Re: Christine in 2024? [Re: rdrnr6970] #3223515
03/29/24 10:29 AM
03/29/24 10:29 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Blumhouse is known for scary good movies. I have hope. But in the present- many remakes and reboots are just terrible. The biggest examples are bowing to a woke agenda. The most recent Terminator is a great example- Ghostbusters 2016, Laura Croft -Indiana Jones etc. Another example is overuse of CGI. Even expensive CGI can look awful. The Thing prequel shows this. Then there is taming the remake down to a PG13 rating when the original was R. Robocop remake does this along with many others.
Keep old mopars alive.
Re: Christine in 2024? [Re: 2boltmain] #3223651
03/30/24 09:14 AM
03/30/24 09:14 AM
rust belt
Moparite Online content
Moparite  Online Content
rust belt
Quote
Tesla would be fine as I wouldn't be on board with destroying more '58 Plymouths to make a movie. They can destroy all the Teslas they want... as many as possible would be preferable.
Along with all the other hideous turds on the roads. I don't want to see any mopars being destroyed to make a buck. They should have had a warning before watching the Dukes of Hazard movie. "You will be sick to your stomach to see all the Chargers we destroyed to make this movie". If any of you have seen the clip of the charger land after the big jump it's disturbing! I did like seeing the Camaro being t boned into the gas station! I still can't figure out why the CG of today is worse than it was when Jurassic Park came out. confused
Re: Christine in 2024? [Re: 6PKRTSE] #3223739
03/30/24 03:27 PM
03/30/24 03:27 PM
stratford,ontario,canada
JD340 Offline
JD340  Offline
Originally Posted by 6PKRTSE
I would rather see Christine 2 and it come back to life continuing in the junk yard from the moving piece of trim as it ended in the first movie after being covered by hundreds of other crushed cars after so many years. Once uncovered, it starts all over again.
iagree I've longed for a sequel starting off exactly like that.
Nothing to see here. Carry on.
