Page 3 of 3 1 2 3
Re: Are you in, or near Total Eclipse path…plans? [Re: Remy-Z] #3225870
04/08/24 06:22 PM
04/08/24 06:22 PM
tboomer Online work
tboomer  Online Work
Best eclipse pic I have seen so far! up
Re: Are you in, or near Total Eclipse path…plans? [Re: tboomer] #3226182
04/10/24 05:17 AM
04/10/24 05:17 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
One from my brother taken in Erie, Pa and two taken by me in our front yard. Full eclipse by my brother and the "diamond" by me.
Re: Are you in, or near Total Eclipse path…plans? [Re: A12] #3226185
04/10/24 06:18 AM
04/10/24 06:18 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
This is an odd one taken during totality.
Re: Are you in, or near Total Eclipse path…plans? [Re: A12] #3226213
04/10/24 08:39 AM
04/10/24 08:39 AM
Virginia
BSharp Offline
BSharp  Offline
Virginia
I think it's remarkable that through just blind, stupid luck, the sun and moon have the exact same apparent size as viewed from Earth.
Re: Are you in, or near Total Eclipse path…plans? [Re: BSharp] #3226221
04/10/24 09:46 AM
04/10/24 09:46 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
grin YES! You would think it would look like a small spot in the middle of the sun like this wink :
Re: Are you in, or near Total Eclipse path…plans? [Re: A12] #3226227
04/10/24 10:23 AM
04/10/24 10:23 AM
Virginia
BSharp Offline
BSharp  Offline
Virginia
From 2017 in South Carolina.
Re: Are you in, or near Total Eclipse path…plans? [Re: BSharp] #3226853
04/13/24 11:29 AM
04/13/24 11:29 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Only covered about 80% where I'm at. The sun was out all day except when the eclipse started. Then the clouds started rolling in and blocked a good part of it. Was able to watch it with a welding helmet and burning goggles on the helmet. The lens in the helmet wasn't dark enough. Even tried to take a pic with the phone behind the helmet. It's not that good but you can see it.
Page 3 of 3 1 2 3
