Charger Glovebox #3221870
03/21/24 11:06 AM
03/21/24 11:06 AM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
Hi
I'm helping a friend with his '70 Dodge Charger (with A/C).
Looking for some advice for removing the glovebox.
Hoping it somehow comes out through the front...
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Charger Glovebox [Re: Hrtbkr] #3221897
03/21/24 12:56 PM
03/21/24 12:56 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
If you are trying to save the glovebox liner....it comes out from the back side. I am not aware of a way to pull it through the opening. On an a/c car it's quite a job to get out.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Charger Glovebox [Re: 70gtx440dana] #3221912
03/21/24 02:14 PM
03/21/24 02:14 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
It's a pain - they were installed from the backside, and that's the method for R&R.
Memory says remove defroster hoses, push glovebox back & above heater case, wrestle out the bottom.
That's an old memory, though, may be OK with hoses attached.
But I can't recall doing that job on an AC car.
