Transmission crossmember question #3219981
03/12/24 02:03 PM
03/12/24 02:03 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
My Dart that I converted to a big block/727 was originally a slant 6 with a 904. Can I use the transmission crossmember and biscuit type mount from the 904 on the 727? I would get a new biscuit if I can. Also, I was wondering if I should switch to the later spool mount type crossmember. Is there any advantage to using a spool type mount or will I be O.K. with the biscuit mount crossmember I have?
Re: Transmission crossmember question [Re: 6PAX] #3219992
03/12/24 03:11 PM
03/12/24 03:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Auto trans crossmember is the same 727, 904.
Converting to the spool xmember will making seeking the rubber mount a little easier in the future , from what I hear the biscuit mounts may be slightly taller than original ?
Re: Transmission crossmember question [Re: JohnRR] #3220169
03/13/24 12:53 PM
03/13/24 12:53 PM
moparx Offline
moparx  Offline
i bought a replacement mount for my 69 charger, and it appears it may be slightly taller, but i haven't installed it yet.
as the mount there now is the original, it may have shrunk or slightly settled/collapsed since new, 55 years ago.
beer
