under significantly lower pressures than a TH400. The stock TH400 intermediate sprag or roller clutch(depending on model year and how it was equipped) is a failure point, even with the better 32 element sprag. The TH400 intermediate band is useless in all performance applications and is often removed defeating any compression braking in 2nd. TH400 and TH727 low reveres band are probably about the same capacity based on surface area,
AG. I don't buy that they are faster because of the shift sequence, 727 just apply the 2nd gear band to go from 1st to 2nd and it is just a matter of how fast (hard) you want it to shift (unless your running low band apply), good 727s can shift 2nd to 3rd in a matter of milliseconds so even if a TH400 did it slightly faster your not going to be able to tell the difference from that one single shift on a time slip. The engine can be spaced out for a bigger converter, there are some gear ratios available for the 727 so unless you really really need a ratio that is not available then the TH400 isn't really any faster. The only reason I see is if you absolutely need the SFI case and guys with typical 700 HP or less don't need it. I slept at a holiday in once upon a time so I definitely know what I am talking about.
[Re: HotRodDave]
#3227903
04/18/24 02:11 PM
04/18/24 02:11 PM
Posts: 25,960 Rio Linda, CA
John_Kunkel
Rio Linda, CA
AG. I don't buy that they are faster because of the shift sequence, 727 just apply the 2nd gear band to go from 1st to 2nd and it is just a matter of how fast (hard) you want it to shift (unless your running low band apply), good 727s can shift 2nd to 3rd in a matter of milliseconds so even if a TH400 did it slightly faster your not going to be able to tell the difference from that one single shift on a time slip. It's not all about the quickness of the shift, the 727's release/apply sequence requires some overlap to prevent RPM flareup...overlap produces more component wear than simply progressively applying clutches.
[Re: HotRodDave]
#3227917
04/18/24 03:25 PM
04/18/24 03:25 PM
an8sec70cuda
700 hp or less has no place in this conversation. You don't need anything other than a slightly beefed up 727 for that power level. Traction shouldn't be an issue no matter what tire or suspension you have for only 700 hp.
[Re: Al_Alguire]
#3227931
04/18/24 04:29 PM
04/18/24 04:29 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
AS said its more the availability of aftermarket parts. There are many parts out there to make a 727 live at that power level. With a TH400 there are just more options, kinda like a BBC vs a BBM. Both capable of making power one just has many more options. The one thing you cannot get for a 727 is an SFI case, to me that s a big deal. FWIW my 64 Savoy has a 727 built by Joels on Joy, it makes north of 1000hp. From what I've been told torque is the larger issue with a TF than raw HP. The Vette has an A1 built 727 and it makes a tick over 1100hp. They are both very nice pieces but are not a budget friendly one. You are correct it's the torque that is the issue vs. the HP level. That said the diesel market is building 47/48RE's that handle over 2000 lb/ft of torque so it's doable , an SFI case would be nice though.
