Re: toll used to hold pinion yolk while torqueing nut ?
[Re: cudaman1969]
#3220589
03/15/24 11:42 AM
03/15/24 11:42 AM
Posts: 6,355 nowhere
Sniper
nowhere
My 35 year old 110 electric Makita is ALL I’ve ever used, never once has a nut backed off (a little red loctite helps too) Beautiful, except the OP was asking how you hold the yoke when you are torquing the pinion nut. I hope you aren't using that same Makita for that. I use my hand to hold the yoke, take a hammer and hit a nail hard, the nail drives into the wood, now a slow tap on the nail, no move. The Makita works on same principal as the fast swinging hammer! It’s called FORCE, kinetic energy You still do not understand. WE ARE NOT TALKING ABOUT REMOVING THE PINION NUT WE ARE TALKING ABOUT TORQUING THE PINION NUT
[Re: Sniper]
#3220595
03/15/24 12:23 PM
03/15/24 12:23 PM
Posts: 4,767 Moved to N.E. Tennessee
GomangoCuda
My 35 year old 110 electric Makita is ALL I’ve ever used, never once has a nut backed off (a little red loctite helps too) Beautiful, except the OP was asking how you hold the yoke when you are torquing the pinion nut. I hope you aren't using that same Makita for that. I use my hand to hold the yoke, take a hammer and hit a nail hard, the nail drives into the wood, now a slow tap on the nail, no move. The Makita works on same principal as the fast swinging hammer! It’s called FORCE, kinetic energy You still do not understand. WE ARE NOT TALKING ABOUT REMOVING THE PINION NUT WE ARE TALKING ABOUT TORQUING THE PINION NUT Reread Cudanas post. He is obviously talking about tightening the pinion nut. You don't use red locktite to remove the nut.
[Re: cudaman1969]
#3220610
03/15/24 12:41 PM
03/15/24 12:41 PM
Posts: 2,013 Apollo, PA.
B1MAXX
Apollo, PA.
My 35 year old 110 electric Makita is ALL I’ve ever used, never once has a nut backed off (a little red loctite helps too) Beautiful, except the OP was asking how you hold the yoke when you are torquing the pinion nut. I hope you aren't using that same Makita for that. I use my hand to hold the yoke, take a hammer and hit a nail hard, the nail drives into the wood, now a slow tap on the nail, no move. The Makita works on same principal as the fast swinging hammer! It’s called FORCE, kinetic energy I had to read this twice at first I thought he drove in nails with his bear hands ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) But I have done what he's saying not all the time but have done it. Like loose ones in late 90's Rams.
[Re: Sniper]
#3220708
03/15/24 09:07 PM
03/15/24 09:07 PM
Posts: 8,371 fredericksburg,va
cudaman1969
fredericksburg,va
My 35 year old 110 electric Makita is ALL I’ve ever used, never once has a nut backed off (a little red loctite helps too) Beautiful, except the OP was asking how you hold the yoke when you are torquing the pinion nut. I hope you aren't using that same Makita for that. I use my hand to hold the yoke, take a hammer and hit a nail hard, the nail drives into the wood, now a slow tap on the nail, no move. The Makita works on same principal as the fast swinging hammer! It’s called FORCE, kinetic energy You still do not understand. WE ARE NOT TALKING ABOUT REMOVING THE PINION NUT WE ARE TALKING ABOUT TORQUING THE PINION NUT Oh I do understand, torquing the nut has no value other than to assure it doesn’t back off, the very same thing as red loctite does. Then it ONLY comes off when it’s needed. Why is any bolt torqued? To lock it on, the only stretch that the pinion will do is from the front bearing out. 742 and Dana have shims to set preload 489 has a crush sleeve to set preload, it needs 250 ft lbs to crush or get the crush sleeve eliminator to eliminate that cheapo fix from Chrysler. And not a dang one has backed off unless I wanted it to. That Makita has taken off every factory pinion nut I’ve ever used it on (a lot), there are things I’ll torque but a pinion ain’t one of those.
[Re: cudaman1969]
#3220743
03/16/24 01:39 AM
03/16/24 01:39 AM
Posts: 11,769 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Pinion nut torque can be used as a final adjustment on preload and turning torque. This applies to solid spacers as well as crush sleeves, which should not be used in a performance application.
Even the major rear end parts suppliers have different methods and numbers they recommend. One says 200 on a small pinion and dial in the preload with shims at that number. Another says 140 as a minimum, up to 200 to dial in preload. Tightening the nut will increase preload.
Preload numbers also vary. Intended use will dictate this number. A performance based class will use very low preload numbers, relatively speaking.
[Re: moparx]
#3220765
03/16/24 09:56 AM
03/16/24 09:56 AM
Posts: 1,769 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
This is probably one of the 1st tools I made...was awfully proud of it too, although as you can tell that this welding job of mine leaves a lot to be desired (as far as improvements go LOL).
Still, several yoke installs later, still working great, no deflection in the material so far.
[Re: CMcAllister]
#3220821
03/16/24 02:01 PM
03/16/24 02:01 PM
Posts: 26,027 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Pinion nut torque can be used as a final adjustment on preload and turning torque. This applies to solid spacers as well as crush sleeves, which should not be used in a performance application. How is the preload affected by torque when the yoke bottoms on the pinion shoulder? Once the yoke bottoms on the pinion shoulder, further tightening won't preload the bearings any more...you can keep tightening the nut until the threads fail and the bearing preload will stay the same.
[Re: John_Kunkel]
#3220842
03/16/24 03:31 PM
03/16/24 03:31 PM
cudaman1969
fredericksburg,va
Pinion nut torque can be used as a final adjustment on preload and turning torque. This applies to solid spacers as well as crush sleeves, which should not be used in a performance application. How is the preload affected by torque when the yoke bottoms on the pinion shoulder? Once the yoke bottoms on the pinion shoulder, further tightening won't preload the bearings any more...you can keep tightening the nut until the threads fail and the bearing preload will stay the same. John and I agree on something finally lol
[Re: John_Kunkel]
#3220893
03/16/24 07:51 PM
03/16/24 07:51 PM
Posts: 43,347 Bend,OR USA
Cab_Burge
Pinion nut torque can be used as a final adjustment on preload and turning torque. This applies to solid spacers as well as crush sleeves, which should not be used in a performance application. How is the preload affected by torque when the yoke bottoms on the pinion shoulder? Once the yoke bottoms on the pinion shoulder, further tightening won't preload the bearings any more...you can keep tightening the nut until the threads fail and the bearing preload will stay the same. Not on those pinion shafts with crush sleeves ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
[Re: Cab_Burge]
#3220914
03/16/24 09:33 PM
03/16/24 09:33 PM
Posts: 15,564 Omaha Ne
TJP
Omaha Ne
Pinion nut torque can be used as a final adjustment on preload and turning torque. This applies to solid spacers as well as crush sleeves, which should not be used in a performance application. How is the preload affected by torque when the yoke bottoms on the pinion shoulder? Once the yoke bottoms on the pinion shoulder, further tightening won't preload the bearings any more...you can keep tightening the nut until the threads fail and the bearing preload will stay the same. Not on those pinion shafts with crush sleeves Cab, what they are saying is with a "shimmed" non-crush sleeve application, once bottomed, tightening the nut more will have no affect on pre load. However applying more torque to the nut WITH A CRUSH sleeve will add more pre load to the bearings. As the yoke would not be bottomed on pinion and tightening the nut more will add more preload as the sleeve crushes more. I'm sure you know this ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) but are likely misinterpreting what they are saying ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif) .
[Re: TJP]
#3220931
03/16/24 10:48 PM
03/16/24 10:48 PM
Cab_Burge
Until you crush is too much is what I found on the 489 cases, once it is to short your done adjusting them. You have to replace the crush sleeve or buy a spacer and use shims until you get it correct ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: John_Kunkel]
#3220936
03/16/24 11:56 PM
03/16/24 11:56 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Pinion nut torque can be used as a final adjustment on preload and turning torque. This applies to solid spacers as well as crush sleeves, which should not be used in a performance application. How is the preload affected by torque when the yoke bottoms on the pinion shoulder? Once the yoke bottoms on the pinion shoulder, further tightening won't preload the bearings any more...you can keep tightening the nut until the threads fail and the bearing preload will stay the same. Sounded like BS to me too... until I tried it. Per Mark Williams... 4) Before installing the seal it is a good idea to check the bearing preload, even with a new assembly. Install yoke or coupler on the pinion, install pinion nut and torque to 140 ft/lbs (if possible it is suggested to use a used pinion nut until final assembly). Rotate the pinion with an inch/lbs. torque wrench. The rotational drag should be 7-10 in/lbs (if re-assembling a support with used bearings the rotational drag can be 5-7 in/lbs). If the rotational drag is too low step up the pinion nut torque in 10 ft/lbs increments and re-check the drag. Once the correct drag is achieved note the pinion nut torque. Maximum pinion nut torque is 200 ft/lbs. If the amount of drag is too high the preload spacer is too thin and should be replaced (new spacers will require machining). TORQUE SPECS: Pinion Nut 140 ft/lbs unless higher torque required per step #4 above.
[Re: CMcAllister]
#3221031
03/17/24 01:47 PM
03/17/24 01:47 PM
Posts: 19,678 north of coder
moparx
so i need to pull the carrier from the car to check preload turning torque just to change the yolk ? this is a 741 case with no crush sleeve. i just figured this would be a simple remove nut, remove yolk, replace seal, install new yolk, tighten new nut to specification. i must be really missing something. plus i just noticed i titled this thread as a "toll" used. maybe i just need to pay the "toll" and get over it. and yes, i'm not the sharpest knife in the drawer.............. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: B1MAXX]
#3221057
03/17/24 02:44 PM
03/17/24 02:44 PM
cudaman1969
fredericksburg,va
for that job I would use an impact and red lock tight done in 10 minutes. EXACTLY I don’t give a sh!t what MW says, on a shimmed pinion it will not go any tighter. Shims don’t compress! Bearings don’t compress! UNLESS there’s 500 tons on it!
[Re: cudaman1969]
#3221062
03/17/24 03:14 PM
03/17/24 03:14 PM
John_Kunkel
Rio Linda, CA
for that job I would use an impact and red lock tight done in 10 minutes. EXACTLY I don’t give a sh!t what MW says, on a shimmed pinion it will not go any tighter. Shims don’t compress! Bearings don’t compress! UNLESS there’s 500 tons on it! Yep, but he says "Sounded like BS to me too... until I tried it." There must be places where the laws of physics don't apply. ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif)
[Re: John_Kunkel]
#3221111
03/17/24 06:45 PM
03/17/24 06:45 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
for that job I would use an impact and red lock tight done in 10 minutes. EXACTLY I don’t give a sh!t what MW says, on a shimmed pinion it will not go any tighter. Shims don’t compress! Bearings don’t compress! UNLESS there’s 500 tons on it! Yep, but he says "Sounded like BS to me too... until I tried it." There must be places where the laws of physics don't apply. I'm not talking double digits. More like a couple of inch pounds, for those who are trying to dial it in to a preferred number. That's okay though. Maybe those were days I did some mushrooms and hallucinated it all.
