What makes a TH400 stronger than a 727?
#3227368
04/16/24 06:17 AM
04/16/24 06:17 AM
Posts: 4,699 Wichita
GY3
Wichita
Everyone says to "upgrade" to a TH400 or PG once you get over 1000 HP. Other than the obvious things like the availability of aftermarket SFI cases like the Reid, what makes the GM units better?
Re: What makes a TH400 stronger than a 727?
[Re: racerx]
#3227373
04/16/24 06:54 AM
04/16/24 06:54 AM
Posts: 4,075 Mo.
racerx
Mo.
[Re: racerx]
#3227379
04/16/24 08:21 AM
04/16/24 08:21 AM
Posts: 761 Southington Ct.
turbobitt
Southington Ct.
Stock TH400 can handle some power if they are properly prepped but they do have there weaknesses with stock componentry like anything else. Where one may consider them better is that they have a stack-shift strategy where on every shift a new clutch pack is engage without having to disengage or have a timed shift. That makes the shift quality superior over a TF727/904 that always have a timed shift and no matter what, you have to deal with some degree of overlap. This is of course no correlation to overall strength.
Just to note some of the mechanical differences. The TF727 has bigger clutches and can run under significantly lower pressures than a TH400. The stock TH400 intermediate sprag or roller clutch(depending on model year and how it was equipped) is a failure point, even with the better 32 element sprag. The TH400 intermediate band is useless in all performance applications and is often removed defeating any compression braking in 2nd. TH400 and TH727 low reveres band are probably about the same capacity based on surface area,
AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: GY3]
#3227381
04/16/24 08:26 AM
04/16/24 08:26 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
I have no comment really on the strength aspect, just always heard they'll handle more power reliably. The biggest thing I see is gear ratios. Once you make 1,000+ HP (especially on a small tire), you need a lot less starting line ratio. Not many options w/ a 727.
[Re: an8sec70cuda]
#3227386
04/16/24 08:59 AM
04/16/24 08:59 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
The aftermarket makes it stronger and a better option. The SFI Case is a HUGE bonus.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3227388
04/16/24 09:08 AM
04/16/24 09:08 AM
an8sec70cuda
And the converters are better. There is more room in the chevy style bellhousing for a larger/thicker converter. High hp applications can utilize that.
[Re: an8sec70cuda]
#3227399
04/16/24 09:45 AM
04/16/24 09:45 AM
Posts: 9,871 MI, usa
dvw
MI, usa
In my experience up to about 900 hp has been good.The aluminum drum won't come apart. Parts I think are a must at higher power level? A good front drum, steel front planet, good quality valve body, 518 deep pan with a long enough extention to get the filter at the bottom, reinforced band strut, 3.8 or 4.2 lever, solid rod front servo or shimmed solid late servo, lube hole for the sprag. Just took mine down for service as there was a few pieces of low roller clutch spring in the pan at about 250 runs. It does not use no low band apply. It shakes the tires once in awhile, so regular maintenance. New inner race, spring set, and a filter. Ready to go back in service. The band has been in the trans for over 700 passes, the clutches for over 250. In fact the old front clutch frictions and steels were moved to the rear clutch last time around. No metal on the filter either. If you need less 1st gear ratio or a aftermarket case at a higher power level? Then it's time for a 400. Doug
[Re: DoubleD]
#3227409
04/16/24 10:46 AM
04/16/24 10:46 AM
Posts: 4,696 On the parachute mount
n20mstr
Its not a matter of whats stronger, its a matter of whats better supported by the aftermarket. TH400 is like the 9" rear, there are tons of stuff availible , from case to gear sets. When i switched to a t400 the converter was literally 400.00 cheaper. Seriously i priced the same converter for a t400 and a 727, Best move i ever made becasue there is so many parts availible and the technology of so many people using a t400 now trickles down
I know I know its hard for people to accept but who cares whats stronger, i care about what WORKS the best
....BAD A$$ STREET CAR.....
[Re: GY3]
#3227412
04/16/24 10:50 AM
04/16/24 10:50 AM
n20mstr
Everyone says to "upgrade" to a TH400 or PG once you get over 1000 HP. Other than the obvious things like the availability of aftermarket SFI cases like the Reid, what makes the GM units better? Brad Watt (A93demon) still runs a 727 in his demon. He has been in the 4's at 3200? lbs so i would say he making over 1000. He does leave in second gear so that solves the gear issue , 727 is just as strong as a th400 , but the aftermarket for the th400 is way better, thats really all it is
[Re: n20mstr]
#3227421
04/16/24 11:15 AM
04/16/24 11:15 AM
GY3
Wichita
I know I know its hard for people to accept but who cares whats stronger, i care about what WORKS the best Totally agree! I tire of the "KEeP iT aLl MopAr" crowd when most of their engine is filled with aftermarket parts anyway!
[Re: GY3]
#3227427
04/16/24 11:31 AM
04/16/24 11:31 AM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
AS said its more the availability of aftermarket parts. There are many parts out there to make a 727 live at that power level. With a TH400 there are just more options, kinda like a BBC vs a BBM. Both capable of making power one just has many more options. The one thing you cannot get for a 727 is an SFI case, to me that s a big deal. FWIW my 64 Savoy has a 727 built by Joels on Joy, it makes north of 1000hp. From what I've been told torque is the larger issue with a TF than raw HP. The Vette has an A1 built 727 and it makes a tick over 1100hp. They are both very nice pieces but are not a budget friendly one.
[Re: GY3]
#3227431
04/16/24 11:46 AM
04/16/24 11:46 AM
Posts: 2,933 A shed in England
Tig
A shed in England
I know 3 mopar racers that switched to TH400's and improved et. I don't know if this was due to a better converter or if the TH400 is more efficient? The best improvement in one of those cars was almost 2 tenths, motor and rear was untouched, all mid to low 9 sec cars. Anyone else had the same result ?
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3227460
04/16/24 01:39 PM
04/16/24 01:39 PM
Posts: 8,182 Plymouth, MI
Blusmbl
Plymouth, MI
Yours, Chip's, Tony, Al and Doug's experiences are promising. I should be around the 950 hp mark (but unfortunately at 4300 pounds...) in my car once the 540 is done, and am worried about the longetivity of any 727. Figure it needs the parts Doug has listed in it for sure and I'll also move to a LBA valve body, and debating the billet input and output shafts as well. Bummer with the billet output shaft though, it doesn't have the speedo gear provision and I'd hate to lose the speedo on a mostly street car.
[Re: GY3]
#3227466
04/16/24 01:59 PM
04/16/24 01:59 PM
Posts: 25,949 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Since the subject is "stronger", another thing not often mentioned is the case. The TH400 has a "wrap around" case where the 727 is wide open at the bottom...this makes the 727 case more susceptible to flexing under torque and this can affect the internal component's alignment.
[Re: racerx]
#3227471
04/16/24 02:15 PM
04/16/24 02:15 PM
Al_Alguire
Las Vegas
Very surprise how was the fit Well everythitn gin this car is tight.,Its a shorty version. FWIW we had a TH210(TH400) in the car before the Proflite. It is much quicker with the Proflite hands down not even close. My guess is if someone picked up with a 400 in a non power adder deal they did not have a good work 727 with the right parts for the combo.....
