Page 3 of 3 1 2 3
440 w/Edelbrock performer RPM heads [Re: tgt51] #3233999
05/20/24 05:38 PM
05/20/24 05:38 PM
Central US
grancuda Offline
grancuda  Offline
Central US
1971 440 Engine
Runs great, fresh top end & cam with 1000 miles, selling as long block with intake & C-body pan. Still in car & can hear run.
Stock Forged Crank
Stock Forged Rods
Balanced
TRW Forged pop-up 60 over pistons
ATI damper
Edelbrock Performer RPM heads 84cc
Crane gold aluminum roller rockers
New Mancini shafts
Comp Solid Flat Tappet Cam XS282S
Advertised Duration: 282 int./290 exh.
Comp Solid Lifters
Weiand Single Plane with polished runners
4,800 OBO
Located 25 miles W. of Tulsa OK
1967 Barracuda Formula S 383
1967 Chevy C10 Short Stepper
1980 Macho Power Wagon LWB 318
2021 Toyota Supra
1967 383 nearly NOS flywheel [Re: moparts] #3234173
05/21/24 08:15 PM
05/21/24 08:15 PM
Mattituck NY.
FJ6AAR Offline
FJ6AAR  Offline
Mattituck NY.
**SOLD**
Hi all., I have a 130 tooth flywheel that came off a 1967 383. This engine was used in a college on a dyno for 50+ years. The pressure plate and disc was installed by Chrysler in 1967 and was never released until I unbolted it last year. The clutch disc was connected to a water flow meter that would add load to the engine. This is as close to an NOS flywheel as you will find. If you look closely at the photos not only can you still see the lines from the milling machine but you can also see the halo imprint left by the clutch disc in the surface as it was pressed together and never released for 50+ years. I'm asking $150.00 plus shipping. Good old fashioned postal money order only or cash in person. Please PM me here for fastest response. Thanks for the ad Moparts! Rob
**I will trade even for one nice original and never cut 426 Hemi connecting rod - looking for a perfect original**
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
Holley list 4669 1971 440+6 manual center carb [Re: FJ6AAR] #3234721
05/24/24 01:45 PM
05/24/24 01:45 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Nice original Holley list 4669 440-6 center carb for 4 speed application dated 2040 or July 1970. Nice piece for resto. $525+ shipping from Mi 48837. Message me for more info. Joe 517-243-7115
SOLD!!!!!!!!
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
1971 Holley 4670 440-6 center carb dated 9/70 [Re: 70gtx440dana] #3234722
05/24/24 01:47 PM
05/24/24 01:47 PM
Lansing, MI
Lansing, MI
I have a very nice 1971 Holley automatic 440-6 #4670 center carb dated 2530 (9/70). Would look perfect on a survivor car. Or, restore for concourse. $600+ shipping from MI 48837. PM me for more info. Joe 517-243-7115
SOLD!!!!!!!!
4.500 KB billet crank $2000 [Re: 70gtx440dana] #3234908
05/25/24 02:02 PM
05/25/24 02:02 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
Crank is in very good shape but does need to be turned 10/10, it's standard now. Mopar rod journals, not chevy. 8-bolt flange.
I have two sets of Hemi pistons 4.375 bore that will go free with the crank if you want them, also a set of Brooks 88 rods 6.985"
I have lots of pics, just ask and ye shall receive.
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3235253
05/27/24 03:40 PM
05/27/24 03:40 PM
Long Island, NY
Jstern Offline
Jstern  Offline
Long Island, NY
Max Wedge Parts
Pair of 3447 Carburetors (both stamped L8 3447 SA) - $900
Early Cross Ram intake 2402726- $1,700
Head Pipe - Not sure the history on this, believe it is an early repro $500
Happy to provide more detailed pictures & description if you're interested. Please send a PM.
These parts will be available for pickup at Carlisle
Re: For Sale - Big Block Engine - 2nd Quarter [Re: Jstern] #3236871
06/05/24 06:57 PM
06/05/24 06:57 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
512/400 low deck for sale. carb to pan $15k obo
This is a fresh build and has 3 passes on it.. Its based off a stock 400 block with 440Source internals. It is pump gas friendly at 10.7:1 and has the upgraded ARP 2000 bolts, Ultra light crank, and their girdle as well. Block is not filled and not partially filled...
Indy 325 heads upgraded to 2.19 valves and Comp T&D 1.5 rockers, Morel Lifters, Indy ported 4500 low deck intake. 1050 4500 carb, Milidon oiling system, Indy timing cover and valley cover, ARP damper, Milodon chassis oil pan, & Summit valve covers. MSD distributor
Cam card available upon request.
Re: For Sale - Big Block Engine - 2nd Quarter [Re: Dragula] #3236881
06/05/24 08:05 PM
06/05/24 08:05 PM
Mooresville, NC
A70Runner Offline
A70Runner  Offline
Mooresville, NC
Comp steel roller rockers. The good: Only used to warm engine up in dyno and half a pull. The bad: 3 rockers are seized to the shaft due to to much spring pressure for these. Not sure how bad they are seized, haven’t tried to get them off. Also have surface rust in places due to being in my garage for years. Good if you need the others for spares or to fix.
$125 obo shipped to lower 48. PM me here on the board. Thanks!
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Re: For Sale - Big Block Engine - 2nd Quarter [Re: A70Runner] #3237084
06/07/24 06:08 AM
06/07/24 06:08 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
NOS USA MADE AUTOLITE/NIEHOFF MAJOR TUNE UP KIT PLUS WILL FIT;
1962-1963-1964-1965 DODGE 330,440,POLARA, CORONET 361-4BBL,383 HP,383 2 4BBL INLINE, 413 HP&MW,426SW,426MW WITH CHRYSLER/PRESTILITE/AUTOLITE DUAL POINT DISTRIBUTOR
1962-1963-1964-1965 CHRYSLER 300 413,426W WITH CAST IRON DUAL POINT
1962-1963-1964-1965 PLYMOUTH SAVOY,FURY,BELVEDERE, 361 HP 4BBL, 383 HP, 413 4BBL,2-4 MAX WEDGE, 426 4BBL STREET WEDGE, 426 MAX WEDGE WITH AUTOLITE/PRESTOLITE/CHRYSLER CAST IRON DISTRIBUTOR
INCLUDES AN NOS AUTOLITE IBK-1003, DISTRIBUTOR CAP,MADE IN USA LOGO ON TOP&IBK-1003 INSIDE. , A NORS NIEHOFF VACUUM ADVANCE , NOS AUTOLITE CONDENSER IBB-2042SS-1 2-32, NOS AUTOLITE POWER POINTS 1-42V, AND A NOS AUTOLITE ROTOR IBK-1016. BOTH THE CAP AND ROTOR WERE SOLD TO ATLAS BY PRESTOLITE/AUTOLITE ABD BOXED AND RESOLD UNDER THE ATLAS BRAND
ALL USA MADE PRODUCTS.. ALSO INCLUDES A NOS BLACK METAL 90 DEGREE PVC VALVE, NoVo ARROW TO MANIFOLD , WITH PAL NUT.$125
cowgerwilliam035@gmail.com
T&D Rockers NEW [Re: moparts] #3237596
06/10/24 01:48 AM
06/10/24 01:48 AM
Kansas
Thelma133 Offline
Thelma133  Offline
Kansas
Brand new T&D 1.5 rockers and shafts. We need to go with a 1.7 ratio. Will fit a 440-1, which is what we have, but I am told it will also fit a victor. Please confirm with T&D if used in that application. $1000.00 shipped and firm on price. These are over $1900 currently through T&D website.
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3238101
06/12/24 11:23 AM
06/12/24 11:23 AM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
1 Pr. very nice used Max Wedge 3447 carbs with matching date codes E2, $1600.00 for the pair (708)288-2879
parts 6-12-2024 035.JPG (211 downloads)
parts 6-12-2024 039.JPG (211 downloads)
parts 6-12-2024 038.JPG (211 downloads)
parts 6-12-2024 036.JPG (211 downloads)
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3238118
06/12/24 12:16 PM
06/12/24 12:16 PM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
1 set of 1969 440 SIX PACK 4-speed carbs for A12 Super Bee's & Road Runner's, nice used condition, selling as cores to restore $2500.00 for the set (708) 288-2879
parts 6-12-2024 008.JPG (205 downloads)
parts 6-12-2024 002.JPG (204 downloads)
parts 6-12-2024 005.JPG (205 downloads)
parts 6-12-2024 007.JPG (205 downloads)
Page 3 of 3 1 2 3
