R12 vs R 134 expansion valve —UPDATE
#3223683
03/30/24 11:23 AM
03/30/24 11:23 AM
Posts: 6,410 Abilene, Texas
fastmark
Abilene, Texas
Just getting my new 4 seasons expansion valve out of the box and noticed is says 134a on it. I’m going back with my old rv2 and r12. Will this make any difference? I’ve still have the old valve but it not be used in many years.
Re: R12 vs R 134 expansion valve
[Re: fastmark]
#3223695
03/30/24 11:58 AM
03/30/24 11:58 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
As far I know , the difference (aside the seals), is the pressure adjustment. Can be readjusted but for the price of the piece doesn’t worth the readjustment effort. On my car thought made the R134 “upgrade” on my stock system, including the expansion valve without any readjustment and worked really nice. But I will install a correctly adjusted R134 unit (same, 4 seasons unit that probably you got ) when reassembling my car.
About reuse the original one, well, my car was with the AC without any use by maybe 15-20 years by the original owner (and I refill the system maybe in 2005) and when I made it to work again, still with the R12 before the R134 upgrade, worked nicely.
[Re: Droop69]
#3225104
04/04/24 08:32 PM
04/04/24 08:32 PM
fastmark
Abilene, Texas
I do have the original. It was still on the car but the short discharge hose was the only hose in the car. It was probably removed early on so it has been exposed for a long time. I still have several parts cars with the complete systems still intact that I could use but they have been dormant for many years I found an NOS one on eBay for not much more than old air wanted for one of their 134a valves. I got a 134 marked valve on rock auto for $25. I just don’t want this thing to fail right off and waste my R12.
[Re: fastmark]
#3225151
04/05/24 05:18 AM
04/05/24 05:18 AM
NachoRT74
Valencia, España
New (not NOS) r12 parts are still available at parts stores if you are worry about still use the original one. Just request for it. I’m sure 4Seasons still makes them. When I got my expansion valve and dryer I asked to Rockauto to be specific for r134 (for the later upgrade I was to make) on parts request. They told me the PNs for 4 seasons between R12 and R134 parts were diff by just 1 number. Let’s say! R134 PNs were 3xxxxxx and R12 were 2xxxxxx
…or something like that. That was long time ago.
So ask the dealers or straight to 4seasons
[Re: fastmark]
#3225247
04/05/24 02:55 PM
04/05/24 02:55 PM
NachoRT74
Valencia, España
Rockauto doesn’t mention on their website if what they sell is for any of the refrigerants (or didn’t back when I bought) hence why I contacted them and got that answer. I guess they asked to 4seasons and replied me with the answer got from 4seasons
[Re: NachoRT74]
#3227614
04/17/24 07:35 AM
04/17/24 07:35 AM
fastmark
Abilene, Texas
Well. I got the NOS R12 expansion valve in with all the correct size o rings from multiple places, evacuated the system and pressurized it to 100 lbs with nitrogen. I found two small leaks with the nitrogen at the schrader valves. I replaced them repeated and they held. I filled it with liquid gold, R12 to the proper amount and it comes out of the vents at 34-38 degrees.
