1962-78 Automatic Transmission Torque Converter Drain Cover [Re: Memongo] #3226405
04/11/24 04:06 AM
04/11/24 04:06 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
1962-78 Automatic Transmission Torque Converter Drain Cover. Used, $10 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Call Steve 810-629-1097
Re: 1962-78 Automatic Transmission Torque Converter Drain Cover [Re: Memongo] #3226943
04/13/24 09:58 PM
04/13/24 09:58 PM
MI
MI Mopar Works Offline
MI
Brand new, only mocked up. Has been sitting on the shelf for a few years. Hays 85 311 clutch kit. Includes clutch disc, pressure plate, throw out bearing and pressure plate bolts. For 23 spline Chrysler 833 4 speed transmissions with 11 inch flywheel and bellhousing. List price is $489.99, mine is $300. Pick up preferred in Monroe, MI 48162 or will ship at buyers expense. Call or text Dave (734)624-2212
MI Mopar Works (734)624-2212
Parts Sales
Restoration and detailing of all kinds of mopar hardware
https://www.facebook.com/MIMoparWorks/
Re: Transmission adapter kit [Re: MI Mopar Works] #3228291
04/20/24 02:19 PM
04/20/24 02:19 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
SMR transmissions B/RB to small block transmission adapter kit. Part number SM 99-100P for a 6 bolt crank. New in box, the box has been opened but only for inspection, never installed the kit. for info: https://smrtrans.tripod.com/smrtransmissionsintro/id9.html $400 + shipping PM here or phone (716) 655-0625 ask for Gary or leave a message ( this is a land line)
Re: Mopar Transmission For sale - 2nd Quarter [Re: moparts] #3229264
04/26/24 08:16 AM
04/26/24 08:16 AM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
2468372 big block bellhousing with inspection cover. I bought this bellhousing to put a big block 4-speed in a 69 Dart but decided to keep the car an automatic as it originally came. The bellhousing has been media blasted and I put a coat of primer on it. $450 for both. Money orders only. No Paypal.
gt340 at yahoo.com
4 speed transmissions [Re: 6PAX] #3232287
05/12/24 10:30 AM
05/12/24 10:30 AM
Southwest Missouri
E
eenloe Offline
eenloe  Offline
E
Southwest Missouri
Mopar small block, big block, 23 spline, 18 spline, and overdrive rebuilding. Your unit rebuilt, trade in, or outright from my inventory. I have some era correct stuff to help with your special restoration or can build a non-era specific unit for you. I also have some good used bellhousings, shifters, and other parts. What I don't have, I can source to help with a conversion. All transmissions are thoroughly cleaned, painted, and rebuilt with American made parts. (main bearings, roller bearings, synchronizers, bushings and seals) See the attached flyer for contact information. This is a side line for me, so I work in spare time with flexible dead lines. Feel free to call or text me (Eric) to start a conversation. Thanks MOPARTS for the space.
SO MO Promo rev.jpg (685 downloads)
Contact Info.jpg (654 downloads)
Re: 4 speed transmissions [Re: eenloe] #3233960
05/20/24 02:33 PM
05/20/24 02:33 PM
Valpo Indiana
SMILINJOE Offline
SMILINJOE  Offline
Valpo Indiana
QuickTime scatter shield for small block. 6072 H-12
Hardware included.
$585 shipped lower 48
Re: 4 speed transmissions [Re: SMILINJOE] #3233962
05/20/24 02:42 PM
05/20/24 02:42 PM
Valpo Indiana
SMILINJOE Offline
SMILINJOE  Offline
Valpo Indiana
4-speed overdrive 23 spline for 66-70 B body. Took an A body trans and put B body output shaft on it.
Had it built for a 70 Coronet with a 383. Never got installed.
Has been rebuilt ready to install.
$1200 pick up only.
TKO TKX T56 B Body Cross Member [Re: Memongo] #3234007
05/20/24 06:10 PM
05/20/24 06:10 PM
West Palm Beach, Florida
Craig J Offline
Craig J  Offline
Not sure if this should be in the transmission section or not... if not please let me know and I will move it.
New and never installed.
Nothing wrong with it, I am just selling parts off my Plymouth project.
It is for a B Body with Tremec TKX, TKO or maybe also T-56. I would have had to add two more holes to use it in the Cuda or drill two more holes in the cross member.
Jegs sells it for 199 I will take 65 plus shipping.
Re: TKO TKX T56 B Body Cross Member [Re: Craig J] #3235279
05/27/24 07:36 PM
05/27/24 07:36 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
I have 4 727 small block transmissions pulled about 20 years ago,stored inside,all worked,selling as cores $100 each.Also have 1 904 small block,$100 and 1 727 big block pulled from a motorhome,short tail,no brake drum $200.Can deliver to Chryslers at Carlisle in July,call 315-717-1284
Hemi 4 speed [Re: moparts] #3236945
06/06/24 09:08 AM
06/06/24 09:08 AM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
Selling my 4 speed gearbox.
18 spline Hemi style input with bushed gears, Street style not slick - shifted
Direct Connection HD Aluminum Case with steel bushings, not the Feather Duster case. Excellent condition !
Direct Connection HD aluminum tail-housing . It long to fit the E and B- body chassis. Excellent condition !
This has been in my Cuda since 2005 backing up my Petty built Nascar Hemi. It has been on several Power Tour runs and all around Michigan. It has one issue, when in 3rd gear- if you get on and off throttle few times it will pop out of gear. I have a spare 3rd gear to go with the trans.
Otherwise it shifts very well. No noises or crunches, lol
$2500 plus shipping or you pick it up.
call or text if interested 734-231-070 five
Thank you for the ad!
Re: Hemi 4 speed [Re: Hemidavey] #3238218
06/12/24 06:20 PM
06/12/24 06:20 PM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
1970 B-body Pistol Grip shifter assembly for either bench seat or bucket seat cars without a console, it has the correct 1970 only shifter box, nice driver or survivor quality $850.00 (708) 288-2879
parts 6-12-2024 048.JPG (243 downloads)
parts 6-12-2024 046.JPG (243 downloads)
parts 6-12-2024 047.JPG (242 downloads)
Re: Mopar Transmission For sale - 2nd Quarter [Re: moparts] #3239369
06/19/24 04:52 PM
06/19/24 04:52 PM
NW Indiana USA
727specialist Offline
NW Indiana USA
727 big block transmission Reverse manual with a Griner band on transbrake valve body.
This is a fresh build. This is basically what it has in it contact me for more info. Keith 727 specialist Griner valve body owner and builder 219-718-3542
Thank you Moparts
DR2
727 Trans Brake Big block $3890.00
Griner Transbrake Band on valve body
TCS Billet drum
16 spring and roller overrunning clutch
Rollerised four pinion front planetary
Custom design ft and rear bands
Race ft and rear clutches
Governor body eliminator package
Modified oiling system in governor support
Bell housing vented and case notched
for easy access to the converter bolts
