Re: E body AC Water Valve
[Re: cataclysm80]
#322645
05/31/09 03:19 PM
05/31/09 03:19 PM
Posts: 2,592 None
71rm23
None
Here's a pic of the water valve installed on the bracket on another car.
Tav
Is anyone repoping or have that valve?
[Re: m46rat]
#322646
05/31/09 04:56 PM
05/31/09 04:56 PM
Posts: 6,090 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
Tag info for above car: M26 M31 M42 M44 N41 CTD H51 J25 L25 L31 M21 B51 C16 C55 G11 G31 G33 V1X U A01 A04 A46 A62 GY3 H6Y3 000 903 0229-- E65 D32 JH23 N1B 1274--
EN2 N85 R11 R31 V5X 26 JH23 N1B 1274--
Tav: It is a non N95 car. What measurements do you need, if any? I bought it as a shell, no A/C, motor or trans. etc.
Your fender tag codes are weird.
Never seen M26 or M44 on a car before. You car didn't come w/chrome exhaust tips?
[Re: 71rm23]
#322647
05/31/09 10:58 PM
05/31/09 10:58 PM
Posts: 4,165 Florida
cataclysm80
used or NOS only. You might try Classic Auto Air, I think they usually have some NOS ones up on Ebay.
Tav
[Re: 2fast4yourBrain]
#322648
05/31/09 11:01 PM
05/31/09 11:01 PM
cataclysm80
I think they're alright. M26 & M44 would be part of the A46 molding package which is listed on the tag. The tag has CTD which means "continued". There is a second tag, and the first code on it is probably N42 for chrome tips.
Tav
[Re: cataclysm80]
#322649
05/31/09 11:20 PM
05/31/09 11:20 PM
Posts: 2,315 South, FL
cudaized
South, FL
Actually, there shouldn't be an N42 code. [As noted on the second data plate.] This is a JH car. Dual exhaust came with the N code 383-4. It would have had the turn down exhaust tips. However, N42 could have been optioned. Only the R/T models (JS) came with the N42 exhaust tips as standard equipment.
This picture is of an E65 N coded 383-4 with only the N41 on the Data Plate
