Re: Anyone here use SpeedMaster products?
[Re: mshred]
#3226779
04/12/24 08:50 PM
04/12/24 08:50 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
I have a set of their assembled heads and stainless rockers going onto a stock bottom end budget 360 build for my wagon. Hoping to have it running by late May, just waiting on some parts right now to finish the motor.
I had their air gap copy manifold and returned it after reading it leaves close 30hp on the table compared to a real air gap...Ended up with a single plane instead for my build, but some parts don't justify the savings benefit in my opinion. I was going from 318 iron heads with 1.77" intake valves that I sold for $300 local, so the $900 for the assembled Speedmaster heads were a no brainer, and so far on disassembly they have checked out okay. I had that air gap intake on a stock stroke 318 enginemasters build that I bought that pumped out 477 horsepower. Under 10.5 compression, pump gas, flat tappet cam, etc, etc. Ran mid 11’s in a 3400 pound car with a smaller camshaft than was used in the competition. Those intakes may well make less power, but they make more than enough for 95% of the guys who are going to run a dual plane to begin with. That little motor I had more than proved it. Makes me wonder why the two extremely sharp guys who built this motor and took it to the competition left 30 horsepower on the table. Hmmm https://www.motortrend.com/how-to/0901phr-mopar-318-magnum-engine/
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: fbs63]
#3226848
04/13/24 10:43 AM
04/13/24 10:43 AM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
In my experience the off shore heads don't make the power. Even if you get bare heads and do a good valve job, porting and quality parts they are down 30-40 hp on an engine dyno. They must cut corners with the casting cores in the ports and chambers. They just don't fill the cylinder the same. Lol. Thanks I needed a great laugh 😂
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: AndyF]
#3227474
04/16/24 02:16 PM
04/16/24 02:16 PM
Posts: 21,738 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
I would never buy a set of their heads but obviously some people do. I will tell you that you should never, ever buy a SpeedMaster 8 stack setup. I had a customer buy that setup and then he asked me to tune it. I told him it couldn't be tuned. Saving money was the reason I bought them. buying and rebuilding core heads $1500. Buying Edelbrock heads and having to go through them because of 'Edelbrock issues' $2500. So for less money, I got heads that I could have the shop look at and not worry about. If the motor only makes 300'ish hp with those head I'm fine with that for a street motor. Now I got to find cheap roller rockers and pushrods for it.
[Re: B3422W5]
#3227649
04/17/24 10:40 AM
04/17/24 10:40 AM
Posts: 3,433 Toronto
mshred
Toronto
I had their air gap copy manifold and returned it after reading it leaves close 30hp on the table compared to a real air gap...Ended up with a single plane instead for my build, but some parts don't justify the savings benefit in my opinion. I was going from 318 iron heads with 1.77" intake valves that I sold for $300 local, so the $900 for the assembled Speedmaster heads were a no brainer, and so far on disassembly they have checked out okay. I had that air gap intake on a stock stroke 318 enginemasters build that I bought that pumped out 477 horsepower. Under 10.5 compression, pump gas, flat tappet cam, etc, etc. Ran mid 11’s in a 3400 pound car with a smaller camshaft than was used in the competition. Those intakes may well make less power, but they make more than enough for 95% of the guys who are going to run a dual plane to begin with. That little motor I had more than proved it. Makes me wonder why the two extremely sharp guys who built this motor and took it to the competition left 30 horsepower on the table. Hmmm https://www.motortrend.com/how-to/0901phr-mopar-318-magnum-engine/ Why would you compare a stock intake vs one they massaged for an engine masters competition? That's a bit silly... I agree that the intakes for 90% out there are fine, but if I can find a used version of the real thing which is actually better as cast, then why not? Unfortunately, used small block mopar cylinder heads aren't easy or cost effective to find used where I am, or I would have sprung for a used set of edelbrocks or better.
[Re: ZIPPY]
#3227673
04/17/24 11:37 AM
04/17/24 11:37 AM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Black Friday sale every year. 40% off everything so heads set up with hydraulic roller springs cost around 733.00 a pair. 277.00 each bare.
[Re: pittsburghracer]
#3227969
04/18/24 09:40 PM
04/18/24 09:40 PM
Posts: 12,289 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Speedmaster. Part number prefix PCE. Pro Comp Electronics. Remember them? Pirates from way back.
Doesn't matter. Looks like Speedmaster has been scrubbed from Summit and Jegs. Probably afraid of the legal ramifications of selling the crap. I guess guys will have to go to Amazon, eBay and other quality retailers for their products moving forward.
[Re: CMcAllister]
#3227979
04/18/24 10:17 PM
04/18/24 10:17 PM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Doesn't matter. Looks like Speedmaster has been scrubbed from Summit and Jegs. Probably afraid of the legal ramifications of selling the crap. I guess guys will have to go to Amazon, eBay and other quality retailers for their products moving forward. I get mine shipped right from Speedmaster79. Gonna finish a set this weekend and start porting another set by Monday. 2.055 valve so they will flow 308-315cfm when finished.
[Re: CMcAllister]
#3228026
04/19/24 09:28 AM
04/19/24 09:28 AM
Posts: 6,616 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Doesn't matter. Looks like Speedmaster has been scrubbed from Summit and Jegs. Probably afraid of the legal ramifications of selling the crap. I guess guys will have to go to Amazon, eBay and other quality retailers for their products moving forward. I think this may have something to do with that... Kevin https://youtu.be/9dsHrSq8pso?si=B_dN-tT7YlW3nuVf
#3228036
04/19/24 10:59 AM
04/19/24 10:59 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Doesn't matter. Looks like Speedmaster has been scrubbed from Summit and Jegs. Probably afraid of the legal ramifications of selling the crap. I guess guys will have to go to Amazon, eBay and other quality retailers for their products moving forward. I get mine shipped right from Speedmaster79. Gonna finish a set this weekend and start porting another set by Monday. 2.055 valve so they will flow 308-315cfm when finished. Eddy clones? Decent? Seats fall out? Guides out of whack? Leak water? Anyone try to weld on them?
[Re: CMcAllister]
#3228043
04/19/24 11:09 AM
04/19/24 11:09 AM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Doesn't matter. Looks like Speedmaster has been scrubbed from Summit and Jegs. Probably afraid of the legal ramifications of selling the crap. I guess guys will have to go to Amazon, eBay and other quality retailers for their products moving forward. I get mine shipped right from Speedmaster79. Gonna finish a set this weekend and start porting another set by Monday. 2.055 valve so they will flow 308-315cfm when finished. Eddy clones? Decent? Seats fall out? Guides out of whack? Leak water? Anyone try to weld on them? I’d rather run what I can afford and race weekly rather than not being able to race again. I like racing to much to sit at home.
[Re: OUTLAWSSAA]
#3228081
04/19/24 12:51 PM
04/19/24 12:51 PM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’d rather run what I can afford and race weekly rather than not being able to race again. I like racing to much to sit at home. So do you condone what Speedmaster did to this guy in the name of getting cheap parts? [/quote] Absolutely not and I’ve said so on several posts on several forums. If this went down exactly as posted someone should be on a slow rowboat to China.
#3228120
04/19/24 04:36 PM
04/19/24 04:36 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
I’d rather run what I can afford and race weekly rather than not being able to race again. I like racing to much to sit at home. So do you condone what Speedmaster did to this guy in the name of getting cheap parts? Absolutely not and I’ve said so on several posts on several forums. If this went down exactly as posted someone should be on a slow rowboat to China. That's some funny stuff coming from one of the biggest of a company that sent an ebrock head to china ... along with a 906 ... and said ... make this look like that on the outside ...
Mainstream Media is the new Pravda
[Re: JohnRR]
#3228129
04/19/24 05:17 PM
04/19/24 05:17 PM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
A. Originally Posted by pittsburghracer Originally Posted by pittsburghracer Originally Posted by OUTLAWSSAA
That's some funny stuff coming from one of the biggest bow of a company that sent an ebrock head to china ... along with a 906 ... and said ... make this look like that on the outside ...
John RR mouth you are one of my favorites. Just kidding. Lol Did you ever even own a race car. You worked at a dodge dealer or something didn’t you. Lol 😂
#3228130
04/19/24 05:29 PM
04/19/24 05:29 PM
Posts: 10,049 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
pittsburghracer what changed your views on these heads? You used to be 100 percent against them and really the castings have been the same for a long long time. There early cnc heads cut the guides way down but they stopped doing that.
Have you started to race weekly as on here you seemed to race a few times a year unless your getting out more which would be great or is weekly like two weeks in a row at times?
STOP POTATO HATE!
[Re: Mr PotatoHead]
#3228132
04/19/24 05:55 PM
04/19/24 05:55 PM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Have you started to race weekly as on here you seemed to race a few times a year unless your getting out more which would be great or is weekly like two weeks in a row at times? Back when pro comp owned the company I shied away from them. A forabodiesonly member shared his results then for the last three years over bought multiple set during the 40% off sale. I started porting heads after I stopped enjoying it years ago only doing my own. I doubled my porting prices up to 850.00 and I’m enjoying it again probably porting 15-20 sets of Smallblock Mopar Speedmaster heads. The only issue I’ve found so for was one intake guide was .003 over sized. These heads will easily support 600 plus horsepower. Their cnc program with only get you in the 280-285cfm area. Ohh and I never really post about racing on this site anymore but attended five big money races last year and ran 15 races at those events alone. So yes I race more than most.
