BLOW OUT Sale!!!.... 1966 Dodge Coronet Convertible NOS Pass
[Re: moparts]
#3231463
05/06/24 07:44 PM
05/06/24 07:44 PM
Posts: 477 NJ
Nvr4Get911
NJ
BLOW OUT Sale!!!.... 1966 Dodge Coronet Convertible NOS Passenger Side Quarter Panel NOS - Part# 2528926 Confirm with your body shop on fitment for a 2 door. ...that's correct.... it's a NOS part...never mounted, never used...Nothing better than NOS!!! .....$1,000. CASH....Pick-up only or Buyer finds their own transporter / shipper.....Located in NJ......That's right $1,000...CASH well worth the long drive. I've drove further for less! (20 min. from DE & Phila. & 5 min. from Exit 2 NJT.) Well worth it!!! Even if you don't need it, buy it as a spare!!! Email me at pursuitison@live.com
flasher parts
[Re: Nvr4Get911]
#3231603
05/07/24 05:46 PM
05/07/24 05:46 PM
Posts: 21,443 It's a dry heat
gtx6970
It's a dry heat
A system Ive removed from my car . It never worked and wasnt until I started to remove it did I realize it was never plugged in the fuse block on the backside. But by then, I had already removed most of it. MY car isnt supposed to have it anyway. So , Out it came
Everything you see is included. Wiring, flasher, switch pt # 2631668 and dash bezel $100 postage not included.
I also have an NOS switch # 2820501. Just different part number, but per the online parts books is correct for 67 and interchanges with the 66 system NOS switch is separate price of $150 and will not be sold until the wiring and above set up sells first. basically, buyer of the wiring etc gets first shot at the NOS switch
Buy it all at $250 and I'll cover postage anywhere in the lower 48 states
